Old Dec 11, 2003, 02:53 PM
pc_pilot is offline
Find More Posts by pc_pilot
USA, NY, Yonkers
Joined Aug 2002
Can this ESC handle 4 servos?
I posted this question in the GWS forum but I did not get any replies, so I am trying it here.
I built my GWS Corsair using an ICS-400 ESC. I am using 3 servos now for aileron, elevator and retracts. I want to add rudder control also but I do not know if the ICS-400 can handle 4 servos.
Is it safe to add a 4th servo or will it damage the ESC?
THANKS
pc_pilot
pc_pilot is offline Find More Posts by pc_pilot
Old Dec 11, 2003, 02:57 PM
citabria is offline
Find More Posts by citabria
Under tension
citabria's Avatar
Johnstown, Colorado
Joined May 2002
The ICS 400 will have no problem at all with four servos. It's a solid 15A controller. I've used them on more than one plane with 4 servos.
Scott
citabria is offline Find More Posts by citabria
Old Dec 11, 2003, 03:08 PM
FLL is offline
FLL
Find More Posts by FLL
FLL
Towaco, NJ
Joined Mar 2003
You don't mention what brand and model servos you're using. I found out the hard way that the 4 BMS Bluebird servos in my speed 400 sailplane were too much for the BEC in my 25A Castle SC to handle (shutdown city). Switched to 4 HS 55's and problem ended.
Be careful, 4 is pushing the limit,
Frank
FLL is offline Find More Posts by FLL
Old Dec 11, 2003, 03:12 PM
pc_pilot is offline
USA, NY, Yonkers
Joined Aug 2002
I am using the 9 gram servos sold by ALLERC.COM. They are the same size as the HS-55 servo.
Old Dec 11, 2003, 03:13 PM
thunder1 is online now
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
What servos and what battery?
The BEC on that controller is rated for 1.2 amps at 8 cells. The more cells you have the more heat (power) the BEC has to dissipate.
I've read of at least one EZone reader who smoked the BEC by trying to run four servos with a 3s (11.1v nominal) Lipo battery.
thunder1 is online now Find More Posts by thunder1
Old Dec 11, 2003, 03:19 PM
No Step is offline
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
I looked around on some web sites and couldn't find anything that says how many servos it will handle either. But >>as I understand it << , it won't damage the ESC , it will just not be able to handle current draw of all the servos and fail to operate servos & reciever resulting in a crash. I know, big help ?! I am no expert. Alot depends also on how smoothly (no binding) the surfaces move thus resulting in minimal current draw to begin with. With the single servo/linkage setup on the GWS Corsair, there might be a good amount of current draw there on that servo. Wish I could help some more. Maybe someone with more experience with this ESC will chime in.
Fred G.
No Step is offline Find More Posts by No Step
Old Dec 11, 2003, 03:23 PM
College Park, MD
Joined Sep 2002
The specs on those servos are Speed (sec/60) .11, Torque 1.1/15.3 (4.8 V)
The specs on HS-55s are Speed (sec/60) .17, Torque 1.1/15 (4.8 V)
So you could infer that the servos you are using must be using more amps because they provide the same torque but are significantly faster (.11 vs .17) The difference in speed must be because the motor is hotter or the gearing is different.
But actual current useage can only be found by testing due to efficiencies, etc.
I always try to test out my controllers BEC capacity first by hooking all the servos up and wiggling the stick around as if I'm flying. (not very accurate since there's no load on the servos but it is fun to do) If the ESC gets so hot you can't touch it, you're asking for trouble.
Old Dec 11, 2003, 03:50 PM
pc_pilot is offline
USA, NY, Yonkers
Joined Aug 2002
All my battery packs are either 7.2v NICD or 8.4v Li-ion and Li-poly. I wouldn't want to damage the esc so I figure I will just stay with the setup I have now or remove the retracts and add the rudder.
Old Dec 11, 2003, 03:56 PM
headless is offline
Find More Posts by headless
Does anyone hear a cat?
headless's Avatar
Tallahassee, FL
Joined Sep 2003
Curious; could one use a clamp meter around those smallllllll wires on a servo -- maybe just the hot wire, and actually measure the current it's pulling? Are clamp meters not accurate enough for wire that small?
headless is offline Find More Posts by headless
Old Dec 11, 2003, 05:17 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
I was thinking about this earlier, and isn't the BEC really just a voltage regulator? Whats to stop someone from bypassing the BEC in the normal rx and using something like an +5v regulator? I have a couple that run at 3A at 12V...
Phreakish is offline Find More Posts by Phreakish
Old Dec 14, 2003, 02:46 AM
College Park, MD
Joined Sep 2002
The BEC is in the ESC, not the Rx.
No problem running a separate BEC, just disconnect the red (+) wire from the ESC - Rx connector so that the ESC BEC is not supplying power to the Rx.
Just make sure the voltage regulator puts out a voltage that your servos and Rx expect. Connect the input to the drive battery and the output to the Rx red and black (+ -) connectors on an unsued channel.
Anyone lets CC PH25 ESC to handle 4 servos? eta Power Systems 15 May 09, 2005 04:37 PM
Can the phoenix10 handle 4 servos? TMASTER Castle Creations 7 Apr 07, 2005 12:00 PM
can castle phoenix 25 handle 4 servos and 3cell lipo Paul Wilson Power Systems 3 Jul 12, 2004 12:44 AM
Can the ICS-400 ESC handle 4 servos? pc_pilot GWS (Grand Wing Servo) 5 Dec 15, 2003 09:53 AM
E-Flite Maxx 25 ESC how many servos can this thing handle KenP Power Systems 2 Jan 30, 2003 05:02 PM
