Old Nov 26, 2012, 06:02 PM
bigmd is offline
Find More Posts by bigmd
Joined Apr 2004
kyosho adj steering question
anyone have a pic of this?put it in today but are the bearings supposed to sit flush?i drilled out the top hole so the bearing is inside the hole.the instructions are terrible.
bigmd is offline Find More Posts by bigmd
Old Nov 27, 2012, 11:49 AM
grymg is offline
Find More Posts by grymg
RCMCC.tripod.com
grymg's Avatar
Fremont, CA
Joined Sep 2003
Yup, the bearings are supposed to replace the bushings originally on the triple clamps. The only reason for the upper hole is for the steering shaft to stick through.
grymg is offline Find More Posts by grymg
Old Nov 28, 2012, 05:49 AM
bigmd is offline
Joined Apr 2004
hmmm is this made for an MK1 also?thats what i was trying to install in.
Old Nov 28, 2012, 05:18 PM
bigmd is offline
Joined Apr 2004
i drilled out the top clamp and pressed the bearing in wondering if im supposed to do same for bottom.keep in mind im using the old kyosho oil forks
Old Nov 29, 2012, 12:42 AM
kegresse is offline
Find More Posts by kegresse
SF, CA
Joined Apr 2006
Hi Bigmd, just need to drill a hole for the top - don't touch the bottom.
I hope the photos will help. Other option parts - cast steering head,
aluminium gear box.
Have fun with your bike!
Kegresse
kegresse is offline Find More Posts by kegresse
Old Nov 29, 2012, 04:44 PM
bigmd is offline
Joined Apr 2004
kegresse pics helped.did your bottom triple clamp have a hole big enough for the bottom bearing?
Old Nov 29, 2012, 04:52 PM
bigmd is offline
Joined Apr 2004
or does a bearing not go there?
Old Nov 29, 2012, 10:00 PM
kegresse is offline
SF, CA
Joined Apr 2006
Hi bigmd,
no changes for the bottom part. Look at gyrmg's reply again -
"Yup, the bearings are supposed to replace the bushings originally on the triple clamps. The only reason for the upper hole is for the steering shaft to stick through."
Old Nov 30, 2012, 11:26 AM
grymg is offline
RCMCC.tripod.com
grymg's Avatar
Fremont, CA
Joined Sep 2003
yeah mk1 triples on the bottom weren't made for bearings.
doesn't matter though, I've found that the bearings don't really matter in terms of steering performance.
Found Kyosho Mini Inferno Steering Servo FourDollaRacing Cars - Cars and Parts (FS/W) 1 Nov 24, 2015 08:02 PM
Discussion Sub trim adj. needs end travel adj. too? hidaven Electric Plane Talk 12 Jan 04, 2011 08:10 PM
Discussion Basic Tx swash mix / travel adj question greper Mini Helis 3 Apr 15, 2009 04:26 AM
Discussion question about setting up Kyosho HOR steering us_matrix Motorcycles 4 Jun 21, 2006 12:48 PM
Question direct steering on kyosho 1/8 mkI questions MichaelConnally Motorcycles 3 Sep 19, 2005 07:26 PM
