Old Nov 25, 2012, 06:21 PM
Member of S.S.O.T.B.B.
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
HK250GT 6Ch from a DH9116
My first CP heli, moving from a Double Horse 9116. It's a pretty big
jump, and thought I would share if someone is thinking of moving up.
My next heli would have been an MJX-F45 if it had not been for a
generous donation from another forum member (Thanks Balr14 !!).
I got it mostly assembled, just needed to install electronics.
I spent a ton of time getting the belt drive and tail to operate smoothly.
But now, she spools up like a dream. Smooth and silent. My 9116 sounds like
a dying lawnmower by comparison.
The one-way bearing is awesome to hear spool down, it spins for
quite a while. The belt drive took an hour to adjust, but now you don't
even know it's there.
The head speed is insane. I was scared to put it past 60%
Before I get heavy into the manuals and start setting it up, is there anything
that looks out of place?
Steve_ is offline Find More Posts by Steve_
Old Nov 25, 2012, 08:13 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I would make sure the pin moves very freely up and down inside the anti-rotation bracket. I noticed a lot of the openings in the HK250GT needed some sanding and filing.
Balr14 is offline Find More Posts by Balr14
Latest blog entry: Some stuff
Old Nov 26, 2012, 04:47 AM
Suomi, Ruovesi
Joined Feb 2011
Also I would cable tie the wiring
Essex2visuvesi is offline Find More Posts by Essex2visuvesi
Old Nov 27, 2012, 08:26 PM
Joined May 2011
Why not use a 3s(3 cell) li-po ? Will your canopy fit with the esc mounted side-ways? It looks like you will have to remove your gyro every time you replace your tail boom.(to get to the screws) The HK tail boom is super thin and super fragile.
mugen 1 is offline Find More Posts by mugen 1
Old Nov 28, 2012, 12:37 PM
Steve_'s Avatar
Joined Nov 2012
First hover today. I'm so freakin' happy. Took me forever to figure out the
setup / pitch / throttle curves / and every other thing I knew nothing about. LOL.
I have a decent beginner set I made (can still go wild 3D with
idle-up mode).
When you kick that in (idle-up).... OH MY !!! Freakin AWESOME !!!
(I only did it on the ground). And with the curve, that was only 80% throttle.
This thing is wicked. Very tricky to hover, even with a super docile custom setup.
Of course, it would be easier without the 8 Mph shifting breeze...
If anybody buys a 250GT and uses a SKY-703 radio, and Skyartec head lock gyro, you are welcome to my
setup, posted here. It's a good starting point at the very least.
https://docs.google.com/open?id=0B5i...mswZUhHLW1CTHM
It took me several hours to figure all the settings out, and this might save
you some time.
Old Nov 28, 2012, 01:12 PM
Steve_'s Avatar
Joined Nov 2012
This is a 2S setup pulled from a Wasp V3 and seems to have plenty
of power. Idle-up is scary
As far as the gyro, I have a huge roll of servo tape. No big deal if I have to
move it.
The only place the canopy is tight is at the battery, as I have it way forward
to try to balance it.
Old Nov 28, 2012, 03:01 PM
Closed Account
Joined Apr 2010
But it's gotta be easier than trying to hover that 9116 in a 8 mph shifting breeze
karlik is offline Find More Posts by karlik
Old Nov 28, 2012, 04:03 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
You are doing great! But, don't shift in to idle up mode on the ground. You want to be in the air at neutral throttle; much less stress on the equipment. You should probably get used to using throttle hold, rather than cutting the throttle in a crunch situation. When you cut throttle quickly you induce negative pitch, so you come down faster. There are two ways to offset this: use a pitch curve that has very little negative pitch or raise throttle trim. The downside of doing this is it reduces your ability to fight wind. But, if you use throttle trim, you can reduce it with a flick of a finger. The use of throttle trim to control flight characteristics is standard operating procedure on the Thunder Tiger Innovator. It works quite nicely on quads, too.
Old Nov 28, 2012, 05:30 PM
Steve_'s Avatar
Joined Nov 2012
Yup, I made a custom pitch curve that is all positive pitch. 1 to 6 degrees.
