Old Mar 15, 2013, 09:23 PM
pantherqs is offline
Find More Posts by pantherqs
Canada, ON, Windsor
Joined Feb 2011
Buy it or not, that's the reason for them. I received enough in my kit to replace all of mine.
pantherqs is offline Find More Posts by pantherqs
Old Mar 15, 2013, 09:28 PM
dfruehwald is offline
Find More Posts by dfruehwald
WZ9V, AMA 409852
United States, VA, Alexandria
Joined Jan 2007
Now you have wondering if I'm just missing the other 5.
I have mine assembled with the black clips right now. Probably need to contact the CNC Heli guys.
dfruehwald is offline Find More Posts by dfruehwald
Old Mar 15, 2013, 10:26 PM
stumpy277 is offline
Find More Posts by stumpy277
stumpy277's Avatar
Canada, ON, Essex County
Joined Jan 2010
yay! got a free tarot 680 aluminum kit.. so the build begins..
Tarot 680 build (1 min 38 sec)
stumpy277 is offline Find More Posts by stumpy277
Old Mar 15, 2013, 11:40 PM
Fester 1 is offline
Find More Posts by Fester 1
ProFester
Fester 1's Avatar
United States, NY, Wallkill
Joined Feb 2008
Originally Posted by ALModels View Post
New landing skids made of the copter's arm
How do you like your motors ? what size props do you use ? How much throttle do you use to hover ? whats your flight time ? I just bought these motors and there is not a lot of info on people using them .Thanks
Fester 1 is offline Find More Posts by Fester 1
Old Mar 16, 2013, 12:45 AM
ALModels is offline
Find More Posts by ALModels
Aleksey Efimov
ALModels's Avatar
Joined Aug 2010
good motors
propeller 12 * 4.5
45/50% throttle (weight 2750 g)
4S 4000 mAh - 9 minutes
ALModels is offline Find More Posts by ALModels
Old Mar 16, 2013, 07:45 AM
caotri is offline
Find More Posts by caotri
Hochiminh City
Joined Mar 2004
Originally Posted by Askyvision View Post
any footage of the gopro on your brushless gimball that look nice.
if you have the battery on the bottom it much better to stabilize the aircraft than on top
I wonder how can you fold the hexa when esc is put in mid frame plates as your?
regards
Caotri
caotri is offline Find More Posts by caotri
Old Mar 16, 2013, 11:14 AM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
regards
Caotri
I mod mine with aluminum clamp so it not foldable because the folding clip are trash and it make the hex very flimsy with the plastic clip the arm vibrate a lots with the plastic clip. I did mod mine with a arm boom landing post it look tall and sexier. I also just got a Tarot Fy650 too the center plate is small so almost no space for all the esc and YSX4 but I manage to make a clean build
Askyvision is offline Find More Posts by Askyvision
Old Mar 16, 2013, 02:07 PM
WZ9V, AMA 409852
Joined Jan 2007
According to the folks at CNC Helicopter the white clips are not a replacement for the black ones when I asked them about it. They seem to be at a loss as to what the one white set (you'd need 4) is for also.
Old Mar 16, 2013, 02:21 PM
Albuquerque USA
Joined Dec 2012
White the same as black it just made it so you can use it in the front to distinc the black clip. The white clip have at the same time as the black when the break problem occur. The only clip that I think it a different material is from foxtech which cost $3.49 each. By the picture It look different and it said "upgrade". I havnt use it yet so I don't know for sure
There an easy fix for the break problem it not easy break but not fix the whole problem
Old Mar 16, 2013, 03:10 PM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
Here is my Tarot maiden with my own gimbal design "Magi v1"
Magi v1 & Hexa maiden "air test" 720 please !! (7 min 2 sec)
marcin.gala is offline Find More Posts by marcin.gala
Old Mar 17, 2013, 04:52 AM
caotri is offline
Hochiminh City
Joined Mar 2004
very stable fly and also good gimbal. can you share more detail about your own desugned gimbal. Thanks for sharing video
Old Mar 17, 2013, 09:48 AM
WZ9V, AMA 409852
Joined Jan 2007
Nice job. Could you post a pic of the gimbal. Are you planning to make them? I'm shopping for one.
http://www.youtube.com/watch?v=AIAoGjDDozY
Old Mar 17, 2013, 01:10 PM
Joined Jun 2010
Made some small improvements and got another testing flight.
Magi v1 & Hexa 2nd test flight ,some changes in gimbal. (3 min 13 sec)
Old Mar 17, 2013, 03:41 PM
stumpy277's Avatar
Joined Jan 2010
how did you level your motors? I've just mounted my motors and now wondering how to ensure they are level to ground
Old Mar 17, 2013, 03:45 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Fold the Hex`s arms together, then a ruler across the top of the motor housings. If all motors are flat against the ruler, they are all inline with each other and thus all pointing straight up. Just adjust each until they all match
Coyote64 is offline Find More Posts by Coyote64
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
