Old Nov 25, 2012, 03:39 AM
Efliernz is offline
Find More Posts by Efliernz
I'll fly anything...
Efliernz's Avatar
Hamilton, New Zealand
Joined Jan 2007
OSD not level - any ideas?
I have not used the ODS in the past so I have nothing to compare this to.
I have flashed the latest firmware and started from the beginning with temp and the acc calibration process. I have done this twice, getting the same results. The horizon is not level... and it should be. It is level in the setup program.
Another thing I find strange is that I have centered all my TX trims and subtrims and started clean. My DW VM-6 (in manual mode) lifts up and is perfectly in trim. Magnificently perfect! When I switch to AL, I need a lot of roll trim to balance it - as though it is trying to balance to what the OSD tilt is. Yes I can trim it out (with a heap of trim), repower, all that stuff but I am wondering if others are seeing similar results when changing to the new firmware.
Pete
Efliernz is offline Find More Posts by Efliernz
Old Nov 27, 2012, 05:41 PM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
The horizon may be cooked until you arm the multi-rotor.
Have you downloaded the new v4.6 setup client to go with the v4.6 firmware?
Are the accelerometer and temperature compensation check boxes checked in the "Pro Info" tab?
I'll check it out on my setup tonight to see if I can replicate the problem.
George
Pete
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Nov 28, 2012, 01:45 AM
Efliernz is offline
Efliernz's Avatar
Joined Jan 2007
I printed the guide on 4.6 and followed it slowly and carefully... Downloading the latest software client/setup before flashing, disabling and then re-calibrating temperature and acc. I did it twice. It is crooked before and after arming.
Stacky has the same problem. I know the OSD and battery indicator are working (yay) but I think my gimbal and AL worked better with less variation with 4.3.802.
Pete
Old Nov 28, 2012, 06:21 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
So, I just looked into this. It appears that there is a bug in the display of the artificial horizon in the setup client. Basically, it will tell you wherever you start is level. The artificial horizon in the OSD is correct when the aircraft is armed and ready to fly. It is a little weird to me that it is so far off if your setup. In my test setup, it's completely level when the aircraft is level. Is your HoverflyPro level on your frame?
This is a picture of mine armed and ready to fly.
Site Sponsor
Old Nov 28, 2012, 07:13 PM
Efliernz is offline
Efliernz's Avatar
Joined Jan 2007
I will have another go tonight... but with the current testing giving me an unusable AH (which I use), I may have to roll back to 4.3 first as I have a media event next week and I need some flight time...
My board was level when calibrated. I have a perfectly level desk and I had a level on the FC bracket at calibration.
Thanks George.
Old Nov 28, 2012, 11:44 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
The fact that your artificial horizon isn't level is telling me something is wrong. The new altitude hold uses ALL of your sensors (including accelerometer) to hold altitude. If something isn't right, it could cause what you are seeing with AH.
Thanks George.
Site Sponsor
Old Nov 29, 2012, 06:31 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
What version of the setup client are you using? It must be version 4.6 or higher to work with the new accelerometer calibration. I think this is probably the problem you are having.
Site Sponsor
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
BTW, you can get the new one here.
http://www.hoverflyupdate.com/setupC....6/publish.htm
Site Sponsor
Old Nov 29, 2012, 07:22 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
Also, just released v4.6 r2 which fixes the artificial horizon display issue.
Site Sponsor
Old Nov 30, 2012, 02:10 AM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
George, love how you guys sort things out so fast. Thanks
Stacky is offline Find More Posts by Stacky
Help! DJI F450 NAZA/GPS will not connect to assistant software, any ideas would be great. jasper7821 Multirotor Electronics 2 Oct 24, 2012 06:53 PM
Discussion DX8 Not detected in Windows - Any ideas? crashnstick Simulators 0 Sep 01, 2012 06:13 AM
Discussion Receiver Add-On Voltage Leveling Capacitor Good Or Bad Idea? itsme2 Radios 1 Jul 22, 2012 03:05 PM
Question edogfight , any idea why they not responding ? danny_isr Vendor Talk 2 Jan 22, 2004 02:45 AM
My D drive will not work it shows in use retry,any ideas? kitbasher Life, The Universe, and Politics 2 Dec 24, 2003 05:30 PM
