Old Mar 10, 2013, 04:10 PM
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
the 772 has a pivoting base. get the 771 unless you care for it. also "diamond 771" are generally nagoyas except cheaper (but if you wanna be certain get the real thing)
CrashMeUp is offline Find More Posts by CrashMeUp
Old Mar 10, 2013, 04:32 PM
Xnaron's Avatar
Joined Feb 2003
I just did a ground test on a country road with the following antenna's
TX : Nagoya NA-772 http://www.ebay.com/itm/160615055412
RX: Sander Style http://www.ebay.com/itm/200895096737
I was able to get 1.2KM + away with the servo moving left and right. I had a friend on the TX moving it. I tried 1.5KM and the signal was gone. I was driving and I would get out of the vehicle and move away and hold the rx up as high as I could. I think this is pretty decent for a ground test. I'm thinking in the air the range should be much better. Next test will be in the skywalker with FY31AP.
Xnaron is offline Find More Posts by Xnaron
Old Mar 10, 2013, 04:57 PM
RC pilot by soul
Joined Apr 2005
Originally Posted by freekhead View Post
My question got lost a few pages back.
Anyone wana try and give a guess?
where did you sodler the RSSI output on the filter ?
i3dm is offline Find More Posts by i3dm
Old Mar 10, 2013, 05:23 PM
Joined Oct 2012
Thanks.
I soldered the signal wire from rx rssi to the resistor. On the other end of the resistor I soldered the + lead of the cap and the - lead to ground. Then connected it to the analogue rssi input of the osd
I used a 100k resistor and a 100nF capacitor.
freekhead is offline Find More Posts by freekhead
Old Mar 10, 2013, 05:28 PM
RC pilot by soul
Joined Apr 2005
Thanks.
where did you connect the analog OSD input ?
Old Mar 10, 2013, 06:55 PM
Joined Oct 2012
Thanks.
Old Mar 11, 2013, 12:26 AM
Joined Mar 2012
did anybody successfully integrate a RFM23BP to OrangeRX OpenLRS Tx ?
I have four RFM23BP's and they are physically larger than the RFM22 so it's not a direct drop in. It doesn't look to difficult to just wire it in. For some reason I was thinking it was the same size as the FRM22 and as such would be a direct drop in. I'm going to run with the 100mw system until I reach it's limits before I decide to put the RFM23BP in.
Maglin is offline Find More Posts by Maglin
Old Mar 11, 2013, 02:02 AM
RC pilot by soul
Joined Apr 2005
can you post some pics for size comparison ?
Old Mar 11, 2013, 03:04 AM
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
The dimensions can be found from the datasheets.
Description:
Description:
kha is online now Find More Posts by kha
Old Mar 11, 2013, 10:27 AM
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Hmh... your description sound good. What kind of equipment you have at hand?
Basic DMM? (with Hz?)
An oscilloscope?
You could start by just measuring the signal before and after lowpass with your dmm in both AC and DC settings.
Old Mar 11, 2013, 10:14 PM
Canada, BC, Vancouver
Joined Oct 2011
I've got all the gear ordered, and the repo / arduino downloaded.
Now to just wait for the pony express!
Thanks for the support guys -- I'll be tuning back in once the gear arrives!
syzygyQ is offline Find More Posts by syzygyQ
Old Mar 13, 2013, 06:02 AM
Joined Mar 2011
Hi Kha.,
is this the line to modify to increase the RSSI freq.?
Atm I need a 10kOhm and 1uF in order to filter out the dc value, just wanted to step it up to 5Khz
if (RSSI_count > 20) {
RSSI_sum /= RSSI_count;
analogWrite(RSSI_OUT, map(constrain(RSSI_sum, 45, 200), 40, 200, 0, 255));
Sp1k3 is offline Find More Posts by Sp1k3
Old Mar 13, 2013, 06:48 AM
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by Sp1k3 View Post
Hi Kha.,
Actually no, try putting these in the end of setup()
Code:
TCCR2B|=(1<<CS21);
TCCR2B&=~(1<<CS22);
This changes the prescaler of the timer used from 64 to 8 i.e. the PWM frequency should become 8*500Hz == 4kHz.
EDIT: I just tested this briefly and it works as expected.
EDIT2: to make the PWM 32kHz, leave the "TCCR2B|=(1<<CS21);" line out.
EDIT3: ^^is wrong. To get 32kHz use following
Code:
TCCR2B|=(1<<CS20);
TCCR2B&=~(1<<CS22);
Old Mar 13, 2013, 07:24 AM
Joined Mar 2011
Cool!
Thanks That will do 32kHz rocks...
Does it affect anything esle?
Old Mar 13, 2013, 07:37 AM
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Cool!
No, it only affects the RSSI output PWM frequency. (Notice thou that I fixed the 32kHz code)
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx Video Piloting (FPV/RPV) 7 Feb 01, 2013 12:35 PM
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV/RPV - Equipment and Vehicles (FS/W) 1 Jul 11, 2012 12:12 PM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV/RPV - Equipment and Vehicles (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm Video Piloting (FPV/RPV) 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
