Old Nov 24, 2012, 11:45 PM
RWalker is offline
Find More Posts by RWalker
United States, CA, Lancaster
Joined Nov 2011
Putting the Anylink Inside!
Sacrilege! How dare you open up an Anylink! Yeah, I dare. I 've been eyeing this thing ever since I started buying and installing these FrSky 2.4 modules. I began to realize the principle is the same: tie in to the trainer plug with three wires. I just couldn't abide this big bulky enclosure sticking on the back of my radio. It's made for the average DIY adverse r/c'er.
I looked around on line to see if anyone had done what I'd been pondering, and alas, I'm to be the innovator here. So here's the internal mounting of an Anylink 2.4ghz module. The only concern I have will be restoring the antenna connection. Let's be clear here: even with another antenna cable, the range will still be 1000 feet, and this is somewhat messin' with the cosmic order of things over at Hobbico. You're also voiding the warranty, but if you're an RC geek , this shouldn't bother you. I'm just conductiing this experiment to see if it could be done.
Makes total sense to make one of these available to put inside a transmitter like our Chinese overlords have done. Put this puppy in some shrink tube, stick it on the inside with servo tape and tie in to the trainer plug or the board. I'll let ya know how it all works out.
RWalker is offline Find More Posts by RWalker
Old Nov 24, 2012, 11:51 PM
RWalker is offline
Joined Nov 2011
Here's how to use a servo lead
Old Nov 25, 2012, 10:15 AM
RWalker is offline
Joined Nov 2011
I tried to salvage as much antenna cable that I could from the original plastic antenna and reattached it to the board. If you're following along, just remove the cable from the board. Cut through the antenna enclosure and cut off the cable. It will be replaced with an RP SMA antenna pig tail.
Old Nov 25, 2012, 03:31 PM
RWalker is offline
Joined Nov 2011
I removed the square LED indicator lamp and replaced it with a 5mm 2.5 volt LED with extension wires to mount it on the transmitter case. Did a function check and it works!
Old Nov 25, 2012, 03:39 PM
RWalker is offline
Joined Nov 2011
I did a test run with my current Conquest hack project that is on hold for a FrSky module. Even though the antenna is still in work, I got a good bind from the Tactic receiver.
Old Nov 25, 2012, 04:24 PM
RWalker is offline
Joined Nov 2011
If I were to install it in the Conquest, this is where I'd place it, anywhere on the back of the case above the trainer plug. You can also solder a servo lead to the black (gnd) red (power) and blue (ppm) wires of the trainer plug and pick up connections to the Anylink from there. In this case, I picked it up from the board trainer ports. I'd also drill a 5mm hole for the LED in the top of the back case half. Now I'm on hold for an SMA connector to join up the new antenna.
Old Nov 25, 2012, 08:48 PM
Aerospacer is offline
Find More Posts by Aerospacer
ab amicis auxilio parvulo
Aerospacer's Avatar
United States, MN, Big Lake
Joined Sep 2003
Check out this AnyLink inside
Over the last year I too have been converting older 72MHz radios of Futaba, Airtronics and JR to 2.4Ghz, in various hack modules either from FrSky or in the case of Airtronics even their own 2.4GHz RF modules.
In another vane, I picked up a Spektrum DM9 module to update some JR 72MHz module Transmitters (XP783) to DMS2. I discovered that Horizon sells the case for the DM9 module without the RF board to allow people who bought an older cumbersome Spektrum module that they first produced for JR module transmitters.
Like you, I wondered how a AnyLink RF module board would fit into the DM9 case. Well, fit it does. With the antenna included in the DM9 case, you don't need the AnyLink antenna or coax lead at all. For the plug connector I used an old LiPo battery balance plug and soldered the wires to the appropriate pins on the AnyLink board. And the DM9 case is translucent so the LED on the AnyLink board stays put and the beeper on the AnyLink board is easily heard through the DM9 case.
I have been using my AnyLink "JR Module" now for a couple of months to fly the Flyzone micros that Hobbico sells. No silly cables to connect to the trainer jack and charging jack on my JR XP783.
