Old Nov 27, 2012, 03:42 PM
kjur is offline
Find More Posts by kjur
Joined Mar 2012
Question
Ailerons and flaps on 6 channels
Hi.
I'll be getting my new plane soon and I will be using a AR6210 Reciever.
I am fairly certain that the the servos on both wings are pointing toward the fuselage or the tips. So using a Y harness for the ailerons is good but for the flaps one of the servos will move in the opposite direction.
My question is, what would be the best way to solve this? I remember reading somewhere that someone did not recommend to use a reversing y harness, do you know why?
I don't really want to remove the servo (It's an RR model) and cut out a new hole to put it on the other side. But I guess it is the cheapest and best way..
It's not possible to use the Aux and Gear channel for the flap servos right? I'm not sure what the Gear channel is used for.
Thank you in advance!
kjur is offline Find More Posts by kjur
Old Nov 27, 2012, 03:58 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
ailerons should be facing the wing tips, flaps should be facing the same direction. I take it you haven't got the plane? Just wait then to be certain
erikc641 is offline Find More Posts by erikc641
Old Nov 27, 2012, 04:14 PM
kjur is offline
Joined Mar 2012
I found some pictures and the aileron servos are facing the tips and the flaps are facing the tips as well.
Old Nov 27, 2012, 04:28 PM
tacx is online now
Find More Posts by tacx
tacx's Avatar
United States, MI, Washington
Joined Apr 2009
It dosn't matter which way the aileron servo arms are facing (either to the wing tips or to the fuslage) as long as they both face out or both face in.
You should be able to use the spare channels for your flaps.
As, erkc641 has said. Wait until you get the plane.
tacx is online now Find More Posts by tacx
Old Nov 27, 2012, 04:51 PM
kjur is offline
Joined Mar 2012
Okay, well I am 99% sure now that both the aileron servos and the flap servos are facing the wing tips. So I should be able to use "Gear" And "AUX1" for the flaps?
Old Nov 28, 2012, 12:20 PM
kjur is offline
Joined Mar 2012
I recieved the plane today and the aileron and flap servos are facing the wing tips as I thought.
Before I buy a reverser I want to make sure that I can't use the fifth "Gear" channel for one of the servos and Aux for the other?
Could I program my DX6i so that the Gear channel reverse one of the servos? I don't understand how this works I'm afraid.. Would someone please explain?
Thanks.
Old Nov 28, 2012, 06:54 PM
tacx is online now
tacx's Avatar
Joined Apr 2009
Before you buy anything check to make sure the servos are not opposite travel from the manufacturer. You didn't say what plane you have so no one knows.
I would hook the flap servos to a standard Y harnes and make sure of their direction. If that proves to be wrong then you can just get a reversing Y or try connecting the servos to the gear and aux 1 channels.
If you connect them into two seperate channels you will need to refer to your TX manual to find out how they need to be programmed.
If someone has a DX6i maybe they can chime in and advise you.
Old Nov 29, 2012, 01:33 PM
bloviationator is offline
Find More Posts by bloviationator
United States, UT, American Fork
Joined Oct 2012
I don't have an answer, but I want to go along for the ride on this topic.
I have the same transmitter and have wanted to do flaps as well. My problem is I don't have a plane with dedicated flaps - in other words, I want to use the ailerons as flaps and still retain the aileron function. Flaperons?
If I had separate flaps with dedicated servos then I think it would be fairly simple to set things up. My current configuration is a Y harness with both aileron servers plugged into the "ail" port on the receiver. Does that match your situation? What I can't figure out is if I need to run one of the aileron servers to the aux port then do some fancy mixing and re-routing in the transmitter to still maintain aileron function but introduce matching flap action when that switch is flipped.
There are a few videos on Youtube that come pretty close to answering my questions but I guess I'm a little too thick to catch on.
bloviationator is offline Find More Posts by bloviationator
Old Nov 29, 2012, 03:54 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I don't have a DX6i in front of me but basically for flaperons you select "Flaperon" as Wing Type. The left aileron goes in Aux 1 then IIRC the left aileron will be listed as the Flap Servo in the reversing and end point menus. The Flap Menu then lets you set the amount of deflection for either flaperons OR Spoilerons + for flaps - for spoilerons, there will be a mix for elevator in the same menu.
Can't help with dedicated flap servos. Spektrum does not recommend using reversing Y's but I have one in my FunCub, some of the servos twitch but that may have nothing to do with the Y, I bought it used. On another plane I opened up one servo and reversed it but that involves soldering.
600Bob is offline Find More Posts by 600Bob
Old Dec 04, 2012, 01:17 AM
erikc641 is offline
Joined Jul 2012
Yes you will need to have one in to the aileron and one in to the aux channel. Then mix them but just be sure not to overdrive the aileron portion when the flaps are activated.
Old Dec 04, 2012, 03:30 AM
Watts cooking is offline
Find More Posts by Watts cooking
Watts cooking's Avatar
United States, CA, Corona
Joined Oct 2012
Simply hook your ailerons into the Y and plug into your rx, that covers your ailerons. As for flaps you an cut out the pocket and flip the servo like you said (not the best choice due to cutting up your new plane) and connect both flap servos to Y and plug in to rx. The best option is to reverse your servo if you have the know how to re solder the internal wiring of servo. It's extremely easy and there are tutorials on YouTube that will show you how. You just swap the two wires that go to servo motor and where the 3 wires come into servo you swap the outside two leaving the middle in place and there you have it reversed servo no cutting or repositioning the servo. No special mixing or anything.
Watts cooking is offline Find More Posts by Watts cooking
Old Dec 06, 2012, 08:33 PM
erikc641 is offline
Joined Jul 2012
For the dx6i, it is the dual aileron wing type
Old Dec 06, 2012, 11:51 PM
600Bob is offline
Joined Aug 2011
^ Yes, it's under the Wing Tail Mix menu, that is what I couldn't remember.
Idea Aileron/Flap facing on bagged wings target Composites Fabrication 25 Mar 21, 2013 12:52 PM
Question Swap rudder over to aileron channel on DX7s craig01 Beginner Training Area (Aircraft-Electric) 9 Mar 20, 2012 08:28 AM
Mixing ailerons to flaps on Optic 6 charlie tasto Hitec/Multiplex USA 0 Feb 08, 2005 07:58 PM
