Old Jan 02, 2013, 12:35 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
I had time to mess with mine today. First of all I have never used arduino or anything like that before. It took me about an hour to figure out how it all worked but I am now up to speed. I flashed mine using openLRSng and then bound the rx. I then set the failsafe so my servo would move to one extreme when signal lost. With the stock antennas I could get about 200m before failsafe started kicking in. I'll try again later with some other antennas I have. My servo moved smooth so with a little more testing I would be willing to fly with it.
bracky72 is offline Find More Posts by bracky72
Old Jan 02, 2013, 12:38 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
200 meters????? That is awful, hopefully it's just the stock antennas that are the problem
gooby is offline Find More Posts by gooby
Old Jan 02, 2013, 12:44 PM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
I am hopeful that in the air with proper antennas it will go a few km. It will be fun to try.
Old Jan 02, 2013, 12:48 PM
Cesco is offline
Find More Posts by Cesco
Cesco's Avatar
Joined Dec 2007
bracky72,
if you get 200m with openlrsng set to 100mw tx power something is WRONG.
I get more (280m) with stock antennas and 1.6mw, that is 1.6% of your power.
Cesco is offline Find More Posts by Cesco
Old Jan 02, 2013, 12:52 PM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
I'll set it to 1.6mw and see how far I get. It is possible I got one of the antenna mixed up with a 2.4 antenna. They look similar. More testing...
Old Jan 02, 2013, 01:19 PM
Cesco is offline
Cesco's Avatar
Joined Dec 2007
That would explain it. See the 2.4g are "reverse sma" while 433 are "normal sma".
A 2.4g antenna on a 433 device will have a ultrashitty performance, and a r-sma connector on a sma socket wont make contact at all ... means same as no antenna at all.
Would be nice of you to check it. Look into the connector, r-sma and sma are different.
Old Jan 02, 2013, 01:36 PM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
Actually I realized I am still not programming it right so it must still be on stock firmware. The code compiles fine and it begins uploading but I get a message about avrdude not syncing. I'll figure it out.
Old Jan 02, 2013, 02:56 PM
RoboSerg is offline
Find More Posts by RoboSerg
RoboSerg's Avatar
Joined Sep 2011
Soo I dont know, this product from HK seems like a garbage judging from the posts. People are getting < 1 km with 433 mhz LRS. Really? I can buy FrSky 2.4G and get 1.5-2.5 km of range w/o any hassle on stock antennas.
With this product I thought HK could really deliver a low priced LRS saystem than can do 5-10 km of range w/o a hassle. Even with stock antennas @100mW it should do MORE then 2.4G from FrSky.
There is smth wrong with it, I hope I am wrong. I am yet to see a post from someone who has > 4km range with stock antennas. Otherwise its pointless.
RoboSerg is offline Find More Posts by RoboSerg
Old Jan 02, 2013, 03:13 PM
kha is online now
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Well... for a real range test.
Someone with RVOSD G5, rig up a dual (ppm) rx system with frsky 2.4GHz and openLRS running parallel. And have some flights videoed.
I would have the gear but my flying skills wont allow me to do that safely (nor the weather would permit).
kha is online now Find More Posts by kha
Old Jan 02, 2013, 04:23 PM
Cesco is offline
Cesco's Avatar
Joined Dec 2007
Originally Posted by RoboSerg View Post
I hope I am wrong
You are.
People who actually understand / read the posts have a big advantage over you. Please stop calling products garbage because they do not meet your "plug and fly" approach to the hobby. There are people able and liking to go way deeper into the workings than you are, please stop insulting them because you dont understand.
Old Jan 02, 2013, 04:35 PM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
No need to feed the trolls. Their input into working out a 'new' product (yeah, I know it's not really a new product) is nil.
I've just got a flight controller set up as an autopilot as of yesterday. Weather permitting I will test out max range with the comfort of RTH on failsafe. I think this will outperform an unboosted FrSky system easily with stock antennas. The biggest problem in my mind is orientational diversity. I'd feel a lot more comfortable with 2 antennas...
lobstermash is offline Find More Posts by lobstermash
Old Jan 02, 2013, 04:42 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Lobster which FC do you use?
msev is offline Find More Posts by msev
Old Jan 02, 2013, 06:22 PM
Joined Jul 2012
I bought the HK MultiWii Pro with GPS and have been fiddling with it to get ArduplaneNG working. Was a momentous task getting it to work and I'm ecstatic to have got it going.
Old Jan 02, 2013, 07:09 PM
henkster is offline
Find More Posts by henkster
United States, NV, Verdi-Mogul
Joined Mar 2012
Originally Posted by IceWind View Post
@henkster, what range did you got and when you say stock you mean not uploading any new version or same version of the software to the RX or TX?
I've only been taking it out gently so far, the weather's improving after being really hideous recently. So far it's been quite happy at just over 1500m but as I've not really tested everything I'm not going to drop a plane from the sky in pushing things. Ground testing with LOS it went over 2.5km comfortably, but right now I can get any further LOS due to snow cover. I reckon that 5Km should be easily achievable with careful setup, possibly with stock antennae. As soon as you start factoring in decent and/or directional antennae then the range will increase.
Yep, this definitely concerns me too. I have the FrSky system, which left my FlySky system in the dust for range. The diversity definitely makes me a bit bolder in pushing things.
henkster is offline Find More Posts by henkster
Old Jan 02, 2013, 07:41 PM
Joined Jul 2012
And the fact that FrSky beeps at you when your signal's cutting out. But I don't know what the issue is with mine, even with the patch pointed directly at the plane I get beeps at 1km and angry beeps at 1.5km... Hence why I thought I'd give this fella a go
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
