Old Dec 04, 2012, 06:51 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Nice looking engines there, nothing too special on my end but I have taken a shine to the Blink plan... looks quirky and quick which is a good combo in my books!
Seeing as I have two good engines I will probably do an own-design for the second, most likely small thin fuse and high aspect ratio wings for speed coupled with a long streamlined tail to help keep the drag down.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Dec 09, 2012, 07:36 AM
Paul Bonati is offline
Find More Posts by Paul Bonati
Paul Bonati's Avatar
Buenos Aires, Argentina
Joined Aug 2007
Originally Posted by Andrew0820 View Post
Try here, post #43:
http://www.rcuniverse.com/forum/m_10..._2/key_/tm.htm
A GLH will probably be faster than the Hummer, especially if you drop the percentage on the airfoil.
If you're really adventurous, the attached pdf's will set you free.
Sorry, guys I īve a question. The BLINK PLAN. has it have a rudder? Is it the triangle part? Does anybody have a photo of the finished model ?(Sorry for my bad english)
Cheers, Paul.
Paul Bonati is offline Find More Posts by Paul Bonati
Old Dec 09, 2012, 09:15 AM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
This is not mine.
Here ya go:
Andrew0820 is offline Find More Posts by Andrew0820
Old Dec 10, 2012, 10:28 AM
Joined Aug 2007
Thanks a lot Andrew.
Cheers, Paul.
Old Dec 10, 2012, 11:38 AM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Was just checking a mag. from 1967 in RC Modeler and came across this. I think the reedie may be a bit underpowered, but will try to load it anyway.
aspeed is online now Find More Posts by aspeed
Old Dec 10, 2012, 01:07 PM
Western KY
Joined Sep 2003
Here's a copy of the Pipsqueek plans cleaned up a bit.
Old Dec 10, 2012, 04:23 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Looks good guys, although built around somewhat dated components. I do see that its using a NACA 0015 airfoil though which is a good thing!
Could be a good candidate for modern 9g servos and 4g receivers I reckon... lighten her right up and make a speed demon out of her
- boingk
EDIT: Decided to build the Blink this morning. Time 9:30am... lets get her done by lunchtime!
Old Dec 10, 2012, 04:35 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Thinnest airfoils are fastest SD 008? perhaps.
Flat plate/sheet ones, albeit thin, give serious drag at even miniscule Alpha.
Those only look fast :-)
Bare is offline Find More Posts by Bare
Old Dec 10, 2012, 07:16 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
If you're looking for thin airfoils, here you go.....
http://www.outerzone.co.uk/plan_details.asp?ID=1184
aeronca52 is offline Find More Posts by aeronca52
Old Dec 10, 2012, 10:40 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Here we go guys, looking alright so far?
- boingk
Old Dec 11, 2012, 08:07 AM
Western KY
Joined Sep 2003
Looks great!!!!
If you're going to really horse it around, you might want to add spar webs in the inner bay -- gives a lot of structural support with hardly any weight penalty. Depending on what you choose, the covering will also really stiffen it up.
Old Dec 11, 2012, 09:07 AM
Chap is offline
Find More Posts by Chap
Chap's Avatar
United States
Joined Apr 2004
Bede 5
Here is my next build. The article says it's fast and agile, we'll see. I just like the way it looks. Very low parts count, solid balsa wing, should be a quick build
Chap
Chap is offline Find More Posts by Chap
Old Dec 11, 2012, 07:18 PM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Thanks Andrew! The tail is only propped up in position for that photo but you get the idea. One question though - I've been removing the rea rventuri setup of my non-tanked Cox engines for a while now, and simply leaving a 1/4" air channel top and bottom. Doesn't seem to hurt them and makes mounting easy. Do you think this would be an issue?
Chap - As a pilot I'd love to fly a BD5... awesome reputation as very well performing aircraft. I believe one of the few reasons there aren't more of them is simply because the engine they were designed around went out of production! Would love to see a scale model zipping around. Let us know how you go.
On control for the Blink, I'll be using a 6ch OrangeRx receiver with 2 x 9g HK15168 servos for control. Can't wait to get her covered and maidened!
Cheers - boingk
Old Dec 11, 2012, 08:57 PM
Bare is offline
Canada
Joined Nov 2000
Cheers - boingk
Careful what you wish for.. these were Proven Dawg airplanes
Frightening Stall characteristics, only partially cured by a fresh Aerofoil redesign. Most survivors remain as half built 'kits' despite a seemingly endless succession of Owners.
Dave Blum posted Very Good ( in design, construction and Flying ability).. plans for a Scale BD5 of suitable size (electric tho)
Still available.. If you hunt around a bit.
Old Dec 12, 2012, 09:39 AM
Western KY
Joined Sep 2003
boingk --
That tube is there just to give folks a means of choking the engine and pulling fuel up to the spray bar. It works the same as holding your finger over the carb intake on crank induction engines. In some cases, you may actually find a slight performance increase by removing it.
There are two things to consider. After removing the choke tube, make sure the mounting screws don't bottom out in the case before tightening up -- the ears on the tube are almost 1/16" thick and a lot of the Surestart cases are not drilled and tapped deeply enough to accomodate the additional screw length. Secondly, the needle is quite long and will be unsupported. You might want to slip a length of fuel tubing over the needle to soften harmonic vibration or, better yet, cut it back and recap it. Because that needle has a step on it just above the threads, another option is to remove the spring, slip a small flat washer over the threaded portion so that it sits flush against the step, then add a section of tubing over the threaded portion. The washer will keep the tubing compressed against the top of the NV, stop any air leaks and help support the lower end for vibration control.
The OrangeRX is really a great buy. They're available in the US warehouse for $6.19 --- really hard to beat that price for a DSM2 RX.
Question Looking for Small, Simple, and Fast Plans/Build Less Than 16oz/454g roo_ster Foamies (Scratchbuilt) 0 Mar 30, 2012 09:39 PM
Question 1/2a slow flying plane plans (.020/.049) glaerox 1/2A Planes 18 Feb 13, 2010 01:12 PM
Help! need plans from net for shure start 049 with or without rc ring or baby bee 049 ZEROSKIN76 1/2A Planes 18 May 20, 2009 02:36 PM
Discussion Plans For A *FAST* Plane Made Of EPS AND/OR Flat Foam? critterhunter Foamies (Scratchbuilt) 9 Jan 17, 2007 10:07 PM
Discussion Very Fast Plans for a Depron Shockflyer Type Plane 3dricky Electric Plane Talk 2 Jan 26, 2006 01:07 PM
