Old Dec 07, 2012, 02:38 AM
madoldgit is offline
Find More Posts by madoldgit
United Kingdom, England, Maidstone
Joined Nov 2012
more photos of my 680
Here is a few close-ups of frame.
madoldgit is offline Find More Posts by madoldgit
Old Dec 07, 2012, 02:40 AM
Joined Nov 2012
Originally Posted by sgg05158 View Post
Thanks buddy for the information.. Would it be possible to increase the legs' length by simply using longer CF tube so that i can have more ground to camera poles clearance without compromising its strength? Maybe around additonal 20mm more? And how big is the center plate? Its diameter looks big.. Thanks for your patience..
centre plate is about 200mm (average size)
Old Dec 07, 2012, 06:45 AM
psindrup is offline
Find More Posts by psindrup
Denmark, Region Zealand, Terslev
Joined Apr 2008
Originally Posted by madoldgit View Post
, is it best to have long motor leads or long power leads!!!
I don't think it really matters, because the the current/power will have to "travel" the same distance (=same loss), but that discussion is very theoretical - I believe ...
Peter
psindrup is offline Find More Posts by psindrup
Old Dec 07, 2012, 07:01 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Long motor leads.
If you're using long power leads to ESC - you need to add extra capacitors (depends on length).
ABLomas is offline Find More Posts by ABLomas
Old Dec 07, 2012, 08:18 AM
Kaptenklister is offline
Find More Posts by Kaptenklister
Sverige, Örebro Län, Hallsberg
Joined Oct 2011
Originally Posted by ABLomas View Post
Long motor leads.
True, I fried a ESC due to too long power leads.
Kaptenklister is offline Find More Posts by Kaptenklister
Old Dec 07, 2012, 12:03 PM
Joined Nov 2012
must admit that I would prefer long motor leads as this would make for a much neater 'look', but at the expense of inboard ESC's not being kept cool in downwash from props!
Old Dec 07, 2012, 05:32 PM
achiii is offline
Find More Posts by achiii
United States, PA, Philadelphia
Joined May 2012
Mine arrived this evening. Really its a very nice frame. I was quite impressed. Hopefully I remain as impressed as I actually fit it out.
achiii is offline Find More Posts by achiii
Old Dec 08, 2012, 12:03 AM
sgg05158 is offline
Find More Posts by sgg05158
Singapore, Singapore
Joined Oct 2012
FY680 Legs
I also received mine the last night...
I find the legs shaky because of the single allen head screw holding the landing skids from the legs pole acts as a pivot .. this actually concerns me. would this be a problem for anyone?
sgg05158 is offline Find More Posts by sgg05158
Old Dec 08, 2012, 02:46 AM
achiii is offline
Joined May 2012
Did you notice on the instructions that there is no mention of the folding legs, and instead it calls for the xaircraft standard legs that fit the load rails on the tarot? You could always go that route. I havent fit the legs yet, to see if they concern me (it is a little annoying that the legs seem to be the only part that require a smaller wrench).
Old Dec 08, 2012, 07:12 AM
sgg05158 is offline
Joined Oct 2012
yeah I noticed that last night.. for me the very reason why I decided to go for this frame is due to the folding landing gear.. however, it needs modification to;
1.0 make it strong enough to handle heavier payload.
2.0 increase ground clearance for gimbal installation
Old Dec 08, 2012, 08:08 AM
achiii is offline
Joined May 2012
I did too, but Im not yet convinced it needs 1. and my gimbal hasnt arrived yet for me to evaluate 2.
Old Dec 08, 2012, 08:29 AM
sgg05158 is offline
Joined Oct 2012
1 is pointed at the shaky landing gear and not the frame.. but then it is just my opinion.. probably when somebody starts flying it we will get to know if the legs will support well.. I ordered GO gimbal from copterframes and its height is 195mm while FY680 clearance is only around 175mm.. so I am referring to this, yes this may not be true for all..
Old Dec 08, 2012, 09:58 AM
achiii is offline
Joined May 2012
Yup, it certainly might break at that single bolt, and it is clearly a little shaky at that location. We'll see how it holds up.
I thought my motors/escs/FC were being delivered today, but alas no. It will still be some time before I can build.
Old Dec 08, 2012, 05:01 PM
achiii is offline
Joined May 2012
There is a textured foam/rubbery thing with one adhesive side in the kit. I put the whole frame together (weighed as 630g on my kitchen scale), but I still am not sure what this is supposed to be for. Anyone?
Old Dec 08, 2012, 10:10 PM
sgg05158 is offline
Joined Oct 2012
Would it be a good idea if it I use as battery anti slip mat? This will ensure maintain you CG whle on flight. That's what I plan to do..
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
