Old Jan 03, 2013, 02:31 AM
JAS3D is offline
Find More Posts by JAS3D
Lowand Fast
JAS3D's Avatar
Australia, QLD, Gold Coast
Joined May 2012
Originally Posted by Cesco View Post
Sorry ... what i said about using the usbasp programmer for arduino i was completely wrong. It is quite simple to do so. Steps:
Remove the jumper from your HK usbasp like in the picture attached. This jumper sends 5V to the target, we dont want that. Use a normal 5V power supply for the orange opnlrs.
In the arduino sketch, select the usbasp programmer like in screenshot attached.
Connect the usbasp cable to the orange openlrs like in the picture attached.
Use the "upload with programmer" function of arduino like in screenshot attached.
I did test, and it works flawlessly here. You may get a "could not set SCK error", that is normal. Happy programming !
For some reason I still cant get ''serial port' to light up in the menu.
JAS3D is offline Find More Posts by JAS3D
Old Jan 03, 2013, 03:57 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Thanks for sharing, I wasn't aware of that feature.
Seems it was introduced in the IDE 1.0.x. I'll give it a try.
(Still getting the FTDI as it powers the target board and allows debugging/configuration.)
IceWind is online now Find More Posts by IceWind
Old Jan 03, 2013, 05:30 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Originally Posted by henkster View Post
I'm not sure what you're saying, or trying to say here, or even why you would believe this?
The modules work straight out of the box. I've been testing mine over the past couple of weeks with great sucess in stock form. Although I fly in a pretty unpopulated area it's nice to know that:
1. I have full control over the unit, pick my own frequencies according to the lcoal radio landscape, and that I can fly safely with other users with a quick drop into the code. That's not a huge issue, unless you're scared of a bit of tweaking.
2. That despite having an established user base (as it's openLRS remember) and declining enthusiasm on some forums, now HK has released a low-entry-cost version that there's ongoing development and new interest in improving an excellent codebase.
You just have to take it for what it is. It's not a high powered LRS, with the price tag to match. It's extraordinary good value for a hugely flexible 100mW solution.
Try googling "openlrs" for some examples of videos
I was more interested in seeing some videos with this system from hk
I understand its not plug and play but thought by now after all your guys testing some of you would be air born with videos
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Jan 03, 2013, 06:51 AM
18t is offline
18t
Find More Posts by 18t
18t
Joined Mar 2010
ya true, get your s*** together here people. The last 5 or 6 pages of this thread since the units shipped haven't been filled with people talking about using it or anything.
18t is offline Find More Posts by 18t
Old Jan 03, 2013, 07:05 AM
David22 is offline
Joined Apr 2008
I just want to see video of someone flying with the hk system
I find it interesting how people have trouble setting it up, it seems like not fun todo at all
It is surprising no one posts videos mentioning this hk system and how it works
Beit well or not
Anyone have links to fpv videos using this system from hk
Who has flown furthest with stock set up
Old Jan 03, 2013, 08:37 AM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
Don't forget it's winter in most places. People tinker a lot, fly much less. You can just get one and make a video yourself if you're in so much of a hurry
Kilrah is online now Find More Posts by Kilrah
Old Jan 03, 2013, 11:35 AM
Mieciu is offline
Find More Posts by Mieciu
Poland
Joined Feb 2011
Originally Posted by kha View Post
AVR cable is not needed for flashin, instead a 'normal 3v3 FTDI' i.e. USB to TTL serial adapter is needed.
I personally use CP2102 based ones.
Could you please write some kind of how-to with pictures (connection details to both orange tx and rx)?
Are you using this kind of device?
thanks
Mieciu is offline Find More Posts by Mieciu
Old Jan 03, 2013, 02:23 PM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Yes, the CP2102 on the picture is the same I use.
Connections on CP2102
GND (brown), RXD (green), TXD (yellow), 3V3 (red), DTR (orange)
I made the wires on single 1x6 connector (you can make one from two servo connectors by gluing them together). In order (empty) (brown) (red) (green) (yellow) (orange), this fits directly on the serial header on the modules.
On RX
On TX
kha is offline Find More Posts by kha
Old Jan 03, 2013, 04:04 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
My usbto232 device had no dtr connection. I guess thats my problem Doh!
bracky72 is offline Find More Posts by bracky72
Old Jan 03, 2013, 04:18 PM
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
You can manage without DTR.
Just keep the 3V3 wire off and connect it just when the Arduino says "Uploading..." on the staus (between code and log). It may take a few tries.
i.e. press "Upload" button, prepare to connect, and when "compiling sketch" changes to "Uploading..." connect the wire.
Old Jan 04, 2013, 07:14 AM
Spejlo is offline
Find More Posts by Spejlo
Joined Sep 2011
I do not understand some people here.. yesterday i have received HK OLRS and have no problem with it at all..
flashed FW in 15 minutes witch my own freq. and ground test with stock antennas is over 2km.. and i bet it goes a little further but i cant go there
Spejlo is offline Find More Posts by Spejlo
Old Jan 04, 2013, 07:47 AM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
I've ordered another programmer from ebay to see if that's my problem. I've spent way to much time fooling with what I have now.
Old Jan 04, 2013, 10:56 AM
MarcoTheRipper is offline
Find More Posts by MarcoTheRipper
MarcoTheRipper's Avatar
Italy, Lazio, Rome
Joined Jul 2012
What programmer do you have right now? Maybe you can get DTR from the board
MarcoTheRipper is offline Find More Posts by MarcoTheRipper
Old Jan 04, 2013, 11:28 AM
IceWind's Avatar
Joined Feb 2005
Did you tried and do the same test with the stock FW?
Old Jan 04, 2013, 01:16 PM
Nick_P is offline
Find More Posts by Nick_P
United States, MO, De Soto
Joined May 2003
Why would anyone? I thought the stock firmware was garbage? That would be like buying a 9x and running stock firmware. There is no point when open9x is 1000 times better.
Nick_P is offline Find More Posts by Nick_P
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
