Old Dec 27, 2012, 06:13 PM
18t is offline
18t
Find More Posts by 18t
18t
Joined Mar 2010
I got mine working with openlrsng, I'll update if I ever figure out why I couldn't bind. The only obvious change is physical location. I had the TX in randomize after holding the button until it beeped loudly, from there I plugged in the rx and had instant bind lights.
oh and btw, the link seemed quick and smooth to me so far by just observing the servo. Yet to test ppm but I trust that it will be just fine.
18t is offline Find More Posts by 18t
Old Dec 27, 2012, 06:14 PM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Originally Posted by lobstermash View Post
I don't have one... They can be programmed with the AVR programmer, can't they? It'll be quicker for me to wait for my buddy to get back than order an FTDI...
Yes AVR programmer will do too.
kha is offline Find More Posts by kha
Old Dec 27, 2012, 06:48 PM
Pookyjuice is online now
Find More Posts by Pookyjuice
Joined Oct 2011
After seeing 6 pages of people fiddling with firmware flashes and fiddling with open- source software mods and not single person actaully Flying with this "Plug and Play" system I feel it's not premature to call this HK attempt a FAIL.
This thread seems to have devolved into people hacking about to convince themselves that they didn't waste their hard-earned money. I'm sure if any of you were able to prove me wrong, you'd do so...
Pookyjuice is online now Find More Posts by Pookyjuice
Old Dec 27, 2012, 06:50 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Erm, I remember more than one post form people doing test flights on it, but at it's current state it is a mislabeled system more than a fail. I definitely wouldn't feel safe when all units are shipped to fly on the same channel.
acetech09 is offline Find More Posts by acetech09
Old Dec 27, 2012, 09:35 PM
lobstermash is offline
Find More Posts by lobstermash
Joined Jul 2012
Troll much? How about reading the thread again... I've flown mine.
It's not as if this system is unknown. Although it comes with OrangeRx stickers, it's OpenLRS, which has been around a few years. The stock firmware is the same stock firmware that the original product is shipped with.
lobstermash is offline Find More Posts by lobstermash
Old Dec 27, 2012, 09:36 PM
yarg is offline
Find More Posts by yarg
United States, IN, Greenwood
Joined Oct 2011
HK clearly states on the product page:
*Note: The setup and use of Open LRS requires computer programming skills and basic Arduino experience. This is not a "plug and play" system. See the attached document under the "Files" tab for resources on programming info, firmware downloads and more.
Where did you get the idea it was plug and play?
yarg is offline Find More Posts by yarg
Old Dec 27, 2012, 10:21 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Well, isn't it plug and play but pre-loaded with outdated/bad firmware?
gooby is offline Find More Posts by gooby
Old Dec 27, 2012, 11:29 PM
acetech09's Avatar
Joined Apr 2012
It is plug and play.
Plug in your FTDI and play with firmware.
Old Dec 28, 2012, 01:05 AM
Joined Oct 2011
My apologies, I think must have woken up (at work) pissed off and hungry when I posted that. I was nonplussed at the amount of work this system seems to take to set up, and that rant was definitely coming from a POV of ignorance.
I suppose I wanted to believe that a UHF setup that actually fits into my current budget would be easy to set up and affordable. There's no such thing as a free lunch, I realize. An ultra cheap n00b-friendly LRS would probably result in many lost planes in the short term.
Old Dec 28, 2012, 01:08 AM
18t is offline
18t
18t
Joined Mar 2010
I also had TX solder issue, I was having very intermittent success and I read the post below so I took a look inside. The connector was actually pretty good but my rfm22b radio had 3-5 joints nearest to the three pin bank that ranged from needing touch-up to basically not soldered. No problem now, I'm actually quite happy with the system for the price. Kha's firmware is great, thanks.
Here it is flying in ppm mode. I know that it obv. doesn't show any range capability but I'll get to checking rssi when I get to it, not expecting much difference from orig. openlrs performance. The shakiness is from the pilot not the radio it doesn't help that im standing in a few inches of snow in 20deg F middle of the night. http://www.youtube.com/watch?v=BZBB8...PReQSg&index=1
Originally Posted by Cesco View Post
I got my orange 433 today, and it works. I could not resist to install the openlrsNG firmware on it, and that works too. Quite happy so far.
I did have a manufacturing fault on the TX module. Hope this is an isolated event. The connector was not properly soldered, and the ppm pin did not make frim contact. Luckily after some wiggling i did see it.
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Well HK / OrangeRX should have used some R&D resources to work on the firmware, I have maybe used 15-20 hours on mine and I could call it plug and play already .
But, no they did not use any R&D resources apart from minor rework on the PCB layout and shipped with the very first firmware they found. With this level of competence I'm start to wonder what kind of shite their other products firmwares are .
Old Dec 28, 2012, 01:35 AM
Joined Jul 2012
Generally poor - they use what their suppliers give them (see the G-OSD firmware and stock Flysky 9x firmware as prime examples). The only place I've seen them improve firmware is the alleged changes to ER9x for the 9XR. Hopefully start of a brave new world for HK...? I doubt it. But they're consistently improving. I'm happy to be able to have my hands on this module and technology at a price I can afford.
Joined Jul 2012
Very grateful for your work on this firmware I should add, Kha....
Old Dec 28, 2012, 04:38 AM
Friman is offline
Find More Posts by Friman
Joined Jul 2011
Hi everyone.
Does any of the versions available is using more than 3 frequencies hopping? It seems a bit problematic to me... The eLeReS costs only 25$ more for tx+rx and uses 16 frequencies hopping as far as I know... Also supprt antenna tracker... I'm trying to make up my mind wiether to get the hk's product or eLeReS.. The only advantage I can see for the hk's is that it open source based, so the software might improve. Just don't know if the frequencies hopping issue is depend on the software or hardware?
Friman is offline Find More Posts by Friman
Old Dec 28, 2012, 04:42 AM
IceWind is online now
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Did more tried this kit?
I haven't been able because of the bad weather but yesterday a friend while trying lost total control after ~30mts... and that is not a good sign.
IceWind is online now Find More Posts by IceWind
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
