Old Nov 24, 2012, 09:51 PM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
Retractable landing gear for a Bellanca Cruisair
Folks, I'm intending to build up this Guillow r/c model kit I've had for many years. I hope to install retractable landing gear, and this model Bellanca retracts its wheels by swinging them straight back.
I'm looking for suggestions from the group as to how this might be accomplished while not using model landing gear retracts turned 90 degrees and relying on the downlocks to keep the landing gear legs in place. I suspect that any substantial rearward force would break the downlocks. I don't think any of them were meant to take landing loads from that direction, it's like a very heavy side load if the retracts were used conventionally, swinging inwards. If someone knew of how I might modify some retracts for a Corsair or a P-40 so as to defeat the twist, that might be a solution, but again I don't want to overload a downlock.
Thanks very much.
PeterH is offline Find More Posts by PeterH
Old Nov 24, 2012, 10:32 PM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Maybe use two nose gears and lock the steering?
James
Deuce is offline Find More Posts by Deuce
Old Nov 25, 2012, 11:36 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
If you have converted any small Guillows kit to electric power successfully you know how important it is to keep the all-up weight down so that model can fly in a scale-like manner without being continuously on the verge of a stall. Consider leaving the gear off, hand launching, and belly landing on grass.
E-Challenged is offline Find More Posts by E-Challenged
Old Nov 25, 2012, 12:38 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I had to look that one up to see what happens. It seem to be basically like this animation -
eflightray is online now Find More Posts by eflightray
Old Nov 25, 2012, 02:40 PM
PeterH is offline
Granby, CT, USA
Joined Jan 2001
Guillow Bellanca Cruisair
This is not a converted freeflight model. Guillow sold a C-170 and the Bellanca as 1/2A scale r/c models, the Bellanca has a 42-inch wingspan. My conversion work is to build it with an electric motor, not a TeeDee.
And that's one nifty animation, too!
Thanks, folks.
Old Nov 25, 2012, 04:04 PM
Dennis Sumner is offline
Find More Posts by Dennis Sumner
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
United States, MI, Canton
Joined Sep 2002
I am working in plans for a 1/8 scale Bellanca Cruisemaster and I plan in using E-Flite 15-25 90 degree retracts. I believe they lock pretty good and could replace the trunions with Aluminum ones if needed.
Dennis Sumner is offline Find More Posts by Dennis Sumner
Old Nov 25, 2012, 04:14 PM
GeoffinIN is offline
Find More Posts by GeoffinIN
Two left thumbs
Muncie, IN
Joined Sep 2006
A simple torque tube to each leg and a single servo in the wing root should suffice,
especially if you do an over-center setup for down and locked.
I like this bird - among my favorites!
Geoff
GeoffinIN is offline Find More Posts by GeoffinIN
Old Nov 25, 2012, 10:58 PM
PeterH is offline
Granby, CT, USA
Joined Jan 2001
Torque tube
Geoff, let me see if I'm following what you've suggested - - - landing gear strut is attached to a torque tube which has an arm driven by a servo. Down locking is achieved by the geometry of the servo output arm. If it's in line with the drive rod coming from the landing gear control arm, any landing gear rotation loads are passed through the servo to the servo mounts and don't have much effect on the servo gears, the servo case takes the load.
Please speak up if I'm missing the point. Thanks for the suggestion.
Old Nov 25, 2012, 11:07 PM
Deuce is offline
Deuce's Avatar
Joined Jul 2006
While I might be a bit presumptuous to speak for Geoff, I would tend to agree with your thinking. However, may I suggest the servo drive a "tiller" arm that would take any loads transferred by the gear, instead of the servo taking the loads?
It might even be easier to find a more suitable place for the retract servo, as the tiller is not as bulky...
Just thinking out loud!
James
Old Nov 26, 2012, 11:27 AM
Joined Oct 2000
Thanks, folks.
Forgot about the Guillows' 1/2A scalers, sorry! The Cruisair is a favorite of mine too.
Old Nov 27, 2012, 09:06 AM
Two left thumbs
Muncie, IN
Joined Sep 2006
James's suggestion makes sense - for a heavier bird. I think even a mini (not micro) 90° retract servo such as the Waypoint W150MGR will take the load with ease. It weighs under 16 grams, has 52 oz/in torque and will fit in the battery tray shown on the wing center section of your plan. Set it up so it goes 180° while the arm on the torque tube goes 90° (servo arm 1/2 length of torque tube arm) and it'll hold the undercarriage down and up very well! I'd rubber mount it so it has some spring - just in case!
Geoff
Old Nov 27, 2012, 01:04 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
More info: I've attached a photo of the undercarriage showing that Eflightray's animation is spot-on. I found my factory drawings (obtained from the Smithsonian Institution) and found the center-to-center of wheels measurement of the full scale bird is 8' 10 5/8". They cant inwards, so the upper dimension would be about 2" less. Since the wheels are on the outside, you'll need to run the torque tube (if you choose to do it that way) through the plywood G 4 rib
Old Nov 27, 2012, 01:17 PM
jhspring is offline
Find More Posts by jhspring
Oh no, not again!
jhspring's Avatar
United States, LA, Carencro
Joined Dec 2005
For a model this size, the simplest ( and probably close to the lightest) solution would be electric retracts. http://www.pw-rc.com/product_info.ph...oducts_id/2386 They are designed to be used in models like the P40, so the strut can be set to rotate the wheel as the gear retracts. In other words, they were designed to retract straight aft, so the downlocks are engineered for your application. They are 19 gm each, so a pair will cost you about an ounce and a half, which should be more than tolerable, i would think.
Regards,
Jeff
jhspring is offline Find More Posts by jhspring
Old Nov 27, 2012, 05:13 PM
Two left thumbs
Muncie, IN
Joined Sep 2006
Jeff, the wheels don't rotate on the Bellanca - they hang out in the breeze about halfway, so rotating retracts would have to be modified.
Geoff - spelled the old-fashioned way
Old Nov 27, 2012, 06:47 PM
Joined Sep 2002
Regards,
Jeff
I agree but use normal non rotating 90 degree units. The Cruiseair and Cruisemaster have the gear retracting back with about 1/2 the wheel showing....
Denny
"bellanca cruisemaster" r/c model airplane kit bayou_city_boy Non R/C Items (FS/W) 1 Nov 16, 2012 09:15 PM
Sold Guillows Bellanca Cruisemaster bayou_city_boy Aircraft - Fuel - Airplanes (FS/W) 1 Nov 16, 2012 09:15 PM
WTD--plans for a bellanca cruisemaster mle2tie Aircraft - Electric - Airplanes (FS/W) 1 Nov 23, 2004 06:22 AM
Question Elec pwr for Guillows Bellanca Cruisemaster Capt Crash Scale Kit/Scratch Built 1 Jul 28, 2004 03:42 PM
Bellanca Cruisemaster agpilot24 Scale Kit/Scratch Built 12 Jun 27, 2001 07:18 PM
