Old Nov 27, 2012, 09:04 PM
Dirty Dee is offline
Find More Posts by Dirty Dee
Dirty Dee's Avatar
United States, IL, Northbrook
Joined Sep 2011
Build Log
A-10 Warthog Balsa Design and Build: 1/11th Scale
I was originally going to build a Chis Golds A-10. But after starting to convert the plans to AutoCAD I realized it wasn't as scale as I would have liked.
This is my first balsa build, and I figured this would be a good size. I plan on eventually scaling the design up to meet IMAA requirements after ironing out any issued from this first pass.
Fowler flaps and decelerons will be worked into it too.
Here are some picture of the finalized solid model and the start of the balsa ribs, formers, etc. Loadout probably isnt realistic, but I got carried away
Dirty Dee is offline Find More Posts by Dirty Dee
Old Nov 29, 2012, 10:24 AM
eatond is offline
Find More Posts by eatond
EDF Jet Jam 2016, June 16-19th
eatond's Avatar
United States, MO, St Charles
Joined Nov 2002
Hi Dirty Dee,
nice job so far. What source did you use for a 3 view?
Dan Eaton
eatond is offline Find More Posts by eatond
Old Nov 29, 2012, 07:38 PM
Dirty Dee's Avatar
Joined Sep 2011
Originally Posted by eatond View Post
Hi Dirty Dee,
Dan Eaton
I used the ones attached as well as from this site:
http://www.airwar.ru/other/draw2/a10a.html
Old Dec 03, 2012, 09:17 PM
Dirty Dee's Avatar
Joined Sep 2011
Progress update pic.
Wing tips and nacelle intakes will be made from 3mm stacked depron. Tail cone is 6mm depron.
I was debating making the wing 1-piece removable. Now I'm thinking I will do a 2 piece, detachable before the inboard flaps.
I also decided to make basic ailerons for now and then design the decelerons after I get this airborne.
Old Dec 07, 2012, 10:44 AM
FOShowNoClass is offline
Find More Posts by FOShowNoClass
SDF
Joined Sep 2002
I'd love to build one when you get the plans done. Good luck!
FOShowNoClass is offline Find More Posts by FOShowNoClass
Old Dec 08, 2012, 09:47 PM
TomJacoby is offline
Find More Posts by TomJacoby
Imagine That!
TomJacoby's Avatar
Tularosa, New Mexico, United States
Joined Jan 2003
Great CAD work!
-=Tom=-
TomJacoby is offline Find More Posts by TomJacoby
Old Dec 11, 2012, 06:32 PM
SDF
Joined Sep 2002
Is this for 70mm fans?
Old Dec 12, 2012, 10:17 AM
Dirty Dee's Avatar
Joined Sep 2011
That's the plan. But since the inside diameter of the nacelles are close to 120mm it will require a taper to the fans, which will look strange.
One option I was considering is just using 90mms, but that might be overkill.
What I was thinking is rather get a set of 120mm fan blades and place them ahead of the 70mm fan unit, and allow them to spin freely, similar to what is done for the larger turbine a-10s.
Old Dec 20, 2012, 10:44 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Nice plan you have going. I love the A10 and recently built a twin 50mm. I plan to build a larger one at some point. It sounds like if you go 90mm it would leave you 10mm thick walls on the nacelles, that would be a good material thickness for shaping the intake and the slight rear taper. I look forward to your build Greg
Lt599 is offline Find More Posts by Lt599
Old Dec 20, 2012, 11:48 PM
Dirty Dee's Avatar
Joined Sep 2011
thanks for the kind words.
For the nacelles, I might be sheeting the inside surface for the front and center section. For the rear where it curves I might do a mix of balsa and hot-wired foam since sheeting seems like it would be a pain.
I haven't gotten much progress to be worth posting new pictures since the past few weeks have been hectic. Been working on the nose section and gear bay. After Christmas I should be back in full swing with the design.
Old Dec 23, 2012, 09:53 AM
PANTHERFLYR is offline
Find More Posts by PANTHERFLYR
Retired C-5 Flight Engineer
PANTHERFLYR's Avatar
United States, CA, Fairfield
Joined May 2005
wow!
PANTHERFLYR is offline Find More Posts by PANTHERFLYR
Old Dec 24, 2012, 11:10 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
awesome Subbed
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 26, 2012, 08:59 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
subbed. you could always run bigger fans on less cells. for example, run them on 5S instead of 6S, or stick to 6S and run around at half throttle and get longer flight times.
I would not recommend putting larger fans in front that freewheel in the breeze. this will add all kinds of unwanted vortices into the driving fans and will severely diminish their performance. I would go with larger fans right from the get go and run them either way I suggested above. the 12 blade fans from Hobby King (or other sources) will be good for an A-10, since they look the part, sound the part and you don't need fighter-like performance. i think that's the way to go.
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 27, 2012, 02:17 PM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
subscribed
I ditto LuvEvolution.
IWC is offline Find More Posts by IWC
Old Dec 27, 2012, 03:52 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Nice project, thanks for letting us see your CAD model as it develops!
Rich, could you just use a lower KV motor instead of running at low throttle all the time? It is my understanding that low throttle isn't a good idea done constantly.
BillO is offline Find More Posts by BillO
Discussion Home/ Electric RC On-Road/ 1/10 RC Electric On-Road/ HSP 1/10 Scale 2.4GHz RTR Brushl lancaster1945 Car Talk 1 Mar 24, 2013 01:47 PM
Build Log 1/10 scale R.A.F Se5a build Chompwat Scale Kit/Scratch Built 44 Dec 23, 2012 03:01 AM
Discussion Scale A-10 Warthog Build AirborneRME Jet Turbines 1 Jul 20, 2012 12:03 AM
Discussion lx warthog scale a-10 cool but expensive:( milton12325 Foamy EDFs 0 Jun 09, 2012 05:08 PM
Discussion 1/5.5 or 1/6 Scale A-10 Warthog Kit jtw0006 The Builders Workshop 1 May 23, 2007 05:30 PM
