Old Dec 21, 2012, 12:10 AM
liorz055 is offline
Find More Posts by liorz055
Joined Aug 2009
Originally Posted by Cesco View Post
I got my orange 433 today, and it works. I could not resist to install the openlrsNG firmware on it, and that works too. Quite happy so far.
The modules have the arduino bootloader and a custom version of openlrs installed. The ftdi serial programmer SHOULD be the 3.3V type not the usual 5V type. I did use the 5V type, but you should not since the rf module will fry sooner or later.
Range test not done yet. The original antenna doesent look convincing.
I did have a manufacturing fault on the TX module. Hope this is an isolated event. The connector was not properly soldered, and the ppm pin did not make frim contact. Luckily after some wiggling i did see it.
Thanks for the info, are they any new updates???
liorz055 is offline Find More Posts by liorz055
Old Dec 21, 2012, 12:44 AM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
I did a small mod on mine for flashing.
kha is offline Find More Posts by kha
Old Dec 21, 2012, 12:52 AM
tignmeg is offline
Find More Posts by tignmeg
Registered Adict
tignmeg's Avatar
Australia, WA, Drummond Cove
Joined Jun 2012
LOL....Ya gotta wonder why that wasn't done out of the factory eh
tignmeg is offline Find More Posts by tignmeg
Old Dec 21, 2012, 12:59 AM
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Maybe they will do v2 with better antenna and flasher slot
Old Dec 21, 2012, 02:53 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
LOL I was wondering about the FTDI connection and seeing that pic answered it
I guess this one didn't took 6 years to be designed.
IceWind is offline Find More Posts by IceWind
Old Dec 21, 2012, 01:12 PM
Dennis Frie is online now
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Not any surprise, that they haven't changed anything from the original OpenLRS.
Dennis Frie is online now Find More Posts by Dennis Frie
Old Dec 22, 2012, 06:16 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
They finally got these back in stock. Going to wait awhile more until they release a freebie and place my order then
Koo is offline Find More Posts by Koo
Old Dec 23, 2012, 05:28 AM
pavn is offline
Find More Posts by pavn
pavn's Avatar
Czech Republic, Olomouc
Joined Sep 2010
Did they have in stock also transmitter?
OrangeRx Open LRS 433MHz TX Module (JR/Turnigy compatible)
http://www.hobbyking.com/hobbyking/s...095&aff=388598
I see it BK out of stock currently.
I placed order 2 weeks ago already.
pavn is offline Find More Posts by pavn
Old Dec 23, 2012, 06:44 AM
AleG is offline
Find More Posts by AleG
AleG's Avatar
Bangkok
Joined Oct 2007
I bought a set to test it, but I haven't managed to make it work yet, I have to install Arduino 0.22, it seems using Arduino 1.0 for programming doesn't work.
I'm interested in using this for multicopters, that way I can use RangeLink for planes and OpenLRS for multicopters, the OpenLRS receiver is lighter, cheaper and range is not a problem.
AleG is offline Find More Posts by AleG
Old Dec 23, 2012, 07:48 AM
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Try my OpenLRSng firmware. It has been made for arduino 1.x.
Old Dec 23, 2012, 10:03 AM
simplyfly is offline
Find More Posts by simplyfly
go ahead and try
Canada, ON, Maynooth
Joined Nov 2011
Yes please, where do I get the FW?
simplyfly is offline Find More Posts by simplyfly
Old Dec 23, 2012, 10:20 AM
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
It is in github, just google for openlrsng.
https://github.com/kh4/openLRSng
Old Dec 23, 2012, 09:26 PM
18t is offline
18t
Find More Posts by 18t
18t
Joined Mar 2010
I'm having difficulty trying to establish a link using any of the 3 firmwares so I believe it must be some stupid mistake on my part that I haven't thought of. If anyone has any suggestions that would be great, I've tried quite a few different things now.
What board types should be chosen in thundead?
18t is offline Find More Posts by 18t
Old Dec 23, 2012, 11:00 PM
AleG is offline
AleG's Avatar
Bangkok
Joined Oct 2007
Thank you, I'll give it a try.
Old Dec 24, 2012, 02:34 AM
kha is offline
kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
For thundead you select the M2 TX and RX. You should note that the markkings on oRx are off in this case.
For openLRSng I added some output on serial on RX startup which should help analyse trouble.
With OpenLRSng the binding mode on tx is signaled by tx emitting short 'clicks at around 5Hz'.
Then power on RX having the PC connected and Arduino Serial monitor open at 115200 baud. This should show info at bound time.
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
