Old Dec 05, 2012, 02:07 PM
psindrup is offline
Find More Posts by psindrup
Denmark, Region Zealand, Terslev
Joined Apr 2008
Thanks for sharing the pictures! :-)
Where are you planning to place the ESC's?
Peter
psindrup is offline Find More Posts by psindrup
Old Dec 05, 2012, 02:13 PM
psindrup is offline
Joined Apr 2008
I managed to find a/the video. :-)
fy680 (4 min 13 sec)
Please note that he is running his rig on 6S!
Peter
Old Dec 05, 2012, 02:26 PM
ABLomas is online now
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Very bad stabilized video (in software) - you can't say anything about frame performance from this video...
ABLomas is online now Find More Posts by ABLomas
Old Dec 05, 2012, 04:19 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
Your right it does say much at all. The motor mounts are different and the landing gear different.
NaterPin is offline Find More Posts by NaterPin
Old Dec 05, 2012, 05:06 PM
psindrup is offline
Joined Apr 2008
Can I hijack this thread just a little? :-)
If I want to run the FT680 folding hexacopter with a Naza GPS unit on 6S (to be able to reuse the batteries from my T-rex 500) what motors, propellers and ESC's would be the right choice?
Peter
PS: If OP finds this post "out of place", let me know, and I will start a separate thread.
Old Dec 05, 2012, 08:31 PM
sgg05158 is offline
Find More Posts by sgg05158
Singapore, Singapore
Joined Oct 2012
Originally Posted by madoldgit View Post
60mm centre to centre of poles and 175mm ground to centre of pole and if you had 1047 props there is a gap of 85mm between rotor tips (at closest point) hope this helps.
Thanks buddy for the information.. Would it be possible to increase the legs' length by simply using longer CF tube so that i can have more ground to camera poles clearance without compromising its strength? Maybe around additonal 20mm more? And how big is the center plate? Its diameter looks big.. Thanks for your patience..
sgg05158 is offline Find More Posts by sgg05158
Old Dec 06, 2012, 01:56 AM
simone76 is offline
Find More Posts by simone76
simone76's Avatar
Italy, Lombardy, Cremona
Joined Mar 2007
http://www.rctimer.com/index.php?gOo...8&productname=
this could fit
simone76 is offline Find More Posts by simone76
Old Dec 06, 2012, 07:36 AM
sgg05158 is offline
Joined Oct 2012
This motor uses 6S battery.. propeller range from 1047 to 1447.. this is within the the 10" to 13" propeller range for FY680.. maximum current at 16A only..
http://www.foxtechfpv.com/foxtech-mo...390-p-623.html
please don't forget to share your experience..
Old Dec 06, 2012, 05:34 PM
knichefilms is offline
Find More Posts by knichefilms
United States, OH, Springfield
Joined Nov 2012
I ordered mine from cnchelicopter.com today along with a few extra parts. Can't wait till it gets here. I have also ordered maytech motors and esc's from a local/web vendor radicalrc.com, the ones I bought aren't on his site but he can order anything. Dave takes good care of me there and designed one hell of a Wright Flyer kit. He's always at Weak Sigals. Not sure on the gimbal yet but planning to carry an Nex5 or T2i. Also planning to make the landing gear retractable. I'm thinking Naza w/ GPS for the controller since I can't quite afford the WKM. It's looking like Wednesday for delivery. I'll do my best to document as much as possible along the way. I'll update as it comes.
knichefilms is offline Find More Posts by knichefilms
Old Dec 06, 2012, 05:39 PM
sgg05158 is offline
Joined Oct 2012
http://www.rcgroups.com/forums/showthread.php?t=1782327
Maximum propreller size for this hexa is 12".. Not as indicated 10" to 13" range... I ordered 12"..
Old Dec 06, 2012, 06:15 PM
madoldgit is offline
Find More Posts by madoldgit
United Kingdom, England, Maidstone
Joined Nov 2012
legs should be fairly easy to lengthen, although the tube looks as though its bonded/glued into the metal bottom mounts, the top (hinge end) has a hex all the way through. Will measure the c/plate in morning and upload photo of it all folded
madoldgit is offline Find More Posts by madoldgit
Old Dec 06, 2012, 06:19 PM
Joined Nov 2012
retracts should be a fairly easy mod, was thinking of going that route myself! (using a separate servo each side)
Old Dec 06, 2012, 06:24 PM
Joined Nov 2012
Peter
not sure where to put ESC's, want it to look as clean as poss', is it best to have long motor leads or long power leads!!!
Old Dec 06, 2012, 11:17 PM
ALModels is offline
Find More Posts by ALModels
Aleksey Efimov
ALModels's Avatar
Joined Aug 2010
Hello madoldgit! Is the copter frame rigid enough?
ALModels is offline Find More Posts by ALModels
Old Dec 07, 2012, 02:35 AM
Joined Nov 2012
Seems to be rigid enough! good quality carbon-fibre. I dont have anything to compare against though!!! (only my cheap X525)
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