It doesn't get light on the skids at the curve I set until around 2 or 3 deg, so even if I completely cut the throttle it won't pancake. When I enabled idle-up mode I made sure I was at zero or very little pitch. It makes a quick 180, then sits there screaming happily
Old Nov 29, 2012, 11:08 AM
Steve_'s Avatar
Joined Nov 2012
Actually, the opposite is true, the 9116 is MUCH easier to fly.
Just FYI
I'm sure that will change once I get used to the completely different flight behavior.
The high head speed makes gyroscopic forces 10 times greater on the 250GT.
** EDIT
The HK250GT handles wind far better than the 9116. It's just harder to fly
because I suck at it.
Old Nov 30, 2012, 04:38 AM
Steve_'s Avatar
Joined Nov 2012
Broke my first part on the 250GT today. I was sliding sideways about a foot
off the ground and a gust made it dip and catch the skid.
Only broke 1 leg, so I can still fly it. But if I had been 2 feet up all
would be good. Stupid.
It can get away from you SOOO FAST... just a nudge on the sticks for a split
second is all you can give it unless you want it taking off like a freakin' rocket.
I need to get a radio with programmable rates and epa's so I can tone it down a
little while I learn.
When it starts to get out of shape, you set it down NOW.
If you have to think about it, it's too late... you've already bit the dust.
All you can do is cut the throttle and hope the blades "bounce" off the blacktop.
This thing is pure evil. Devil bird from hell, I'm not kidding.
I equate it to trying to balance a marble on top of a bowling ball.
I can't believe I have not totaled it already.
But it is so satisfying to fly... the sound, the snappy movement.
The way it holds it's position if you are on the sticks right.
It is just soooo smooth.
The spin rate of this thing is completely nuts.
The tail can spin around so fast it's a blur.
Old Nov 30, 2012, 08:10 AM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
If you tipped with enough force to break a skid leg, you should check the feathering shaft. They are always the first thing to bend. When you disassemble the head, pay very close attention to the order of the bushings, bearings, rings, etc. Lots of beginners overlook this. Going from a DH9116 to a 250 clone has to be the biggest jump I've ever heard of. Ranks right up there with starting with the old Walkera 4#3B.
Old Nov 30, 2012, 09:14 AM
Steve_'s Avatar
Joined Nov 2012
It kept flying when it happened, in fact I didn't even know I broke a part off
until I went to power down.
I was going sideways at a good clip and just nicked a crack in the blacktop.
If it wasn't for that crack, all would be well
The heli kept flying as if it weighed 200Lbs. Didn't even twitch.
Like I said, I didn't even know I broke anything until post flight.
I've ran a pack through since, and it seems ok, nothing different that I can
tell. Still smooth and snappy at the same time
I've got it sitting waiting to see if CA will bond it back together but I doubt
it, they are just too flexible.
Old Nov 30, 2012, 09:33 AM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Glue with CA, warp the break area with dental floss or fine thread and soak with CA. Even if it doesn't hold, you have effectively created a receptacle that you can put hot glue in.
Old Nov 30, 2012, 09:37 AM
Steve_'s Avatar
Joined Nov 2012
On a different note, the 9116 is totaled... Kid was flying, got it too far away.
I took over but it was already too late, couldn't see it.
Had to throttle cut, and this time it needs battery, PCB, head, frame,
and other stuff. Not even sure I want to fix it.
Sold Hk250gt Black_heart Aircraft - Electric - Helis (FS/W) 2 May 18, 2012 03:30 PM
For Sale HK250gt , Beastx, Satellite daveapplemotor Aircraft - Electric - Helis (FS/W) 7 May 09, 2012 04:26 PM
Sold HK250GT with upgrades newheliguy81 Aircraft - Electric - Helis (FS/W) 3 Mar 20, 2012 10:10 PM
Sold FS/FT HK250GT w/spares RobDog Aircraft - Electric - Helis (FS/W) 1 Mar 03, 2012 08:07 PM
