Old Feb 03, 2013, 11:52 PM
RUSSIA is offline
Find More Posts by RUSSIA
Joined Dec 2012
My FY680 from 02feb2013
RUSSIA is offline Find More Posts by RUSSIA
Old Feb 04, 2013, 04:18 AM
madoldgit is offline
Find More Posts by madoldgit
United Kingdom, England, Maidstone
Joined Nov 2012
Looking good my friend!
madoldgit is offline Find More Posts by madoldgit
Old Feb 04, 2013, 04:55 AM
Darrens is offline
Find More Posts by Darrens
United Kingdom, Edingale
Joined Aug 2005
Hi Russia,
I have the same motors as you and they look great. One thing I did was heat shrink the wires where they enter the arms to add some protection against abrasion from the Ali clamp or carbon tube. I will monitor the heat shrink to see if it lasts and if not, replace with spiral wrap.
It's just a suggestion, but you may want to think about adding some protection to your wires also as you don't want to rub through the silicone and create a short on the carbon tube or break the wire all together.
Your call, but I hope this helps.
D
Darrens is offline Find More Posts by Darrens
Old Feb 04, 2013, 07:39 AM
trinco is online now
Find More Posts by trinco
☢ ɴᴏᴏʙ ☢
trinco's Avatar
Malaysia
Joined Mar 2012
i was wondering, can this frame be convert to quad X & Y6? i was thinking to build an X8 with this frame, if it can support quad X configuration im sure i can do X8 with it
trinco is online now Find More Posts by trinco
Old Feb 04, 2013, 09:15 AM
alek3d is offline
Find More Posts by alek3d
Slovakia
Joined Nov 2010
Originally Posted by Coyote64 View Post
Finally a break in the weather meant I could get a decent flight in.
The values were :
Total flight time before auto land : 7:20
On landing 37% of lipo still remained
Charger put 2845ma back in leaving 1155ma available
2845 gave 7 mins 20 ( 440 seconds ) so 6.5ma per second
1155 left means an additional 2mins 57 seconds ( 177 seconds )
So in theory 10 mins 17seconds flight time leaving 20% of a 5000mah 4S
Thanks a lot, sounds good
alek3d is offline Find More Posts by alek3d
Old Feb 04, 2013, 12:41 PM
psindrup is offline
Find More Posts by psindrup
Denmark, Region Zealand, Terslev
Joined Apr 2008
Hi fellow FY680 pilots
I just had a not so successful maiden flight with mine
The first without the compass calibrated
FY680 hexa copter with Naza controller - strange crash on maiden flight (1 min 7 sec)
After compass calibration
FY680 hexa copter with Naza controller - strange crash on maiden flight after compas calibration (0 min 56 sec)
B.t.w. - has anyone found a solution to the very flimsy/fragile landing "legs"?
They break very, very easy, and it does not take a rocket scientist to see that they are build/designed WAY to fragile.
T.i.a.
Peter
psindrup is offline Find More Posts by psindrup
Old Feb 04, 2013, 12:55 PM
Coyote64 is online now
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Says both video`s do not exist.
I thought the same about the landing gear, but after getting carried away and clipping a fence and having too "crashes" my landing gear survived both events without damage
Coyote64 is online now Find More Posts by Coyote64
Old Feb 04, 2013, 01:51 PM
Askyvision is offline
Find More Posts by Askyvision
Albuquerque USA
United States, NM, Albuquerque
Joined Dec 2012
T.i.a.
Peter
check out my landing gear mod here
http://www.rcgroups.com/forums/showt...0#post24007790
Askyvision is offline Find More Posts by Askyvision
Old Feb 04, 2013, 02:56 PM
crashpilot1 is offline
Find More Posts by crashpilot1
Joined Nov 2011
https://www.youtube.com/watch?v=l1ff...0_Ck0g&index=2
The second with the compass calibrated
https://www.youtube.com/watch?v=IAtD...0_Ck0g&index=1
T.i.a.
Peter
Mine is not here yet..........but can you show us where it broke
crashpilot1 is offline Find More Posts by crashpilot1
Old Feb 04, 2013, 06:12 PM
Albuquerque USA
Joined Dec 2012
At the T where the aluminum and the thin carbon with the screw in I replace mine with carbon problem solve but it suck the they didn't make it thicker but rather a thin one the lading post also very thin. That arm post is good
Old Feb 04, 2013, 07:46 PM
cq316 is offline
Find More Posts by cq316
United States, CA, Temecula
Joined Feb 2013
Hi everyone, I was planning on upgrading to the tarot and i was wondering if anyone has used Tacon motors.
Would these work or would it be really shaky for video because it is a 5 pole?
http://www.hobbypartz.com/96m603-big...826-870kv.html
If they would work, what size esc would you recommend?
cq316 is offline Find More Posts by cq316
Old Feb 04, 2013, 08:32 PM
sgg05158 is offline
Find More Posts by sgg05158
Singapore, Singapore
Joined Oct 2012
Heavy motor @ 170g... 6 motors alone would be > 1 kg.. I would not go for this on FY680
Max current should be somewhere <55A... Maybe 60A-70A ESC would do.
Any idea on its thrust?
sgg05158 is offline Find More Posts by sgg05158
Old Feb 04, 2013, 11:37 PM
Albuquerque USA
Joined Dec 2012
ESC is base on the motor dont go to way over the motor and then it beccome a switcher instead a controller
Old Feb 05, 2013, 02:53 AM
simone76 is offline
Find More Posts by simone76
simone76's Avatar
Italy, Lombardy, Cremona
Joined Mar 2007
did someone already tried out the new white clamps?
simone76 is offline Find More Posts by simone76
Old Feb 05, 2013, 02:54 AM
simone76 is offline
simone76's Avatar
Joined Mar 2007
you can go straight to his channel https://www.youtube.com/user/psindrup?feature=watch
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 08:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 05:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 09:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 14, 2009 12:15 AM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 11:16 AM
