Old Dec 14, 2012, 11:09 PM
43851E is offline
Find More Posts by 43851E
43851E's Avatar
College Station, TX
Joined Jul 2009
I work in the manufacture sharpened diamond blades. 10 carbon atoms wide is about as sharp as anything. One problem faced with these sectioning blades is that the sectioned samples will exhibit compression or "chatter". The installation of a serration is the only way to allow the "cut" or slice to penetrate smoothly with a clear, no defect cut section of the material being machined. Otherwise fluid boundaries are introduced in a somewhat chaos free environment without set paths to control these harmonic artifacts.
So I say yes to the deviations provided they do not change the already existing design beyond safe limits.
Doug
43851E is offline Find More Posts by 43851E
Discussion Fixed leading edge slats, examples RCB1 Fuel Plane Talk 30 May 17, 2016 09:52 PM
Discussion Propeller modifications Overworked Racing Boats - Electric 5 Mar 28, 2012 10:12 AM
Help! Sanding leading edge on a Lil Bird 2M kurtenstein Sailplane Talk 3 Mar 27, 2012 11:20 PM
Discussion Leading Edge Leading Edge? gorgeflyer Slope 27 Sep 22, 2006 09:17 PM
Discussion Notched leading edges Azarr 3D Flying 31 Mar 22, 2006 03:32 PM
