Nov 28, 2012, 10:14 PM
Steinbach, MB, Canada
Joined Nov 2004
My suggestion is to see if you can get your hands on some very small electronic shrink tubing. Place the tubing over the wire in the area where you wish to glue and try very hard not to get any ca into either end of the shrink tubing. Very small shrink tubing would be flexible enough to bend around any Z bend and you will not need a whole lot, depending on damaged area, maybe 3/4 of an inch. You would not need to shrink if you get one small enough.
Hope this works for you.
Sackie
