Old Mar 07, 2013, 12:59 PM
QQHeaD is offline
Find More Posts by QQHeaD
Russian Federation, Murmanskaya oblast, Kirovsk
Joined Nov 2011
Originally Posted by raipe View Post
Ok, thanks for the info. Is there a brand/marketng name for the foam or just styrofoam? The stuff that is sold in Finland as styrofoam is nothing like the one in your pics. It's white, kinda bubbly and brittle. Jist wondering if we'd have something similar.
raipe
http://www.tn.ru/catalogue/technoplex/
QQHeaD is offline Find More Posts by QQHeaD
Old Mar 07, 2013, 02:29 PM
raipe is offline
Find More Posts by raipe
raipe's Avatar
Finland
Joined Oct 2008
Thanks, i'll check that out.
raipe
raipe is offline Find More Posts by raipe
Old Mar 10, 2013, 10:57 AM
nakayan is offline
Find More Posts by nakayan
nakayan's Avatar
tokyo japan
Joined Feb 2007
QQHeaD great job
Looking forward to.
Please, I want to pdf settings and the position of the center of gravity, for reference.
nakayan is offline Find More Posts by nakayan
Old Mar 10, 2013, 01:35 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
Nakayan,
Thanks For the Data Info/CoG
You wouldnt happen to have the slices from the intake or the canopy cross sections?
Im building at 100% out of foam. Hopefully a bit lighter when completed.
Some pics included
D_FAST is offline Find More Posts by D_FAST
Old Mar 11, 2013, 03:52 AM
meerkat13 is offline
Find More Posts by meerkat13
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Beautiful work D_FAST,
Have you used this method of construction before?
meerkat13 is offline Find More Posts by meerkat13
Old Mar 11, 2013, 10:17 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
meerkat13
I've built some of "Beanie's" builds. That uses formers on a plan form, and skins.
Nothing like this though.
I mainly wanted to get my feet wet with this style of building.
As im wanting to develop some of my hot wire designs into short kits,wanted to see how all this works.
Got her off the jig last night so I can begin skinning the bottom.
Old Mar 11, 2013, 12:33 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Nice work D!
Eric B.
AirX is offline Find More Posts by AirX
Old Mar 11, 2013, 01:47 PM
meerkat13's Avatar
Joined Jan 2013
Wow... You don't hang around!
Great work
Old Mar 12, 2013, 02:12 AM
bobby67 is offline
Find More Posts by bobby67
crash rc plane is my job....
bobby67's Avatar
Florence area,Tuscany, Italy
Joined Jan 2009
great job guys!
I hope to have soon the laser parts cut and begin building.
There'll be grateful if someone posts the formers of airduct. Many thanks.
Roberto
bobby67 is offline Find More Posts by bobby67
Old Mar 12, 2013, 10:54 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
more completed
Old Mar 12, 2013, 03:29 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
Originally Posted by bobby67 View Post
great job guys!
Roberto
Once i verify mine are correct ill be more then glad to post them.
still hoping for the intake cross sections so i dont have to model them myself.
found here http://www.youtube.com/watch?feature...FLOKWtBg#t=11s
Old Mar 13, 2013, 10:35 AM
bobby67 is offline
bobby67's Avatar
Joined Jan 2009
I saw part of the video ... those guys did not put the airintake, only the lip. I think I am going to use same system, simple and less weight ....fuselage is big and there are no problems of air flow. I have 2 cs 10 blade with outrunner for 4s ready...dinamically balanced...
Old Mar 14, 2013, 03:58 AM
AR56 is offline
Find More Posts by AR56
Joined Mar 2013
Nakayan,
AR56 is offline Find More Posts by AR56
Old Mar 14, 2013, 06:13 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
Moving along quite well
It has been awhile doing skins like this.
As my brother worked out the wing
I tackled the rest of the skins on the fuselage,
Now the wing was a pain in the bum!
Nothing seamed to line up with the wing plan.
Chord Spar was like 2 in longer then plan, once cut
Many ribs just didnt line up when inserted to the spar when over layed on the plan
Feet/riser location off on the plan.
Washout seams to take a wicked step up instead of a nice smooth taper or angle
Leading edge didnt seam to flow in a nice straight line either when set on the feet
A lot of work went into figuring all this out and to correct these. The overall wing panel great! My brother did a bang up job on it.
Im not knocking the free plans at all.
But when i imported it to cad these problems arise there as well.
I mentioned back on the first page i was seeing some errors.
Then Nakayan, chimed in with his laser cutting vid,etc....
Majority of the fuselage cross sections, you can run a dividing line down the center and nothing matches as far as left to right.
Another words if i mirror one half of a former, it doe not match the original.
If i was to take a guess, the 3d model was done as a whole, and not 1/2 then mirrored so everything is symmetrical.
So one has to make sure everything is level then jigged while your building! Do Not count on the notching and interlocking tabs, chekc double check triple check then glue.
This one is not fo the indeterminate builder that is for sure
They are free, and i know how much time it takes to model and cad for RC plane so ill take it as it has come to me.
Its another reason why i went with foam. as i didnt want to plunk down the cash for a laser cut to find all the headaches which i knew was there.
@ QQHeaD
Did you notice any of these problems, or did you do foam cores? Cant tell from the flicker images.
Weight will determine that for me.
I'm leaning toward the dectrum 70's
for 4s/5s, comes bundled with esc's and servos an added bonus.
2 of these units weighs as much as 1) 10 bladers
Anyways more pics.
Thanks again for the set of plans Nakayan !
Old Mar 14, 2013, 01:25 PM
nakayan is offline
nakayan's Avatar
tokyo japan
Joined Feb 2007
Awesome! Amazing! D_FAST
Do you need data of the intake lip?
Please stick together with a thickness of 3 mm balsa.
Enjoy!
Discussion Alenia Aermacchi M346 1:20 vittoriofi Micro EDF Jets and Power Systems 8 Mar 12, 2012 03:30 AM
Discussion Build Off II, Alenia G222 AirX Scale Kit/Scratch Built 37 Apr 28, 2008 08:47 PM
Discussion Aermacchi M-346 deca78 Electric Ducted Fan Jet Talk 3 Nov 07, 2007 01:48 PM
EDF50 Aermacchi M-346/Yak-131 EDF Mike77 Electric Ducted Fan Jet Talk 0 Oct 26, 2005 05:29 AM
GPH 346 (SE) with OS .46 like new will trade for logo 10 hanglider Aircraft - Electric - Helis (FS/W) 1 Jul 07, 2002 12:13 PM
