Old Nov 25, 2012, 07:55 PM
plane58 is offline
Find More Posts by plane58
plane58's Avatar
United States, MI
Joined Aug 2012
Remove yellow tint from white ABS plastic
Hello, I just bought an old Traxxas Villain 1508 boat in very good shape.
The boat sat for a very long time and has a yellow tint on the top of the boat,
the sides and bottom are nice and white.
I've done a search and was told to use baking soda, white vinegar, whitening
toothpast and many others. Does anyone here a good idea on how to remove the yellow, or should I just paint it white and be done with it...thanks
plane58 is offline Find More Posts by plane58
Old Nov 25, 2012, 08:38 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
I think you are going to find that the best and most likely only solution is to paint everything you can see white. I have an older ABS hull that I painted white almost 20 years ago and even with the paint and rarely in direct sunlight she still yellowed.
Kcal is offline Find More Posts by Kcal
Old Nov 25, 2012, 09:45 PM
Predreadnut is offline
Find More Posts by Predreadnut
Predreadnut's Avatar
Joined Jul 2007
Maybe the yellow stuff is nicotine?,maybe look up how to remove that
Predreadnut is offline Find More Posts by Predreadnut
Old Nov 26, 2012, 12:30 AM
desron48 is offline
Find More Posts by desron48
ADM. 48TH FLEET
oxnard ca.
Joined Jul 2007
could very well be....@plane58.....if you have windex rub a little on the plastic and it smears...could very well be nicotine in my shop iv'e got a couple of bare hulls they yellowed as well....i smoke and so does my shop assistant....
joe
desron48 is offline Find More Posts by desron48
Old Nov 26, 2012, 07:29 AM
plane58 is offline
plane58's Avatar
United States, MI
Joined Aug 2012
I took everything out of the the hull and gave it a good washing with dish soap,
I then used a product called Meguiar's marine wax and all that did was make the yellow shine better. Do all ABS plastics yellow with age?
Old Nov 26, 2012, 09:45 AM
Steve Bad is offline
Find More Posts by Steve Bad
"Take the Cannollis"
Steve Bad's Avatar
Lake Martin ALABAMA
Joined Feb 2006
I would try using hydrogen peroxide.
(First, use alcohol to remove the wax you just put on.)
Steve Bad is offline Find More Posts by Steve Bad
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
ABS turns yellow when it is exposed to sunlight or fluorescent lighting.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 26, 2012, 10:16 AM
cdog46 is offline
Find More Posts by cdog46
Southern Maine USA
Joined Apr 2006
get hydrogen peroxide from beauty supply store
It is 4X stronger than drug store kind. it won't take as much time as shown in this article http://www.howtocleanstuff.net/how-t...rABSplastic%29
cdog46 is offline Find More Posts by cdog46
Old Nov 26, 2012, 11:16 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
The yellowing is basically a suntan that goes through the structure of the plastic. Like Kcal says, paint it.
mfr02 is offline Find More Posts by mfr02
Old Nov 26, 2012, 05:10 PM
plane58 is offline
plane58's Avatar
United States, MI
Joined Aug 2012
This is what the boat looks like.
Old Nov 26, 2012, 07:10 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
Paint it. Even if you just paint it white.
The yellowing is from exposure to Ultra Violet sunlight. Like someone else mentioned earlier, long term exposure to fluorescent lighting will do it too. Fluorescent lights emit a small amount of UV. Black lights emit a lot more UV.
My wife's Kyosho Jet Arrow also originally white ABS is yellowed on the top surface. It'll get painted this year or next. Depends on how long she runs it before she hates the yellowing.
Apismelifera is offline Find More Posts by Apismelifera
Old Nov 27, 2012, 12:08 PM
plane58 is offline
plane58's Avatar
United States, MI
Joined Aug 2012
I like to thank everyone for there input, and Kcal it right, along with others..I'll give it a paint job....thanks
Old Nov 27, 2012, 02:30 PM
Pescador is offline
Find More Posts by Pescador
Boat racing enthusiast
Pescador's Avatar
Canada, AB, Calgary
Joined Jan 2009
There are guys bleaching yellowed nylon parts from older RC cars like the RC10 with hydrogen peroxide and sunlight.
I don't know if it would work on ABS.
http://www.tamiyaclub.com/showroom_m...98012&id=22525
Pescador is offline Find More Posts by Pescador
Old Nov 27, 2012, 10:01 PM
Drifter1soc is offline
Find More Posts by Drifter1soc
Drifter1soc's Avatar
Joined Oct 2011
Yup, that is florescent light yellowing. Had a fender strat pick guard do that once. I had to replace it. Painting is probably the correct answer.
Drifter1soc is offline Find More Posts by Drifter1soc
Old Nov 28, 2012, 01:21 AM
Joined Jul 2007
Woah, does that mean that if I have those curly bulbs, my Fender Telecaster and Epiphone Les Paul are in danger of pick guard damage?! :-(
Discussion Adhesives for ABS Plastic Bill Diedrich Scale Boats 21 Sep 06, 2012 02:27 PM
Discussion Tinting Clear Mylar White? ForeverFlying Painting and Finishing Tips 0 Mar 16, 2012 06:00 AM
Discussion Removing paint from Yellow f-18 Axefly Painting and Finishing Tips 7 May 12, 2011 02:14 AM
Discussion Remedy for Uv Yellowed ABS PLastic-It Works! cdog46 Dock Talk 3 Jul 25, 2010 10:37 PM
Removing Wrinkles From ARTF Covering (Sticky Plastic Type) Andycart Fuel Plane Talk 2 May 24, 2004 01:02 PM
