The Netherlands
Joined Nov 2009
If you coil a wire (core or not) you are creating an electromagnet. A straight wire however is not a coil, and does not create a traditional bipolar magnetic field when carrying a current, but still a magnetic field does exert a force on that conductor if a current passes through it. Of course a coreless motor is a brushed motor, because the static field magnet has North and South magnetic poles. Without brushes the wire being forced to the left when passing one side of the fieldmagnet, would be experiencing a counterforce when passing the other side of the magnet. So you still need a form of commutation. In the pictures in post #2 you can clearly see that the copper wires are all straightened and parallel in the area where they are subject to the magnetic field of the stator magnet. Brgds, Bert |
Joined Apr 2010
In the rotor shown in post 2 I am only able to see the outermost layer of windings.
The text for the patent says: FIG. 1 is an axial section showing a motor which is typical of the prior art. FIG. 2 is a perspective view of the rotor used in the construction of FIG. 1. FIGS. 3 and 4 show respectively, in a "developed" view and in a schematically perspective view, the nature of the winding used in the present invention. FIGS. 5 and 6 are corresponding views showing an alternate form of winding. FIG. 7 illustrates, in perspective, a rotor and associated brushes constructed in accordance with the invention. FIG. 8 shows a greatly enlarged fragment of the end edge engaged by the brushes. FIG. 9 is a fragmentary section looking along line 9--9 in FIG. 8 and showing the use of wear-resistant plating. FIG. 10 is an axial section taken through a motor constructed in accordance with the invention. To me at least, image 6 in the patent (the alternate form of winding) looks a lot like this - ![]() And that looks a lot like the motor used in the V911and even the MSR, except I can't see the underlying layers in the MSR image.
Canada, BC, Vancouver
Joined Oct 2011
Here's a cross section diagram of how I think a coreless motor works after interpreting what you said: ![]() We know F = I x B F - force I - current B - magnetic field TL;DR: We have 2/3 variables, when I and B are 90 degs from each other, it produces a force which turns the motor. We have the current and we have the magnetic field, so it produces a force orthogonal to to the mag field and current when the direction of the magnetic field is perpendicular to the current. There has to be some type of logic as to when a particular wire should be powered, but (if I'm not wrong) that's the theory behind a coreless motor. Corrections are more than welcomed! |
Chicago 'burbs
Joined May 2006
You can look at this stuff in many different ways.
On the lowest level, you have the fundamental Lorentz Force. However you can look at it also as the interaction of two magnetic fields that are trying to align themselves in an anti-parallel (e.g N-S, S-N) fashion. Any moving current generates a magnetic field around the wire carrying the current. The vector sum of all these little current carrying segments produce the equivalent of a larger magnetic field. The advantage of a coreless motor is less inertia to movement---it can accelerate faster. Also since there is no core (=iron type material) that is being magnetized by the current, you have no hysteresis or eddy current losses. However a core is like a magnifier of the field generated by the windings. In other words you get a stronger magnetic field with less current. So a coreless motor is likely to have more resistive losses than an equivalent core motor that is making the same torque. So you win and you lose some! |
Joined Oct 2011
| Thread Tools | |
| Discussion How to fix the coil on a Minicp RX(WOWS SILiCONE DOES NOT WoRK!) | mescalinedream | Micro Helis | 2 | Feb 09, 2013 07:28 PM |
| Discussion how does this hacker MM work | ror1 | Power Systems | 12 | Apr 01, 2012 02:34 AM |
| Discussion How exactly does the CAM work? | ravisurdhar | Altitude Limited Electric Soaring (ALES) | 23 | Mar 31, 2012 06:09 PM |
| Help! How Does RCexl test Kit work? | Fokker DII | Engines | 6 | Mar 31, 2012 03:45 PM |
| Discussion How does it work? | SteveM | Radios | 10 | Mar 09, 2012 06:06 AM |
