servo/esc plug substitute (and cheap too)
If you already know about this, please bear with me. I've searched the forums and can't find anyone asking this, but here's an answer anyhow. Having been in the hobby for almost 30 years, I've had several different brands of radio. The servo plugs are similar, but different enough that one mfg's servo wouldn't fit another's receiver. It turns out that they are all based on a standard plug called a pcb or breadboard connector with 0.1" (2.54mm) pin spacing. Sound familiar? Not coincidence that your esc's plug right onto the pins on your fc board. The various R/C manufacturers took this and modified the connector shell so it would only plug in one way to maintain correct polarity. And they are all different. Futaba G, Futaba J, Hitec, JR, Airtronics, they all have their own connector. This also means that you pay a premium for these proprietary connectors. Even the aftermarket replacements from HK are 1.99 for 10 pairs of shells and pins to fill them. At the lhs they can be 10.00 or more. The micro receivers we use often don't have a one way socket, just bare pins, so we have to be careful to plug the wires in with correct polarity anyway. This makes the proprietary plug unnecessary.
Here are a few examples of cheaper alternatives: 3"Single pin jumper wires, 50 for $10.95. 5 each of 10 colors: http://www.pololu.com/catalog/category/66 Female crimp pins, 100 for $5.95: http://www.pololu.com/catalog/product/1930 Male crimp pins, 100 for $7.95: http://www.pololu.com/catalog/product/1931 Housings (shells) from 1x1 pin to 2x16 pins. 1x3 are 25 pcs for 79 cents! http://www.pololu.com/catalog/category/70 I don't know about you, but 50 3" single pin fc/rx wires for $10.95 is a pretty good deal to me. Get a crimper and some 26 awg wire and you can make custom cables with as many pins as you need. And what did you pay for that last Y cable you bought? $10.00? |
Tallahassee, FL
Joined Feb 2009
Hansen Hobbys is a good place to pick up that kind of thing also:
http://www.hansenhobbies.com/product...rvoconnectors/ |
| Thread Tools | |
| Help! Align 70 Amp ESC supplying too much voltage to servos | MinfangDuan | 3D Electric Heli Flying | 3 | Sep 27, 2012 10:16 AM |
| Sold Team LOSI Micro T ESC, Receiver, Servo and Motor, cheap | spbalaj | Cars - Accessories (FS/W) | 4 | Sep 05, 2012 01:13 PM |
| Help! ESC plug too big for AR6200... Please Help! (Pictures) | CB Flyer | Radios | 5 | Jan 17, 2011 06:34 PM |
| Discussion Any experience with Airtronics 54444 MG servo - a cheap substitute for HS85MG ?. | ktoey | Slope | 0 | Dec 18, 2007 11:40 PM |
| Question With generic ESC BEC's, is using too few servos as bad as too many? | Accu157 | Power Systems | 4 | Mar 25, 2007 10:22 PM |
