It's not very big, about 2" x 2", so it's easy to enclose. Tupperware and PVC pipe seems to be a popular choices. You just need to figure out how to protect the wires.
Latest blog entry: Some stuff
Roto Bob,
Thanks for that. This was my original plan but I don't think the vectors are very good. The centre canard under the pod would allow balancing like a bicycle and be much more effective at a much less drag. It would also increase roll damping which would be beneficial at start up speeds. What do you think? |
There's a ton of products like this ArduPilot - these are based on Arduino, so you can find lots of open-source code for it. The nice thing about these is you get all the sensors you need for a multi-copter, but since you don't need all that, starting with a basic Arduino and buying sensors separately might be cheaper, and you wouldn't have any wasted components - the ArduPilot has 3 gyros, but you only need one. You're forging new ground, so the chance of needing something very customized is pretty high. http://www.robotshop.com/ardupilot-m...m_campaign=jos |
Denver, CO
Joined Dec 2005
The KK2 board can not be reprogrammed. That would require the MWC board I linked: http://www.goodluckbuy.com/crius-upg...r-v1-0-se.html. You can get MWC boards from $20 - $100; they all use Arduino code and the MultiWii interface.
Denver, CO
Joined Dec 2005
Ok, you can use the same control concept with the vertical canard. The linkages would be horizontal in that case. I think it would make it turn, as it corrected for roll. That might be ok, or complicate the steering. Hard to say without doing it. The horizontal controls have one on each side, pitching in opposite directions.
Roto B,
You've never seen anything like this before I can tell. That's okay, I don't think you're alone. I've been studying this concept for years. The centre canard doesn't effect yaw. It's centering (calibrating) may induce some lean or banking which would compliment steering, but other than that it's effect is simply roll. And very effective I might add. It's the same principle as riding a bicycle. I may end up combining the two control surfaces (horizontal and vertical) to reduce A'sOA and/or control suface size and there-by drag. Drag is really the biggest "evil" here as prop power is so limited. There are many design feature which will cleverly reduce drag as velocity increases. I'm pretty excited, I picked up the hull yesterday! |
2501 & Balr,
I really appreciate your input here as I'm considering a few more processor contolled functions: pitch (including depth, or ride height). Depth would likely be from a water pressure sensor. The submarine folks use this. It would eliminate my aft strut and foil... I'll make another drawing for clarity. This had eluded me until I "saw the light" with the electronics. Gotta admit, it still quite daunting... |
So, I know it looks the same as before but there are some significant differences in control.
Roll via the centre canard below the bulb Pitch via the aft foils, fully pivoting Yaw via the horizontally pivoting propeller, it's been moved out front in order to get the cleanest, undisturbed water to maximize efficiency as power is the weak link. Ride height via the forward foils and water pressure sensed The advantage of the single strut is reduced drag. About 30% of the lift will come from the buoyant bulb while purged of water at speed. 10% from the aft foils, And the remaining 60% from the forward foils. Balancing load shouldn't be that large if the sensing board and servos responds in a timely matter. Sooooo, where to go from here in designing a board and software to dynamically balance this beast... |
| Thread Tools | |
| Question How can I use the stabilization expander with 2D/3D stabilizer? | wazoo22 | Eagle Tree Systems | 1 | Oct 23, 2012 12:30 PM |
| Discussion Best video stabilization I've seen yet! | Deadstick 8409 | Aerial Photography | 4 | Sep 01, 2012 05:24 PM |
| Discussion What is the best stabilization system for the CineStar Gimbal? | Tarro | Aerial Photography | 10 | Aug 10, 2012 04:50 PM |
| Discussion What is the best OSD with stabilization? | Eric Tessmer | Video Piloting (FPV/RPV) | 4 | May 28, 2012 05:46 PM |
| Discussion Best stabilization software | JZSlenker | Hoverfly Technologies | 14 | Apr 23, 2012 07:34 AM |
