Old Nov 27, 2012, 11:59 AM
lotsofcats is offline
Find More Posts by lotsofcats
Joined Jul 2012
Shumate F14 Tomcat wing swing set up question.
Hi
I have just got to the stage of adjusting the wing sweep angles prior to sticking the assembly on to the fuselage. The problem I have is getting sufficient swing angle when using the Flap switch on my Spectrum 6i Tx. I can get sufficient angular movement if I use the Gear switch with the gain set to max 140% but using the flap switch set to max I only can get about 50% of that required. I also need to mix some up elev in when the wing is swept back, to compensate for the nose down pitching moment but this function does not appear to be possible if I use the Gear switch. Anyone got any ideas from their own experiences with this model design?
Tony
lotsofcats is offline Find More Posts by lotsofcats
Discussion Should E-Flite make their next EDF an F14 Tomcat?? Quandry Electric Ducted Fan Jet Talk 168 Apr 27, 2013 02:48 PM
For Sale Green Air Designs F14 Tomcat w/swing wings raceradam Aircraft - Electric - Airplanes (FS/W) 0 May 31, 2012 07:37 PM
Sold SOLD - 6MMFLYRC F-14 Tomcat W/Swing Wing Jet Foam Kit - $45.00 Shipped and Insured. GTMAXX Aircraft - Electric - Airplanes (FS/W) 5 Feb 28, 2012 08:39 PM
Discussion f14 swing wing servo question shuttlefishing Foamies (Scratchbuilt) 3 Nov 15, 2011 05:15 PM
For Sale F14 Tomcat Ultimate Scale (Swing wing span75cm-110cm) flighttosky Aircraft - Electric - Airplanes (FS/W) 7 Apr 05, 2006 09:55 AM
