Old Feb 03, 2013, 03:22 AM
kha is online now
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by IceWind View Post
Got all my RFM22 from that store.
Seemingly they dont have the rfm23bp modules which seem to be rather hard to find.
kha is online now Find More Posts by kha
Old Feb 03, 2013, 01:57 PM
LiPoSly is offline
Find More Posts by LiPoSly
Joined Aug 2007
Yep, can't find them anywhere, if I wanted the rfm22b then I would just order from HK and also get the complete circuit board and arduino setup for cheap
I flew again this weekend but had issues completely unrelated to the RX or TX. The OpenLRS seems to work really well, keep on going with the telemetry code Kah
Anyways you don't happen to sit on a bunch of rfm23bs and could sell one to Sweden?
LiPoSly is offline Find More Posts by LiPoSly
Old Feb 03, 2013, 03:50 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Not in EU but...
http://www.goews.com/rfm23bp_433mhz_transceiver
Or from Timecop's shop.
http://abusemark.com/store/index.php...products_id=43
He doesn't seem to have many in stock.
IceWind is offline Find More Posts by IceWind
Old Feb 04, 2013, 01:31 AM
LiPoSly is offline
Joined Aug 2007
Thanks for links, ill give the US store a try...
Old Feb 04, 2013, 01:43 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
I got mine via TimeCop, and that is actually the reason he has some in stock. I can highly recommend getting them from him (it makes sense to grab some naze:s at the same time .
Old Feb 04, 2013, 08:07 AM
LiPoSly is offline
Joined Aug 2007
Cool. I got a pair en-route now.
Im not that much into multi-rotors otherwise I guess the Naze's would make sense .
Anyways, the RFM23B has the same pinout as the 22's right? except that it is slightly longer. (im thinking of hacking one of my OrangeRX with some simple extensions on one side cuz im lazy, but otherwise I'll have to dig out my PCB making equipment again...
Old Feb 04, 2013, 08:26 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Mostly... it seems that rxant/txant pins are swapped. And it is about twice as long.
Old Feb 04, 2013, 09:37 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
What exactly is the function of those pins? Are these signal and ground for the antenna?
msev is offline Find More Posts by msev
Old Feb 04, 2013, 09:56 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Well I have not looked too deep but datasheet states that they need to be set high/low according to tx/rx mode. They are connected to gpio pins of the module and the module is configured to handle that automatically.
Old Feb 04, 2013, 10:54 AM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
Not the RFM most of you are looking for, but interesting none the less for a 100mW Tx/Rx version.
CheckSum is offline Find More Posts by CheckSum
Old Feb 04, 2013, 11:11 AM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
That is a RFM12B which is quite different chip than RFM2x devices as it is basically just modem and does not have the packet handling functionality.
I have to say the OrageRX openLRS RX is quite nice for a general purpose RFM22 + arduino board combo (even thou RFM is not connected to SPI)..
Old Feb 04, 2013, 11:16 AM
CheckSum is offline
CheckSum's Avatar
Joined Jan 2011
^^Gotcha
Knew I was probably missing something
Old Feb 04, 2013, 02:43 PM
kha is online now
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Another RFM23BP source (EU) (7.44€)
http://webshop.ideetron.nl/Webwinkel...7/RFM23BP.html
Be sure to select the 433MHz version if planning to use for openLRS.
Old Feb 04, 2013, 02:56 PM
IceWind is offline
IceWind's Avatar
Joined Feb 2005
Nice find.
Even has the RFM22B-S2. Going to get some to swap the ones in the HK RX's.
Old Feb 04, 2013, 08:43 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
problem solved... first output is rssi not channel 1.
Xnaron is offline Find More Posts by Xnaron
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
