Old Nov 27, 2012, 04:42 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Build Log
Flying Wing Revisited
This model was a committee design, on this forum, 3 years ago.
http://www.rcgroups.com/forums/member.php?u=35157
It made a number of successful flights but ran into problems with the prop. The 8x4 moved the airplane but was way too small for the MicroDan motor. Any larger prop destroyed itself by sucking up sand and rocks on take off attempts. The MicroDan needs a 10x6 or 11x7. That really eats rocks! I could never get the gear long enough for take off and the larger props made hand launch dangerous - call me chicken.
Also, this model was built around the credit card size Olympus FE 360 camera. A beautiful camera, but not one that is suited to off-field UAV operation. It was destroyed early by a few grains of sand around the lens barrel. For the last couple of years, this project has resided on the airplane pile in the pump house.
The other day I spotted a Panasonic Lumix Tough camera on ebay. It's not as small as the FE 360 but the lens is in the upper right edge of the camera face and remains flush when the camera is in use. It's a 16MP digital and it's sealed - good in 30 ft of water without a case and intended for use in sand - wow!
Mounting the camera upside down places the lens window at the bottom of the wing section. That would fit an oblique mount within the root section.
So, I bought the Lumix, rescued the airplane for the pump house, carved a lens port out of the underside and built a camera mount into the rear section. Oh yeah, I removed the landing gear and pusher mount and moved the motor to the front, where it belongs.
The result is:
Span: 52 inches
Root Chord: 12.25
Tip Chord: 8.5 inches
Area: 4 sq ft
AUW: 45 ounces
Wing Loading: 11.25 oz/sq ft
MicroDan motor ~280 Watts
68 Watts per sq ft
100 Watts per pound
That should hand launch nicely.
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Nov 27, 2012, 05:10 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Or now you could fit a longer landing gear and use the 10 inch props.
BMatthews is offline Find More Posts by BMatthews
Old Nov 27, 2012, 05:51 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Landing gear takes up too much structure and increases drag. Hand launch should make everything easier.
Tom
Old Nov 28, 2012, 07:35 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Forget any fixed or retract landing gear, and go for a take-off dolly if a take-off is required.
It also save weight on having attached U/C.
The dolly could even be bungee assisted if required.
eflightray is offline Find More Posts by eflightray
Old Nov 28, 2012, 10:59 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Tom, I've used to termination several point-n-shoot cameras. Either totally destroyed in a "spirited arrival", or dust in the lens system giving a permanent "lens error" notification when powering up.
I've found it worthwhile for the AP cameras to get the insurance on them at purchase.
Gotten at least one new one after an incident involving smiting Mother Earth.
The new Canon A2300 with 16 mpix makes superb photos! Beats everything I have used up to now.
Just picked up a GoPro Hero3, to try the time lapse stuff, eliminating any need to trigger a servo to trigger the shutter.
Systems failure on takeoff...I've tossed the receiver... 2nd time for it to fail.
O8E-112612-TakeoffRollOverCrash (1 min 4 sec)
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 28, 2012, 01:43 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Sparky,
Wild video!
I gotta stop buying cameras! I love my Canon A650 but it's way too heavy. I have a Canon S95 that is very nice - CHDK helps.
We should fly Friday. I'll let you know how the Lumix works out.
Tom
Old Nov 29, 2012, 11:46 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
Stop buying cameras!!!!
What's got into you?
Here's what I've been flying recently...
The 808s are very good for AP video.
Not so good for photos.
The Canon A2300 gives 16 mpx!
The GoPRo with the interval ability removes the need for an onboard shutter trigger.
Old Nov 29, 2012, 04:47 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Sparky, I was laughing and cringing at the same time. Sorry....
,,,,well, it WAS funny sounding to hear all the crunching and see the wobbles... so I guess I'm not really sorry for laughing....
A year or so ago I got myself a Fuji that is water, dust and sand proof that has the internal zoom. I really gotta get it into a model.
Old Nov 29, 2012, 04:52 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Ready for first flight
Ready for first flights tomorrow at the club field. If all goes well we'll try some flights in our study area on Saturday afternoon.
The installation worked out better than expected. There is plenty of room to slide the Lipos into the box spars. The leads plug into a connector block. They can be loaded and plugged in on the bench. The Dean's connector allows a single connection at the field.
The Autopilot wire runs are cleaner than usual. Looks pretty tight. We'll see tomorrow.
Tom
Old Nov 29, 2012, 05:47 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Bruce
I've had crashes with on-board videos working, but with all of those, the camera stopped, usually due to being broken!
This is the first one where they kept on running, even after being "thrown clear" by the impact. The nose camera was buried in the impact crater, had to search the countryside for the other two.
The GoPro has a safe container, but it's way big. The camera itself is really small outside the box.
Old Nov 29, 2012, 10:08 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
With the plethora of small, light and tough keychain and lipstick style digital cameras we can likely expect more post crash moments that examine "The Silence" as we hear the ever loudening crunching of the pilot's steps towards the scene....
Old Nov 29, 2012, 11:38 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
To say nothing of Lipos and Outrunners... looking back almost 10 years here..
I did this delta using Tom's basic design. Speed 600 and heavy-as-lead Nicads!
I have a problem seeing which point is the front when a delta gets way out there.
Old Nov 30, 2012, 10:28 AM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
My Trusty Sony Bloggie
Gents,
With all due respect to those of you who have been doing RC models for much longer than I have, and who have probably shot more stills and vid from aloft than I have, I humbly submit that what I've seen on this thread does not impress me. For purposes of shooting stills or video, you are trying to re-invent the wheel.
I pondered doing a scratch-build for an aerial camera plane, but decided it was much easier to modify a humble GWS Slow Stick. And cheap, too. You can guess what I used for power and radio.
For the camera I chose a Sony Bloggie I got several years ago. It has a swivel lens head. Using Velcro and straps under the Slow Stick boom, I can mount it to point forward, backward, or to either side (no gimbal and servo arrangement).
I shoot 720p at 60 FPS. The aerial shot is a frame extracted from the last vid of the season. It ain't shabby, unlike the murky stuff shot with the keychain cams. I've had two, and both tapped out before I could even mount them on an airplane.
Not being a good pilot, most of my landings are more like sudden arrivals. In grass, fortunately. The Bloggie survives, and I await spring time for another shooting session.
BTW, my house is the one in the center of the pic, with the tan roof.
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Nov 30, 2012, 11:26 AM
Ascended Master
Palmdale, CA
Joined Oct 2000
I've used the Yard Stick, the built-up wing appealing more to me.
And then I bulked out the fuselage to hold the camera inside, on a tilting mount for looking sideways to straight down.
Old Nov 30, 2012, 11:44 AM
Joined Feb 2000
Sparky Paul,
That's a nice camera mount. I could do that. I also appreciate the whole fuselage, which better protects the camera from... However, it restricts the panorama if the cam is swiveled fully left or right. So the boom fuse is better suited, ISTM, IMHO.
My set-up uses 3S and weighs 24 ounces, ready-to-launch. What's yours?
Jim R.
Mini-HowTo BajiWing: Flying Wing using "Armin Wing" technique templton89 Foamies (Scratchbuilt) 235 Sep 20, 2013 03:59 PM
Discussion Flying Flying Wing From Flying Wing TjW Flying Wings 5 May 19, 2012 09:52 AM
Discussion Reusing glider wings to make flying wing Goldentaco Sailplane Talk 4 Apr 02, 2012 09:44 PM
Discussion Full scale flying compared to RC flying, revisited Ickarusmelt Beginner Training Area (Aircraft-Electric) 4 Mar 01, 2008 02:08 AM
