Old Feb 18, 2013, 04:07 PM
ALModels is offline
Find More Posts by ALModels
Aleksey Efimov
ALModels's Avatar
Joined Aug 2010
Originally Posted by LFLoTiTo View Post
Here is an alternative simple solution for the flimsy landing gear of the Tarot FY680.
Cheers,
Great idea!
Aleksey, be careful. Tarot isn't toy, it's very dangerous.
I hope, you want to be a father...
Do not worry! I have a thick jacket and pants.
ALModels is offline Find More Posts by ALModels
Old Feb 20, 2013, 05:55 PM
achiii is online now
Find More Posts by achiii
United States, PA, Philadelphia
Joined May 2012
Originally Posted by ALModels View Post
a little humor
While it seems like a relatively poor idea to jump over your hex, it is impressive that it stayed in the air after you bumped a prop or two. and your gps pos hold looks quite solid. nice.
achiii is online now Find More Posts by achiii
Old Feb 21, 2013, 01:34 PM
Sleepyc is offline
Find More Posts by Sleepyc
Closed Account
Joined Aug 2006
Maiden later today.
Tarot 680, iPower 750KV motors, Hobbywing 40 ESC, Xoar 12x4.5 wood props. Quadframes.us 215mm Landing gear with a Photohigher AVC130 sctrapped in.
HoverFly Pro FC.
Can't wait!
Sleepyc is offline Find More Posts by Sleepyc
Old Feb 21, 2013, 01:54 PM
madoldgit is offline
Find More Posts by madoldgit
United Kingdom, England, Maidstone
Joined Nov 2012
Originally Posted by Sleepyc View Post
Maiden later today.
HoverFly Pro FC.
Can't wait!
Nice rig!!!
madoldgit is offline Find More Posts by madoldgit
Old Feb 21, 2013, 02:02 PM
lov2fly is offline
Find More Posts by lov2fly
Gods not dead!
McMinnville OR
Joined Feb 2004
Maiden later today.
HoverFly Pro FC.
Can't wait!
are you using the 2217Q 750kv motors? If so did you do some motor thrust/amp tests to find what props to use?
lov2fly is offline Find More Posts by lov2fly
Old Feb 21, 2013, 02:32 PM
Sleepyc is offline
Closed Account
Joined Aug 2006
I used the recommended size prop info from Bambucopter, and then modified that info to take into account the Zoar wood props, which I have personally found work well at around a 1" smaller than recommended size. So I'm on 3 Cell and they recommend a 13/8 (which I think is crazy pitch) so I'm using 12/45s.
65-75 cm air frame
i2814Q 750kv 350w power brushless motor
40A ESC
3C 13/80 - 4C 11/47 cw,ccw propeller
Nav Lights added!
Old Feb 21, 2013, 03:19 PM
Mike Carrio is offline
Find More Posts by Mike Carrio
It's all about FPV
Puerto Rico, Hatillo
Joined Sep 2012
65-75 cm air frame
40A ESC
Nav Lights added!
What flight time you get with your current configuration??? Really like that landing gear/gimbal setup you have, might go that way with mine.
Mike Carrio is offline Find More Posts by Mike Carrio
Old Feb 21, 2013, 03:30 PM
Sleepyc is offline
Closed Account
Joined Aug 2006
I was getting 5 minutes on 4000 mHa on a similar rig with about 900 Mha left in the tank.And that rig was slightly lighter. So on this guy I'm running 8000 mHa (2 x 3S 4000) and I'm setting the timer at 7 min and then I'll check how much the packs have left in them. I think with conservative flying 9 - 10 min should be achievable.
Also i have no intension of ever folding this thing up, so I'm not too worried about the clips, the rig is very solid if left in the Hex config.
The Landing gear are really nice. From Quadframe US, I think they were only $119?
Old Feb 21, 2013, 03:38 PM
lov2fly is offline
Gods not dead!
McMinnville OR
Joined Feb 2004
do you know the weight with everything loaded ready to fly?
Old Feb 21, 2013, 06:36 PM
wrong17 is online now
Find More Posts by wrong17
wrong17
United States, CA, Sacramento
Joined Jan 2009
Has anyone use Sigma mount on there Tarot FY680 Frames?
I had it on my Xaircraft x650 and I like how it moves the ESC right next to the motor. Plus it take away all the extra wiring from the center of the frame.
CNC Helicopter.com sell these Sigma mounts here:
http://www.cnchelicopter.com/servlet...upgrade/Detail
According to CNC Helicopter's website it said that the Sigma mounts are upgrade arms for the Tarot 680 (Look the the bottom of the page):
http://www.cnchelicopter.com/servlet...Folding/Detail
Here is a picture of the Sigma Motor mounts (its is the larger one)
This is on my X650 frame but I want to use it on the Tarot FY680
wrong17 is online now Find More Posts by wrong17
Old Feb 21, 2013, 07:07 PM
wrong17
Joined Jan 2009
Here is a side by side comparison between the stock Tarot FY680 arms next to the same arm with a Sigma mount. The difference in length is about 4.5 inches (114mm).
Do you think this will be a problem? I assume there will be more stress for the inner mounts because of the longer arms. I am planning to use 13 inch props too. The motors I am using are 3506 650KV T-Motor with a 3s lipo.
Old Feb 21, 2013, 07:12 PM
wrong17
Joined Jan 2009
This is why I like the Sigma mount.... look how clean it makes it for my X650 and I would like to do the same for my Tarot:
The wires hanging out is for the gimbal
Old Feb 21, 2013, 07:16 PM
hixon_blues is offline
Find More Posts by hixon_blues
hixon_blues's Avatar
Joined Jan 2013
Check these out, made by tarot for the 680
http://www.goodluckbuy.com/tarot-m16...et-orange.html
I just picked up the Iron man 1000 octo and they have a similar motor mount with bracket for the ESC.
hixon_blues is offline Find More Posts by hixon_blues
Old Feb 21, 2013, 07:27 PM
wrong17
Joined Jan 2009
It looks like the stock Tarot Motor mount except it has a longer CF plate where you can strap on the ESC. I like how it keeps the esc close to the motor but it still has a lot of exposed wiring.
Old Feb 21, 2013, 09:02 PM
It's all about FPV
Joined Sep 2012
Great, thanks for the info. I have a couple of 4500mAh 3S batteries that I may try and see. I ordered some AX-2810Q-750KV motors from HK, and they also run on 4S so once I get the frame put together, I may try with 4S batteries, and compare.
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 08:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 05:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 09:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 14, 2009 12:15 AM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 11:16 AM
