Old Nov 25, 2012, 03:58 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Tarot FY680 hex
Anyone tested already?
http://www.goodluckbuy.com/tarot-fy6...me-tl6801.html
Another source:
http://www.foxtechfpv.com/tarot-fy68...der-p-810.html
I found few threads on other forums, but seems no-one tested it yet. There's review on Youtube, but after HoryzonHD cam i won't trust FU ;-)
So, anyone got it already and could confirm, that it's stiff, made from real carbon fiber (and not GF-CF 'sandwitch'), is so easy to fold as described?
ABLomas is offline Find More Posts by ABLomas
Old Nov 25, 2012, 06:40 AM
fotogear302 is offline
Find More Posts by fotogear302
Hong Kong, Sham Shui Po
Joined Jun 2012
confirmed it is made of real CF (not GF) - 2mm thick center board. good thing is that it is much more stable than my old XA650. bad thing is their accessories for fy680 is a bit expensive.
also, i heard that TAROT is developing their own CINESTAR based gimbal.
fotogear302 is offline Find More Posts by fotogear302
Old Nov 25, 2012, 08:17 AM
sgg05158 is offline
Find More Posts by sgg05158
Singapore, Singapore
Joined Oct 2012
I am very interested to get this because of its fully foldable feature including the landing skid, makes it very easy to bring along from one place to the other.
however, I wonder whether it will be able to handle dslr.. could this be able to handle 4-6kg of takeoff weight?
sgg05158 is offline Find More Posts by sgg05158
Old Nov 25, 2012, 10:13 AM
Joined Jun 2012
not for dslr but mirrorless camera such as nex5 , gh2
Old Nov 25, 2012, 01:37 PM
Velociraptor73 is offline
Find More Posts by Velociraptor73
SMILE you're being recorded :)
Velociraptor73's Avatar
Joined Apr 2010
I'm also looking for a good review on this frame as I need to replace my F550. I'm more towards Jakub's six as it's a well known and proven frame. I'm a bit afraid FY680 landing gear could collapse in a less than perfect landing. But a good unbiased review could put it on my shopping cart.
Velociraptor73 is offline Find More Posts by Velociraptor73
Old Nov 26, 2012, 03:42 PM
Diafragma1939 is offline
Find More Posts by Diafragma1939
Joined Jun 2012
+1
I'm also interested in the tech specs of this amazing looking frame
Diafragma1939 is offline Find More Posts by Diafragma1939
Old Nov 26, 2012, 11:06 PM
sgg05158 is offline
Joined Oct 2012
I have seen the video and the springs looks strongs, not easy to retract... Also comparing this with a retractable landing gear which is being introduced now i would trust this more than that.. I guess.. I hope they include a hard case..
Old Nov 28, 2012, 03:11 PM
madoldgit is offline
Find More Posts by madoldgit
United Kingdom, England, Maidstone
Joined Nov 2012
fy 680 testing
Hi all, just joined this forum and was looking for reviews on the fy 680, but no luck so far!! on a plus side my fy 680 should be with me before christmas, so if nobody has done a review I may post a video of how well it was packed/bits missing and finaly a build up of it!
madoldgit is offline Find More Posts by madoldgit
Old Nov 28, 2012, 10:03 PM
sgg05158 is offline
Joined Oct 2012
madoldgit... Great! looking forward to you review with videos.. Please also share the electrnics you will use and the flight time you will achive.. Somebody has done a test of 5kg payload using 6x2200 mah 3s lipos but only 6 minutes hover time..
Old Nov 28, 2012, 10:56 PM
FlyingMcCoy is online now
Find More Posts by FlyingMcCoy
Joined Mar 2010
I assume the 5kg payload includes the 6 lipos.
FlyingMcCoy is online now Find More Posts by FlyingMcCoy
Old Nov 29, 2012, 03:04 AM
sgg05158 is offline
Joined Oct 2012
The test was done in 2011 by KK, i found it very useful for me.
Weight with batteries was at 3kg and based on his test, found the most stable payload at 5kg, total flying weight of 7kg..
sorry if my i maybe using some strange terminologies as I am a newbie myself..
here is the link:
http://www.rcgroups.com/forums/showthread.php?t=1372744
Old Dec 04, 2012, 04:51 AM
psindrup is offline
Find More Posts by psindrup
Denmark, Region Zealand, Terslev
Joined Apr 2008
I would not be bothered about that at all.
The landing gear folds "outwards", and if you land sideways, the leading edge landing gear is loaded in the different direction of the direction it folds.
I am pretty sure that if you are really worried about the landing gear "collapsing" on a hard vertical landing, you could find a way to pin the legs.
Am am too looking for the first reviews, build videos and flight reports of the first "fylly installed" FY680
Peter
psindrup is offline Find More Posts by psindrup
Old Dec 04, 2012, 05:20 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
only if they extend the m2m to 700+... otherwise it is hard to increase flight time effectively.
jy0933 is offline Find More Posts by jy0933
Old Dec 04, 2012, 08:31 AM
simone76 is offline
Find More Posts by simone76
simone76's Avatar
Italy, Lombardy, Cremona
Joined Mar 2007
I'm building it for NEX5N 3 axis gimbal with arduino based secondary controller for video operator. Target weight of 4.5 kilos. It will take me some time because it isn't the only project i'm working on. A thing i can tell, 13" propellers swing with a gap of 9-10mm. Way too little, i will increase the wheel base to slightly above 700 to achieve at least 20mm gap.
Now you can find also the carbon/alu version and save some bucks: http://www.goodluckbuy.com/tarot-fy6...me-tl6802.html
simone76 is offline Find More Posts by simone76
Old Dec 04, 2012, 12:47 PM
psindrup is offline
Joined Apr 2008
Great!
Are you documenting your build, so the rest of the world can follow your progress?
I am new to this hexacopter "thing" (I have been flying and building "ordinary" rc copters for 4 years) so I am curious why the propeller spacing is an issue?
A friend of mine has build a similar sized hexacopter and recommended these propellers.
http://mikrokopter.altigator.com/gra...imisdi0t2s5hg6
Best regards
Peter
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
