Old Jul 09, 2013, 05:08 PM
offtopic is offline
Find More Posts by offtopic
United States, IN, Jeff
Joined Dec 2012
Originally Posted by morris.hans View Post
3900mah out of a 4000mah battery. Are your numbers from hovering only? Thats flying around on less than 5% lipo battery life which is really sketchy for the hex and batteries hovering or not.
Flying around. Even after the battery alarm sounds It still has plenty of power. I'm using those nano tech batteries. They get warm but no swelling what so ever. I do push em to there limits I admit that. With this hexa it fly's so much better than my qav500. That quad, soon as the alarm sounded it would drop out of the sky. The 680 still fly's and with longer flight times. I have sucked out 4100mah out of one of the 4s and it didn't faze it. I've flown the 680 enough times now to trust the alarm and my time on the transmitter. Soon as I add more weight Im sure my times will differ.
That azzhole from uavobjects.com canceled my preorder on a rctimer gimbal I just found out. I figured I would give him a second chance to take my money. I was wrong again with him. If he doesn't want to take my cash and doesn't like me he should take me off his mailing list. I guess I'm just a number to him...And who the heck uses a brick for a gimbal test. The guy even looks like a azzhole in his video. Go figure... Sorry for the rant but needed to vent somewhere..
offtopic is offline Find More Posts by offtopic
Old Jul 10, 2013, 12:24 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Taking more than 80% out of your lipo will damage the chemistry of the lipo. Don`t be thinking its not bothered by it, the damage has already been done now. The lipo`s will start getting worse and worse each cycle. Just because it puts the same mah back in doesn't mean its fine still.
Coyote64 is offline Find More Posts by Coyote64
Old Jul 10, 2013, 12:35 AM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
What about 4006 motors? They are significantly lighter but might do the job...
tigar is offline Find More Posts by tigar
Old Jul 10, 2013, 07:18 AM
offtopic is offline
Joined Dec 2012
I bet I have 15 to 20 charges on them with no problems yet. My 3300mah started to swell a little on the qav500 but it's still going strong. Back when thunderpower lipos were the sh! t the best lipo available at the time. I had issues with them swelling. With these newer lipo's out now they seem to be much better.
Im waiting on a zippy lipo brand to get here. I'm curious to see if its up to par with the nanotech's. I will continue to run them as I am. Even if I just get 50 cycles out of a lipo I'm satisfied.
I made up a parallel deans conector last night. I'm going to run two 4s friday when I'm off work and see what happens. I have a good feeling about it. I will let you guys know the outcome.
I know there are calculators to determine fight times with different weights and prop sizes and so on. But real world testing wins every time. Trial and err has always worked best for me.
Old Jul 11, 2013, 11:33 AM
UAVJOE is offline
Find More Posts by UAVJOE
Sr. Ext. UAS Pilot, NMSU FTC
UAVJOE's Avatar
United States, NM, Las Cruces
Joined Feb 2012
Can someone measure the center plate on the FY680? I would like to order a dome for it at the same time.
UAVJOE is offline Find More Posts by UAVJOE
Old Jul 11, 2013, 12:40 PM
tigar is offline
tigar's Avatar
Athens, Greece
Joined Sep 2001
19-20cm diameter depending where you measure since it is not a perfect circle.
Old Jul 11, 2013, 05:54 PM
UAVJOE is offline
UAVJOE's Avatar
Joined Feb 2012
Roger that. Thanks I have been looking for this information.
Really appreciate it.
Old Jul 11, 2013, 10:39 PM
AIRFED is offline
Find More Posts by AIRFED
United States, LA, Shreveport
Joined Jul 2013
Checking out the cheap landing gear. 200 grams lighter than the quadframe gear but still strong enough for my 2656 gram flight weight.
http://gothelirc.com/shopdisplayprod...r+Landing+Gear
AIRFED is offline Find More Posts by AIRFED
Old Jul 12, 2013, 08:10 AM
rahulvyas is offline
Find More Posts by rahulvyas
Joined Jul 2012
I bought FY690S finally from infinity-hobby.com 233$ incl DHL shipping
rahulvyas is offline Find More Posts by rahulvyas
Old Jul 12, 2013, 05:54 PM
mezerwi is offline
Find More Posts by mezerwi
Joined Jul 2012
Tarot FY680 (0 min 15 sec)
mezerwi is offline Find More Posts by mezerwi
Old Jul 12, 2013, 07:32 PM
Jarold C is offline
Find More Posts by Jarold C
Joined Mar 2013
Originally Posted by mezerwi View Post
What its your setup? Motors, props, and fc, please- it looks good!
Jarold C is offline Find More Posts by Jarold C
Old Jul 12, 2013, 07:52 PM
mezerwi is offline
Joined Jul 2012
Ys-X4
AX2810Q x 6
30A plush esc
5000mah 3s x2
You can fly more than 15 min with this setup.
add additional 1.48GPB x 12, u can get EZO bearing which make this motor superb. =D
Old Jul 12, 2013, 08:09 PM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Will the sunnysky 2216 800kv work with this frame using 4s? I'll be carrying gopro brushless gimbal. Not sure what would be the AUW but i'm flying 2.9kg on F550 frame.
DYORD is offline Find More Posts by DYORD
Old Jul 13, 2013, 07:42 AM
bjornthans is online now
Find More Posts by bjornthans
bjornthans's Avatar
Norway, Troms, Skjervoy
Joined Jul 2012
it will work nice with a 5000 mah and a gopro. im flying those motors on a disco,f550 and a nex neo. i use 3508 700kv on my 680. but i have auw at 4kg.
bjornthans is online now Find More Posts by bjornthans
Old Jul 13, 2013, 07:47 AM
CyberCrash is offline
Find More Posts by CyberCrash
Germany
Joined Sep 2009
Ys-X4
AX2810Q x 6
30A plush esc
5000mah 3s x2
Wow, so these motors: AX2810Q
Seem pretty damn good. 10Ah and over 15min??
That's amazing. I only get 8:39min out of my 6600mAh and 2.7kg.
What is your weight?
CyberCrash is offline Find More Posts by CyberCrash
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
