Old Nov 27, 2012, 09:10 AM
demiluk is offline
Find More Posts by demiluk
Switzerland, ZH, Zurich
Joined Oct 2011
Old (27MHz) HZ Super Cub to DX6i: which is the easiest (less time consuming) mod?
Hi,
I would like to change the receiver of my 27MHz HZ super cub in order to exploit the receiver I found in the package of my new DX6i transmitter (that is a spektrum AR6200 DSM2).
Which are the ESC (and eventually motors?) that fits with the less modification efforts?
Thank you in advance for your advices,
Luca.
demiluk is offline Find More Posts by demiluk
Old Nov 27, 2012, 10:07 AM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
strongly recommend you check out: http://www.rcgroups.com/forums/showthread.php?t=1338787
you can use a 30A esc and a 480 brushless - i would recommend e-flite. also, lots of options on the url i just gave you.
cmdl is online now Find More Posts by cmdl
Old Nov 27, 2012, 10:44 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I bolted a Park 450 right on mine - don't think I even had to drill any holes. You only need an 18-amp Castle Thunderbird for that. You have to replace both servos too, I used HS-55 servos, they fit right in.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 27, 2012, 12:32 PM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Jasmine, why do you need to replace both servos? I currently have an extra Parkzone 450 motor that came out of my T-28 Trojan and have a 30 amp e-flight ESC that I can use to convert my SC to brushless. Do you use the gearbox, or direct drive for the prop?
chucksolo69 is offline Find More Posts by chucksolo69
Old Nov 27, 2012, 12:50 PM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
i believe the stock servos in the super cub are 5 wire servos. they won't plug into a standard 3 wire receiver.
hoghead5150 is offline Find More Posts by hoghead5150
Old Nov 27, 2012, 01:25 PM
Rocket Programmer
Joined Jul 2007
Yeah that's the reason. It has two servos so you need two new ones that work with the standard receiver.
Old Nov 27, 2012, 01:27 PM
Joined Apr 2011
Ah, got it, I never really noticed that.
Rocket Programmer
Joined Jul 2007
Pretty sure the Trojan uses a 480 motor? Direct drive is the only way to go.
I think a 480 is too much power, therefore extra weight you don't need. It can be flown that way, but it will need tail weight to balance and it won't be as floaty - maybe a good thing.
Old Nov 27, 2012, 03:03 PM
cmdl is online now
cmdl's Avatar
Joined Jan 2012
yep. pz t-28 stock is 480.
Old Nov 27, 2012, 03:22 PM
demiluk is offline
Joined Oct 2011
But does this motor fit the Super Cub stock gearbox?
Old Nov 27, 2012, 03:44 PM
Rocket Programmer
Joined Jul 2007
No, you will remove the gear box entirely. It's only needed for high speed motors and we're talking about low speed direct drive motors.
Old Nov 28, 2012, 12:09 PM
demiluk is offline
Joined Oct 2011
Thank you for the info :-)
Just another question: what are the hs-55 servos? (Maybe silly question, but i'm pretty new to the hobby!)
Old Nov 28, 2012, 12:15 PM
Rocket Programmer
Joined Jul 2007
It's a Hitec Servo... any servo around this size will work...
http://www.servodatabase.com/servo/hitec/hs-55
Discussion Took HZ Super Cub out for 1st time today! Mark88fan Beginner Training Area (Aircraft-Electric) 3 Jul 23, 2012 11:16 AM
Help! Old HZ super cub RTF radios - evidently not so good sirocelot Beginner Training Area (Aircraft-Electric) 4 May 08, 2012 06:53 PM
Question HZ mini super cub tail wheel mod microflitedude Parkflyers 2 Mar 04, 2010 02:37 PM
Discussion Modded HZ Super Cub kylewoody Parkflyers 1 Jul 05, 2009 07:02 PM
Discussion hz mini super cub aileron mod micro_doc Foamies (Kits) 2 Jun 15, 2009 03:53 PM
