Old Dec 20, 2012, 06:52 PM
sey2washy is offline
Find More Posts by sey2washy
Joined Oct 2009
Originally Posted by zhangdanchen View Post
you this is fy680 Adapted
Yes, I have adapted the FY680 to the pictures above
sey2washy is offline Find More Posts by sey2washy
Old Dec 20, 2012, 06:57 PM
Joined Oct 2009
Originally Posted by Sleepyc View Post
Right now no different props/ I'm at 1045 on all.
But I have been reading about the different pitches on top and bottomn. When I can find some cheap decent props I'll try it.,
GoPro 3 is really nice. No complaints. I have the Silver edition, so it's basically just a smaller Hero 2, but I do like the flat lens of the protective case.
The guys over on the askman gimbal thread seem to think the wood zinger props are the way to go, just as good if not better then the expensive graupner props. I have a set on the way but they may take a couple of weeks to get here.
I got the black edition. We really like the idea of the 120fps for some slow-mo footage.
Old Dec 20, 2012, 09:57 PM
Velociraptor73 is offline
Find More Posts by Velociraptor73
SMILE you're being recorded :)
Velociraptor73's Avatar
Joined Apr 2010
I was also following Askman thread since it started and tried Zingers 9x4 with original DJI 2212, but they were overheating the motors when gimbal was onboard (even with no camera), probably because my altitude and overall temperature. That is something you must consider too. And then instead of Graupners I went for Carbon 11x5 from Foxtech on 2216. But before I could do some decent tests and compare flight times they got broken in a tip over landing. They are very fragile, even more than Zingers. I just received a new carbon set and waiting to finish my FY680 to start again.
Regarding Naza with Y6, you have to set it at assistant software, just as you would do to any new instal. Naza is not exactly plug and play out of the box. One must read carefully the manual a few times before trying to install it and do the setup for the first time. But after you find your way around it's pretty easy.
And yes Y6 is much better at wind situations and you barely need a gimbal so stable it is. But mine felt less locked on course than my original flat X6 setup that was a joy to fly. And I still got some wobbling on fast descents. Maybe better gains cold fix that, but I didn't have the chance to try it. Another factor to consider is that my Y550 (F550 clone converted to Y6) had too flexible arms and that didn't help at all either.
Velociraptor73 is offline Find More Posts by Velociraptor73
Old Dec 21, 2012, 03:17 AM
psindrup is offline
Find More Posts by psindrup
Denmark, Region Zealand, Terslev
Joined Apr 2008
Could someone guide me in the direction of the askman gimbal thread,- please. :-)
What size of propellers wooden would you use?
(A direct link would be über cool)
Peter
psindrup is offline Find More Posts by psindrup
Old Dec 21, 2012, 03:13 PM
madoldgit is offline
Find More Posts by madoldgit
United Kingdom, England, Maidstone
Joined Nov 2012
Anybody running mwc 2.1 on a crius se fc how does it compare to megapirate???
I'm looking at stability over response in the flight characteristics (dont mind it being on the slightly sluggish side)
madoldgit is offline Find More Posts by madoldgit
Old Dec 21, 2012, 03:54 PM
psindrup is offline
Joined Apr 2008
What size propellers are you all using?
I am considering these with 880KV motors
http://www.kopterworx.com/vmchk/Xoar...prop-11x5-pair
Peter
Old Dec 21, 2012, 04:14 PM
Sleepyc is offline
Find More Posts by Sleepyc
Closed Account
Joined Aug 2006
Man look into the Hoverfly boards. They are so stable it's almost insane.
I have 4 of them now (2 sport and 2 pro) and I love them. Tried a Naza and hated it.
HF just flys SO smoothly with the proper gain settings.
Soon I should have a pro with a GPS unit and see how that all works. Also the HFP included 2 axis gimbal controller rocks. Really nice bit of kit!
Sleepyc is offline Find More Posts by Sleepyc
Old Dec 21, 2012, 05:44 PM
zhangdanchen is offline
Find More Posts by zhangdanchen
Joined Dec 2012
the taort more Product plese look this fackbook web http://www.facebook.com/profile.php?id=100004645114287:)
zhangdanchen is offline Find More Posts by zhangdanchen
Reply With Quote  (Disabled)
Old Dec 21, 2012, 06:48 PM
Joined Nov 2012
went and had a look on their site, nice bit of kit!! but outa my price range unfortunately .
Old Dec 21, 2012, 07:22 PM
Joined Dec 2012
you can buy this only 100usd, if you think buy this tell me
Old Dec 22, 2012, 01:27 AM
Joined Oct 2009
Peter
http://www.rcgroups.com/forums/showthread.php?t=1582036
It's a rather large thread now but there is a lot of information hidden in there. http://tppacks.com/store/ is the website for their equipment.
http://www.zingerpropeller.com/ has a good range of propellors that are reasonably priced. Much cheaper than the graupners and any carbon props.
Cheers
Seymour
Old Dec 22, 2012, 05:32 AM
TooSLow2Care is offline
Find More Posts by TooSLow2Care
insert witty phrase here
Joined Aug 2006
I just received my kit today. Started assembly and I know it goes without saying, but just in case...
THREAD LOCKER is your best friend.
All of these tiny 2.5mm thread & 2.0mm thread hardware CAN NOT be torqued on. Simply tighten snug with some blue/medium thread locker (Loctite, Permatex, etc) & you'll be happy.
I think my 680 is going to run 12" props on 6S. That works te math out to ~400kv motors...
Cheers,
Brian
TooSLow2Care is offline Find More Posts by TooSLow2Care
Old Dec 22, 2012, 07:52 AM
ALModels is offline
Find More Posts by ALModels
Aleksey Efimov
ALModels's Avatar
Joined Aug 2010
hi guys !
I flew his hexacopter
motor
ESC
prop 10*4.5
is a frame from the site FoxTech
ALModels is offline Find More Posts by ALModels
Old Dec 22, 2012, 08:04 AM
psindrup is offline
Joined Apr 2008
Originally Posted by ALModels View Post
hi guys !
motor
ESC
prop 10*4.5
Looking good!
Finally some affordable motors and ESC's with the correct specs.
***********************Warning!******************* **********
The motors you are linking to, requires a 40A ESC!!
Peter
Old Dec 22, 2012, 10:57 AM
ALModels is offline
Aleksey Efimov
ALModels's Avatar
Joined Aug 2010
I have no problems ;-)
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
