Old Nov 27, 2012, 01:23 PM
Malcom2820 is offline
Find More Posts by Malcom2820
United Kingdom, England, Birkenhead
Joined Nov 2012
Question
My servo is broken :-(
My Angell Airbus was never the same again after sharing a rather intimate moment with a tree a few weeks ago (DOH!). That's OK though because I fancied having a go at making something so the gubbins are now in an rc boat. I noticed though, that the servo was a bit hit and miss while I was putting the boat together. Perhaps that explains why the tree failed to get out of the way. I put it together anyway to try it out but the servo has finally given up. I see that replacement servos come with three wires, but the one with the Angell Airbus has two.
My questions are these; am I right in assuming that only two wires are required for power, the third being for communication, meaning that the circuit board from the Angell gives or takes power to or from the servo therefore removing the need for communication? If that is the case can I overcome the problem by just not using the communication wire? And If so is it correct to assume that the red and black wires are for power and the third wire whatever colour it might be is for communication?
Thanks for taking the time to help a newbie.
Malcom2820 is offline Find More Posts by Malcom2820
Old Nov 27, 2012, 07:54 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
No. It sounds like what you have is some basic type of bang-bang actuator rather than an actual servo. They're common in simple RC toys where proportional control isn't required, and they do that job pretty well.
Trying to use a real servo simply won't work because there's no PWM signal available to drive it. The red and black wires ARE for power, but the third wire tells the servo when to move and where to go. If you just give it power with no instructions, it might not do anything at all. It might also go to one endpoint and stop, or it might go to an endpoint and shred its own gears trying to keep moving. It will certainly not give you any kind of controllable reaction and, assuming your actuator worked in both directions, one direction on the stick will simply fry the servo's brain rather than make it move at all.
You could probably ditch the stock actuator from your plane and build your own simple magnet/coil actuator, but that might be a little more involved than you're looking to get.
Piece is offline Find More Posts by Piece
Old Nov 28, 2012, 04:04 PM
Joined Nov 2012
That sounds interesting, is it as complicated as it seems? I get the impression that it might not be something for people with no clue. (like me)
Old Nov 28, 2012, 09:47 PM
jkettu is online now
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
See this post: http://www.rcgroups.com/forums/showp...74&postcount=3
It is not difficult once you know what you are supposed to do: just wind some wire into a loop and put a magnet inside it.
Which brings up another point: an actuator is such a mechanically simple device that there isn't much to go wrong. You could first check if there are any broken wires or other mechanical damage. If you have a multimeter, you could disconnect the actuator and measure the output between those two wires - it should be zero when the controller stick is centered, some positive voltage for one direction and a negative voltage for the other direction.
jkettu is online now Find More Posts by jkettu
Old Nov 29, 2012, 02:58 PM
Joined Nov 2012
My friend did that test we reckon the motor was broke.
Discussion Can I turn my broken 4 blade prop into a 2 blade prop? DontMessWithTX Power Systems 10 Jun 27, 2012 01:52 PM
Discussion is my charger broken? empty 8400mah battery chraged with 300mah in 66minutes..?!?!?! oterpoter Batteries and Chargers 3 Jun 06, 2012 09:13 PM
Discussion Broken switches on my A9... gyrokiteguy Radios 10 Feb 27, 2012 01:19 PM
Question What can i expect to hear when i send my broken servos in? nitrothugg Radios 2 Nov 10, 2009 09:45 AM
