Old Feb 05, 2013, 02:55 PM
kha is online now
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by Xnaron View Post
Great! I haven't looked at any pinouts yet. Does this mean that the orange openlrs tx mod will be plug and play telemetry with the 9x/9xr or do we still need to connect a pin? I'm thinking you mean utilize the existing connection but not clear.
thanks,
Brendin
I don't think Orange connected anything to the unused 'antenna' pin on the 5 pin JR connector Haven't really checked that. So I think a slight modification is needed in any case.
kha is online now Find More Posts by kha
Old Feb 05, 2013, 03:09 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Well if following the commonly seen mods for FrSky telemetry in the 9X the 5th pin is for the TX from the radio. So not really what is needed.
It should be 2nd pin, that in the Orange TX is connected to ground.
So better have that in mind in case the radio is already moded in that way for FrSky.
IceWind is offline Find More Posts by IceWind
Old Feb 05, 2013, 04:18 PM
Xnaron is online now
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
My radio isn't modded...at least not yet...but if it would be possible to modify the er9x software to use the pins already connected on the orangetx that would be cool. We could release a openlrs version of the er9x software. I'll do some digging and see if it would even be possible with the existing pin connections.
Xnaron is online now Find More Posts by Xnaron
Old Feb 05, 2013, 05:22 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
You mean the existing pin connections on the radio? If so unfortunately it is not possible. You'll always need to mod the radio to get the telemetry working, the existing two free pins in the radio from stock don't link to the Atmega.
But if you still need to do the mod, you can wire them differently and be able to use the Orange TX straight away.
In mine I'll simply cut the connection to GND from the 2nd pin and link it to the TX. May still need to add some stuff due to the different
voltage levels 3.3v <> 5v between module and radio.
Old Feb 05, 2013, 10:51 PM
fryfrog is online now
Find More Posts by fryfrog
United States, CA, Mountain View
Joined Sep 2010
Originally Posted by CrashMeUp View Post
At the bottom of the arduino window you'll see the progress. When it says "done uploading", you're good to go!
I just wanted to say thanks for your instructions. I've done a little arduino fiddling, but it had been awhile since I'd used the software and my FTDI programmer. Your directions were just the ticket and I was able to programme two sets of the Orange RXs and TXs. They even worked when I was done!
fryfrog is online now Find More Posts by fryfrog
Old Feb 05, 2013, 11:59 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
Glad it helped someone
CrashMeUp is offline Find More Posts by CrashMeUp
Old Feb 06, 2013, 02:09 AM
LiPoSly is offline
Find More Posts by LiPoSly
Joined Aug 2007
Originally Posted by kha View Post
The flytron has schematics on the site.
I'm designing my pcb as full two layer with basically rfm on one side and rest on the other. Im going to make them at iTeadstudio and as the board will fit 50x50mm it will be doable at 10pcs for 9.99 (+shipping). Ill make the board exactly fit the flysky jr box as I have few vacant after removing the flysky stuff.
Turns out that I've been living under a rock for the past few years, who the heck does etching when you can order nicely done PCBs 10 pieces?!?!! For 10 bucks, or am I reading wrong on their page/here. That's really awsome.
LiPoSly is offline Find More Posts by LiPoSly
Old Feb 06, 2013, 02:51 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Yes it is pretty awesome service, the only downside is that it takes few weeks to get the boards, but the quality has always beed perfect.
Here is my current design, not everything is verified atm.
https://github.com/kh4/openLRSngTX
Old Feb 06, 2013, 08:46 AM
i3dm is online now
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
Hello guys,
can anyone advise which FW is recommended for flashing the OrangeRX LRS Tx\Rx ?
i3dm is online now Find More Posts by i3dm
Old Feb 06, 2013, 09:16 AM
HeliShredder is online now
Find More Posts by HeliShredder
United States, MA, Boston
Joined May 2008
I have been following this thread for a while and I think having an open LRS system will be exciting. Nice work kha!
Anyways, one thing I was wondering is why not make new hardware that uses an arduino nano for the mc-pcb? Like that you would already have USB, LEDs, etc and it would make it very easy to build.
HeliShredder is online now Find More Posts by HeliShredder
Old Feb 06, 2013, 10:24 AM
Ernes is offline
Find More Posts by Ernes
Spain
Joined Dec 2010
Hello all
kha, I'm almost finished my plane and I've seen you make some changes in your code. I flashed my tx-rx some weeks ago.
Do you think I have to reflash them again? or there are minor changes.
Thanks a lot
Ernes is offline Find More Posts by Ernes
Old Feb 06, 2013, 10:29 AM
Xnaron's Avatar
Joined Feb 2003
Yeah I got a chance to do some reading and I see what you mean. Ah well have to do a little soldering then.
Old Feb 06, 2013, 10:41 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Any idea on how to setup PWM for use with a Quadrino FC?
If I missed the I tired the plug on pin one and two.
I couldn't get it to work.
I am wondering if I am using the right channel for PWM?
Which channel, I have seen channel 8 or channel 1.
Am I doing it all wrong?
DoctorAudio is offline Find More Posts by DoctorAudio
Old Feb 06, 2013, 10:46 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by Ernes View Post
Hello all
Thanks a lot
They are 'minor' changes unless you want to try out the telemetry (which requires higher baudrate).
Old Feb 06, 2013, 11:21 AM
Ernes is offline
Spain
Joined Dec 2010
Thanks kha, but can you explain me how it works the telemetry? like frsky? when it sounds when the rssi is low for example?
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
