USA, NJ, Milford
Joined Jul 2006
it's interesting that you were a jerk to me but didn't think to give an opinion to the guy who gave the less than helpful response to me.
i've used foam and Dura Bond for a mold but the foam gave out too easily under the heat of the plastic. |
I try not to get worked up about unhelpful responses, because the forum is completely full of them and sooner or later, someone will turn up with a more helpful response. I get irritated by arrogant or inflammatory posts because they're completely unnecessary and just make the forum a less pleasant place to be. I realize I'm guilty as well, but in this case it seemed like the thing to do.
Anyway, when I say foam I'm not thinking of pink foam or Styrofoam - that stuff loses structure with heat and doesn't work for more than maybe one use. After all, it's basically the same material you're forming over it. I'm thinking of spray insulating foam sealant - the aerosol cans you get at hardware stores, like Great Stuff. That stuff is polyurethane, not polystyrene. It sets rock-hard and doesn't react much to heat. The only trick is getting it to release from your mold in the first place. Depending on how tidy the mold is, that could be helped with plastic wrap or paste wax. |
USA, NJ, Milford
Joined Jul 2006
ok, so the useless posts aside, the spray foam will last for how many pulls? I'm using paste wax and the green spray release stuff (can't think of the name at the moment) to prep the mold. spray foam to make the shell with Dura-Bond to fill in behind it might make a better molding surface than the Dura Bond alone.
THanks for the help. |
I've never had to make more than two of something, so I'm really not sure how long the spray foam will last. It's more likely to die from rough handling than from any part of the forming process, so if you treat it well it should hold up for a while. If you haven't encountered the stuff before, you might be surprised - it's very similar to dried Gorilla Glue. It cures to a very hard foam with a smooth surface made of very fine bubbles, with a core of much bigger bubbles.
Be careful; a little bit goes a long way, and if you seal it into a cavity it'll just break its container. |
Joined Jul 2011
I have used Hornady "One Shot" case lube as a form release agent. It works surprisingly well, and it's little pricey but takes a very small amount on dense surface. Probably not as well on something like an open cell foam, though.
Hope this helps. Bill |
try dry lining adhesive and washing up liquid
i form my plugs from foam pull one and then pour a mix of adhesive in to make a more stable plug Quote:
![]() (sorry about that)for something to use to copy a canopy. Are you using the wash liquid to get a more 'plastic' mix(an old dodge when mixing cement mortar) Stuart |
Afton VA
Joined Sep 2002
Foam
http://www.rcgroups.com/forums/showthread.php?t=1779168 |
| Thread Tools | |
| Mini-HowTo Thermal forming, Vacuum forming methods & devices. | Freddie B | Foamies (Scratchbuilt) | 81 | Yesterday 11:35 PM |
| Sold Vacuum forming machine local sale only - Grass Valley, California | seaphoto | Non R/C Items (FS/W) | 1 | Dec 31, 2012 11:27 PM |
| Question Vacuum forming | Jerome Morris | Dock Talk | 23 | Nov 21, 2012 10:10 AM |
| Wanted Vacuum forming | MrRCFlying | Aircraft - Electric - Airplanes (FS/W) | 6 | Oct 03, 2012 06:17 AM |
| Question Making casts of vacuum formed parts? | payne9999 | Scale Electric Planes | 32 | Jul 11, 2012 09:13 PM |
