Old Jan 13, 2013, 01:55 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Originally Posted by Keenan smith View Post
the Nacelles still look a bit big to me...
I was kinda feeling the same, but the pictures I had were telling me otherwise.
I did find another image (the green one)and overlayed it on the one I was building off of. Nacelles are slightly smaller in that one. I'll modify it a bit and see if that looks any better
Dirty Dee is offline Find More Posts by Dirty Dee
Old Jan 13, 2013, 03:47 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Yeah that drawing looks more accurate
Keenan smith is offline Find More Posts by Keenan smith
Old Jan 13, 2013, 04:54 PM
Dirty Dee's Avatar
Joined Sep 2011
Alright, redid the nacelles based on the other image, making the outer diameter of the nacelle ~0.37in less in diameter. Definitely looks better
Old Jan 13, 2013, 05:22 PM
Dirty Dee's Avatar
Joined Sep 2011
Originally Posted by cpdude View Post
Very cool! I love A-10s. Let me know if I can help you out with any laser cutting.
Brian
Thanks, I'll keep it in mind.
Originally Posted by lardo5150 View Post
I'll buy you lunch if you share those plans/autocad stuff
I'm probably going to release the cut files for free as long as people will share their build and help with giving this a shakedown to find design flaws (too heavy, bad flight tendencies, wing rips off in flight )
Old Jan 13, 2013, 05:23 PM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
hopefully no wings ripping off. although, I have been known to LMAO when it happens. LOL.
LuvEvolution7 is online now Find More Posts by LuvEvolution7
Old Jan 13, 2013, 06:46 PM
Joined Dec 2010
Much better..
Old Jan 13, 2013, 08:14 PM
lardo5150 is offline
Find More Posts by lardo5150
United States, MO, St Charles
Joined Jan 2013
Awesome, that is much appreciated.
I have a three stage goal - fly my trainer - build and fly an A-10 ARF - then build my own A-10.
Learning process for us noobies, but I am just collecting info as I go along while I learn and get setup.
lardo5150 is offline Find More Posts by lardo5150
Old Jan 15, 2013, 12:06 AM
Dirty Dee's Avatar
Joined Sep 2011
Some quick progress pictures.
Old Jan 19, 2013, 04:16 PM
Dirty Dee's Avatar
Joined Sep 2011
I've been working on the control surface movements and fixing any issues to make sure everything will move freely come time for the build. I originally played with a curved slot track for the fowler flaps, but found that two straght slots work, and are very simple to design.
also added the LE stats. Not sure if will just have these as static, or deploy with flaps (although, they were only operated during high AOA and I think when the GAU-8 was fired)
Old Jan 28, 2013, 12:16 AM
Dirty Dee's Avatar
Joined Sep 2011
Removable wing section is mostly complete. Still need to include the shear webs and do mounts for servos and landing gear.
For a plane of this size, whats a good size for shear webs and spars? Currently I have shown 1/4" spars (spruce), and the shear webs will be 1/8" balsa. Is this overkill?
Old Jan 29, 2013, 12:25 AM
Dirty Dee's Avatar
Joined Sep 2011
Was playing around and decided to make an N/AW model too.
Old Jan 29, 2013, 12:42 AM
Joined Jan 2009
now that's kick a$$. I'd go for one of those. I believe it's HK that sells this version and it looks awesome with invasion stripes.
Old Jan 29, 2013, 05:41 AM
Bill Diedrich is offline
Find More Posts by Bill Diedrich
Bill Diedrich's Avatar
Ventress, Louisiana
Joined Oct 2007
DD for someone that is just training and looking to move up
to an A-10 your drawing and design is awesome, you must have
done a lot of research into model design techniques and are a
first rate CAD draftsman to boot. Will definately be subscribed
and looking forward to what is coming down the pipeline. Keep
up the good work it is enjoyable to read and follow.
Bill D.
Bill Diedrich is offline Find More Posts by Bill Diedrich
Old Jan 29, 2013, 12:49 PM
Dirty Dee's Avatar
Joined Sep 2011
Yea, HK sells the 2 seater. almost picked it up last month but then I realized i still had 3 planes i needed to finish assembling.
I might be able to set up the planes so it can be an easy conversion between the one-seater, to the N/AW version. Only difference is the tail surface extends higher, and of course, the cockpit area. That way you can hotswap the A-10 at the field between the two versions if you want.
Bill D.
Thanks for the compliments. I have spent tons of time on research for this plane since i'm a bit picky about making this as scale as possible. A lot of the modeling design I learned by myself, and picked up a few other techniques from others on this site.
Old Jan 29, 2013, 10:46 PM
Joined Jan 2009
that's a great idea. I had the same idea with my Sepecat Jaguar. simply remove the single seat nose section and replace with the twin seat nose. multiple choices in one aircraft.
Discussion Home/ Electric RC On-Road/ 1/10 RC Electric On-Road/ HSP 1/10 Scale 2.4GHz RTR Brushl lancaster1945 Car Talk 1 Mar 24, 2013 01:47 PM
Build Log 1/10 scale R.A.F Se5a build Chompwat Scale Kit/Scratch Built 44 Dec 23, 2012 03:01 AM
Discussion Scale A-10 Warthog Build AirborneRME Jet Turbines 1 Jul 20, 2012 12:03 AM
Discussion lx warthog scale a-10 cool but expensive:( milton12325 Foamy EDFs 0 Jun 09, 2012 05:08 PM
Discussion 1/5.5 or 1/6 Scale A-10 Warthog Kit jtw0006 The Builders Workshop 1 May 23, 2007 05:30 PM
