Old Jan 13, 2013, 09:56 PM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
sounds like the wires aren't connected to the right pins
CrashMeUp is offline Find More Posts by CrashMeUp
Old Jan 14, 2013, 04:33 AM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
Got it working on the rx. On the tx I get:
avrdude: Warning: cannot query manufacturer for device: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning.
avrdude: error: could not find USB device "USBasp" with vid=0x16c0 pid=0x5dc
avrdude done. Thank you.
The blue LED is coming on, the chip gets hot, but the volt reg doesn't. But when I plug the module into the transmitter, the volt reg and chip gets hot but there's no response on the LEDs.
UPDATE: I tried using a different programmer, which is telling me the chip signature is 0x000000. It seems that in spite of life shown, something critical is dead.
lobstermash is offline Find More Posts by lobstermash
Old Jan 14, 2013, 09:07 AM
kha is online now
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Or there is short on the board....
kha is online now Find More Posts by kha
Old Jan 14, 2013, 05:33 PM
Joined Jul 2012
Anyone else tried flashing the tx with AVR?
Old Jan 14, 2013, 06:33 PM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Yep, before getting the FTDI I was using the option to upload using a AVR programmer.
IceWind is online now Find More Posts by IceWind
Old Jan 15, 2013, 01:39 AM
Spejlo is offline
Find More Posts by Spejlo
Joined Sep 2011
I did another range test on ground.. stock antennas 3.5km inside car surrounded with buildings and still strong reliable signal..
another test will be with RSSI
Spejlo is offline Find More Posts by Spejlo
Old Jan 15, 2013, 04:03 AM
Ernes is offline
Find More Posts by Ernes
Spain
Joined Dec 2010
Which firmware tested, please?
Ernes is offline Find More Posts by Ernes
Old Jan 16, 2013, 12:08 AM
Spejlo is offline
Joined Sep 2011
I used thUndeadMOD3.6.. flashed RX as TX and integrated it in my old walkera radio
Old Jan 16, 2013, 01:55 AM
lukelifts is offline
Find More Posts by lukelifts
Canada, BC, Vancouver
Joined May 2012
Looks like I too have a bad setup, I have successfully uploaded both the stock openlrs latest version, and thUndeadMOD4 firmwares. Both attempts have gotten me no farther than 150m before it cuts out.
Looked over the soldering job on both Tx and Rx, and tested connections with ohm meter, everything seems ok.
Any ideas for further troubleshooting?
lukelifts is offline Find More Posts by lukelifts
Old Jan 16, 2013, 05:47 AM
Spejlo is offline
Joined Sep 2011
I've tested MOD4 and frequency hopping is strange.. MOD3.6 is better
but 150m is terrible
if you have oscilloscope try to measure output.. mine gives 20.7dBm (20dBm is in chip specification)
I have another pair of HK LRS... if I have time today I flash them and test.
Old Jan 16, 2013, 06:24 AM
IceWind's Avatar
Joined Feb 2005
Some have reported problems with the soldering work.
Ideal would be to have someone with a working kit and mix-match TX/RX to see which one is the culprit and help debugging.
Old Jan 16, 2013, 07:18 AM
mlbraga82 is offline
Find More Posts by mlbraga82
Joined Aug 2010
They interfere in 1.2 GHz video links?
mlbraga82 is offline Find More Posts by mlbraga82
Old Jan 16, 2013, 08:03 AM
IceWind's Avatar
Joined Feb 2005
A fellow pilot tried his kit last weekend with a 1.2Ghz kit and it actually interfered the other way around.
With the 1.2Ghz vTX enabled the range was greatly decreased to just a couple of meters, with it off he could go way way further out.
He was trying this in a car with FPV, the RX and the vTX were split apart like 25cm. Maybe in another platform it behaves differently.
Old Jan 16, 2013, 08:35 AM
Joined May 2012
Thanks for the advice on trying to test with the oscope Spejlo, however my only oscope is an antique and doesn't really have a scale haha. But if I were to test it would I leave the antenna on?
I suppose this is karma for not buying from flytron, hk is starting to get to me with their cheapo stuff.
Old Jan 16, 2013, 10:06 AM
liorz055 is offline
Find More Posts by liorz055
Joined Aug 2009
Hi Spejlo , can you please explain how did you connect the Rx to the transmitter in order that the RX will serve as TX (from wiring point of view).
I guess you connected the +&- and signal to the appropriate pins in the walkera transmitter, but where did you connect it to the TX , channel 1?
can you also elaborate on the binding procedure and the thUndeadMOD3.6 flashing (did you used older version of arduino?)
Lior
liorz055 is offline Find More Posts by liorz055
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
