Old Dec 13, 2012, 02:52 AM
Cesco is offline
Find More Posts by Cesco
Cesco's Avatar
Joined Dec 2007
Originally Posted by kha View Post
drop the frame rate even more.
I did get your code to have a look.
I do not think about dropping framerate or channels, but about not transfering data that has not changed. Most of the channels wont change at all, so we do not need to transfer them every 20ms. Obviously the the TX needs to select the channels and send an additional mapping indicator to the RX.
A 20ms 4 byte message could consist of:
8 bit chan X
8 bit chan Y
4 bit X mapping
4 bit Y mapping
8 bit checksum
where x-mapping says in which of the 16 channels the X data has to go in the receiver.
btw could you store a windows exe for rfm22calc?
Cesco is offline Find More Posts by Cesco
Old Dec 13, 2012, 03:54 AM
Rownald is offline
Find More Posts by Rownald
Joined Dec 2011
Tried that too, but if you lose a couple of frames it won't work, so every channel will need updates every now and then increasing bandwidth again.
Also added problem, if you try to move everything at once there will be a huge delay.
Preamble and header still make up a lot of data, so won't be able to really drop speed.
Increased sensitivity is in the noise floor, so no effect will be seen. And if it isn't in the noise floor it will be only 1-2 dB increase which is very marginal for the added inconveniences..
Rownald is offline Find More Posts by Rownald
Old Dec 13, 2012, 04:01 AM
Cesco is offline
Cesco's Avatar
Joined Dec 2007
Based on my HAM experience i totally disagree on that.
Have a look at WSJT or similar developments, which work WAY below the noise floor. In other words the "noise floor" depends on BW (bandwidth).
Less speed = less BW = less noise.
Old Dec 13, 2012, 04:08 AM
Rownald is offline
Joined Dec 2011
Based on practical experience with OpenLRS I disagree with you, while it may still be possible to receive a signal that is in the noise floor the RFM22B seems to do this not so well compared to the software that you named. During range testing I lost signal when the signal strength got to around noise floor.
Old Dec 13, 2012, 02:56 PM
bingo17 is offline
Find More Posts by bingo17
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
Also keep in mind noise floor changes with area, day of time, etc..
What dbm level is noise floor in your area or what is your baseline rather?
bingo17 is offline Find More Posts by bingo17
Old Dec 13, 2012, 03:04 PM
Rownald is offline
Joined Dec 2011
My noisefloor is around -105 to -100 dBm
Old Dec 13, 2012, 03:27 PM
bingo17 is offline
bingo17's Avatar
Auckland, NZ
Joined Sep 2009
Wow that is low, 90 - 95 here and sometimes as high as 85dbm
regards
Old Dec 14, 2012, 01:54 AM
Cesco is offline
Cesco's Avatar
Joined Dec 2007
in anticipation of my orange module i did order this 0.5W module, not pin compatible to original and VCC is higher.
http://www.goodluckbuy.com/2500m-hig...le-500mw-.html
Then i did try to get a price from hoperf for the 1W module. Hoperf does not seem to be a retailer, this might get complicated, and 10 minimum order.
http://www.hoperf.com/rf/fsk/RFM23BP.htm
Old Dec 14, 2012, 03:03 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Try to reach out to this guys: http://rf-store.com/
They don't have it currently listed but you never know.
That's where I got my RFM22B, they sell any quantity and the prices are reasonable.
Only thing that might be expensive is the shipping.
IceWind is offline Find More Posts by IceWind
Old Dec 14, 2012, 03:43 AM
fmkit is offline
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
received GLB 0.5w module without any documentation,
got it working but never used because of high heat even in low power mode
RFM23BP 1w module works very well, I have some 20pc on hand, if you want to experiment get one $25 shipped, add $3 for PCB
fmkit is offline Find More Posts by fmkit
Old Dec 14, 2012, 04:54 AM
RoboSerg is offline
Find More Posts by RoboSerg
RoboSerg's Avatar
Joined Sep 2011
So anyone did a range check with stock antennas ?
RoboSerg is offline Find More Posts by RoboSerg
Old Dec 14, 2012, 09:16 AM
Nick_P is offline
Find More Posts by Nick_P
United States, MO, De Soto
Joined May 2003
I have not received mine yet. I refuse to pay 30 bucks for shipping so its on the slow 3.99 shipping boat.
Nick_P is offline Find More Posts by Nick_P
Old Dec 14, 2012, 08:12 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Ugh, once again Hobbyking is pathetic when it comes to keeping products in stock.
gooby is offline Find More Posts by gooby
Old Dec 15, 2012, 12:45 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
This UHF system does not look to be plug and play at all
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Dec 15, 2012, 01:07 AM
kha is offline
kha
Find More Posts by kha
kha
openLRSng haxor
Finland, Espoo
Joined Mar 2011
Yes it is not plug and play but there is a few firmwares that make it very close. All you need is a 3v3 ftdi or any other usb to ttl serial adapter to prigram it.
I'm workking on one and I hope I have the binding stuff done on Tuesday after that is in it will behave pretty much like any of the shelf system.
kha is offline Find More Posts by kha
Wanted Anyone got a good 433mhz UHF RX Antenna? wamdue FPV Equipment (FS/W) 3 Feb 24, 2014 02:19 PM
Question 'Sander' 1/4 wave monopole - correct length for 433MHz UHF? Kahnx FPV Equipment 11 Dec 23, 2013 09:19 AM
For Sale Chainlink UHF system + few matching Rx's i3dm FPV Equipment (FS/W) 0 Apr 22, 2012 06:58 AM
Discussion stiff antenna for 433Mhz UHF Rx ? i3dm FPV Talk 14 Feb 17, 2012 01:25 PM
Sold HK "Orange" Satellite for HK "Orange" Rx rikybob Aircraft - General - Radio Equipment (FS/W) 1 Jan 29, 2011 03:19 PM