I even stuck a FrSky V8HT hack module in a DM9 case because I like how the antenna arrangement is done on the DM9 case better than the JR module that FrSky itself makes for JR transmitters.
Aerospacer is offline Find More Posts by Aerospacer
Old Nov 25, 2012, 10:46 PM
RWalker is offline
Joined Nov 2011
Hey that's great! How's the range with the new antenna, and how did you attach the cable? Edit-never mind,
I see it in the middle photo
Old Nov 26, 2012, 09:25 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by RWalker View Post
I did a test run with my current Challenger hack project that is on hold for a FrSky module. Even though the antenna is still in work, I got a good bind from the Tactic receiver.
Warning! Never operate the module without a proper antenna as it will overheat and may burn out.
EDIT: Should also have said thank you for this interesting and helpful discussion.
Daedalus66 is offline Find More Posts by Daedalus66
Old Nov 26, 2012, 12:24 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
+1 on that with 2.4 Ghz RF boards, Spektrum has strong warning about that:
http://www.rcgroups.com/forums/showp...8&postcount=12
coriolan is offline Find More Posts by coriolan
Old Nov 26, 2012, 07:44 PM
RWalker is offline
Joined Nov 2011
Point taken gents. I dug up an old WiFi media device I had and scavenged the pig tail and antenna off of it. With the pigtail attached, I'm ready to put this in a radio.
Old Nov 26, 2012, 08:38 PM
Aerospacer's Avatar
Joined Sep 2003
Coax connection to AnyLink board
I initially considered trying to put a micro coax jack onto the AnyLink board where they had soldered the pigtail for the antenna. The Spektrum DM9 module comes with a micro connector on the end of its pigtail.
I found as source at:
http://www.newark.com/hrs-hirose/u-f...-50/dp/50P8856
But these jacks are surface mount which I have no experience or soldering equipment to do that kind of work so I went with carefully soldering the much smaller DM9 coax pigtail onto the AnyLink. Added a gob of hot glue for strain relief.
My hybrid module has every bit as good range as the original AnyLink package did.
Old Nov 26, 2012, 08:48 PM
RWalker is offline
Joined Nov 2011
The Conquest!
I decided to install it in one of two Conquest radios I got off ebay. The Anylink module's low profile is perfect for mounting on the back of the Tx case. I drilled the hole as planned for the LED ; a press fit works just fine. Everything fit just fine, make sure the wires clear the battery case and the PCB. Once assembled, it looks like it was made for 2.4ghz. Ground and air tests will follow.
Old Nov 26, 2012, 09:30 PM
Aerospacer's Avatar
Joined Sep 2003
Nice fit in the Conquest. How audible is the beeper on the AnyLink board when its inside the transmitter case?
Think you'll soon want to progress to a multiple model memory transmitter. An economical choice would be something like the JR XP652 which can be had for under $50. Since the AnyLink can switch the JR channel sequence to that of a Futaba, all the Hobbico Flyzone micros are in play for that.
Old Nov 26, 2012, 10:10 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I decided to install it in one of two Challengers I got off ebay. The Anylink module's low profile is perfect for mounting on the back of the Tx case. I drilled the hole as planned for the LED ; a press fit works just fine. Everything fit just fine, make sure the wires clear the battery case and the PCB. Once assembled, it looks like it was made for 2.4ghz. Ground and air tests will follow.
Neatly done!
Discussion AnyLink: Fly a model with Tactic brick with Spektrum TX, etc Gordon Johnson Scratchbuilt Indoor and Micro Models 314 Jul 04, 2014 12:40 PM
Article Great Planes F-86 Sabre Micro EDF with AnyLink Review CSpaced Micro EDF Jets and Power Systems 248 Jun 16, 2013 07:07 AM
Cool Confessions of a Put-Put user... redlite Steam Boats 21 Mar 27, 2013 11:46 PM
Discussion wow game changer anylink semeraro Micro Ready-to-Fly 52 Feb 02, 2013 09:29 AM
Question can i put an anylink on a rtf transmitter smithvail Electric Plane Talk 5 Jul 24, 2012 06:10 AM
