Old Nov 24, 2012, 08:38 PM
crashwilson is offline
Find More Posts by crashwilson
Joined Oct 2012
Radial engine
Building a 1/3 scale Sopwith pup. I would like to puy the new Evalution 77cc radial on this plane.Has anybody used this motor? and are they hard to keep running?
crashwilson is offline Find More Posts by crashwilson
Old Nov 26, 2012, 06:05 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Wilson,
The maximum reasonable size for a glow engine is about 10cc...
Running any engine on gasoline uses ~40% of the fuel, which costs about 1/10...
And it is 'Evolution'. This engine is modestly priced, compared to Technopower... It is a novelty.
DarZeelon is offline Find More Posts by DarZeelon
Old Nov 27, 2012, 02:38 PM
Brutus1967 is online now
Find More Posts by Brutus1967
I convince things to work
The Netherlands
Joined Nov 2009
Not really.... the maximum reasonable cylinder size (if there is such a thing) is 10~15 cc for glow....
There is thermodynamically and mechanically not much difference between 7 single cylinder 11 cc fourstroke engines and one 77 cc 7 cylinder radial (except for the crankcase, crankshaft and conrods of course).
It would be a whole other story if it was concerning a 77 cc 2 cylinder or single cylinder, but the problem is in the physical dimensions, not in the total number of displacement.
So a 77 cc radial might be a very feasible project on glow, and a very thermodynamically challenged project on gas.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Nov 27, 2012, 02:59 PM
DarZeelon's Avatar
Joined Nov 2003
Bert,
I was referring to total engine displacement and actual fuel consumption (and cost).
Besides, there are glow engines with ~50cc displacement cylinders; specifically gas engines that some in the U.S.A converted to glow ignition.
Old Nov 27, 2012, 03:54 PM
The Netherlands
Joined Nov 2009
I know, and with respect to a 77 cc being not really economical on Methanol you are completely right.... (never meant to contradict that)
But with respect to how small a cylinder unit you can operate on gas, that is a completely different thing.... for an engine to be economical you first need it to be able to run. And the smaller the cylinder units become, the harder it gets to run it on gas....
OP was asking about a 77 cc radial, not a 77 cc single.
Economical or not, methanol might be the best solution still, if OP still prefers a radial instead of an economical but very unscale single cylinder gasser .
these big glow engines, they were done mainly when magneto's were still big and heavy, CDI units not readily availlable, and gassers did not develop really heaps of power like nowadays. Than a glow-conversion gives an instant weight saving of up to 50% of the engine weight and an immediate power boost of 20% (at the cost of a very high fuel bill)
Brgds, Bert
Old Nov 27, 2012, 04:11 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That is sort of a new engine and I think there has been somewhat limited availability with it here in the USA. Siedel had made a number of them before, but I don't think any of them made it into the USA. When I took a look around I didn't see anything but the marketing videos for the engine. But the videos I saw did show the engine being run quite well on a test stand though.
Now there is a guy at our local hobby shop who is putting one of these engines in a large 3D aerobatic plane. But he seems to have stalled on finishing it so far.
DarZeelon, I can agree with a large displacement glow engine can consume glow fuel at a prodigious rate. But if one isn't using full throttle all the time the fuel consumption is a lot more manageable. I do that with a big 30cc glow engine powered plane and it does quite well with a 16 ounce fuel tank like that. But also glow fuel provides a considerable amount of cooling for a glow engine that you don't get using gasoline. So with a big radial engine, the glow fuel could be a benefit in a cowled engine setup on a plane.
One other issue is getting a spark ignition system for a radial engine is a real problem. There just aren't any out there so far. I know some people have been working on radial engine ignition systems that are all electronic (no distributor), but I don't think they are ready for production yet. So the radial engines are mostly limited to glow ignition at this time. Albeit there are a few exceptions where the engine has a distributor built into it for spark ignition.
earlwb is offline Find More Posts by earlwb
Old Nov 28, 2012, 01:35 AM
DarZeelon's Avatar
Joined Nov 2003
Bert,
The smallest current production gas engine that I know of; is the NGH 9cc.
In the far past, before the advent of the glow-plug, all engines; even as small as 0.5cc, had spark ignition and used gasoline.
The boost in actual output by converting an engine to glow, is 24% (Stoichiometric ratios).
A .52 gas engine makes the same power as a .40 glow; and is virtually the same size and weight; so this is hardly a problem.
Earl, you are right regarding the ignition issue. It is a problem for small multi-cylinder engines...
Old Nov 28, 2012, 07:49 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I figure, that if you can afford one of these radials, the cost of fuel is a mute point.
Crashwilson: Many who operate large, multi cylinder glow engines, use onboard glow systems to aid in operational reliabilty. Incomparison to the cost of the engine, these units are inexpensive, and provide piece of mind .
These units have proven to be reliable. http://www.sonictronics.com/xcart/home.php?cat=308
TomCrump is offline Find More Posts by TomCrump
Old Nov 28, 2012, 11:51 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Bert, what are your concerns about gasoline in a small engine?
Greg
gkamysz is offline Find More Posts by gkamysz
Old Nov 28, 2012, 10:41 PM
Joined Oct 2012
Radial Engine
this is crashwilson calling!!! Thanks all you guys out there who took the time to try and help me out with my questions on the Evalution 77cc Radial.I don't mind spending a few bucks for fuel for that engine if that is the biggest concern.I just want to build this plane as true to scale as possible, and that engine would be the icing on the cake.I just don't want to get into an engine that I have to work on every time I fly it.Again thanks for the replys.
Old Nov 29, 2012, 08:54 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
A club member has asked for advice on his, but hasn't finished the airplane yet, so I haven't seen the engine. These engine burn 0-10% nitromethane and 6-8% oil after break in, so the fuel isn't particularly expensive.
Greg
Sold 9-Cylinder 99cc 4-Stroke Glow Radial Engine by Evolution Engines ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 14, 2012 09:08 AM
Sold 7-Cylinder 77cc 4-Stroke Glow Radial Engine by Evolution Engines ibcinyourc.com Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 14, 2012 09:03 AM
Discussion Beautiful engines radials Alain RONK Engines 12 Mar 21, 2012 12:51 AM
Sold Saito FA170R3 Radial engine --- SPF Stoneke Aircraft - Fuel - Engines and Accessories (FS/W) 3 Mar 19, 2012 09:15 AM
Sold Last Chance: Museum Quality 9 cylinder radial engine flyboy101 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 23, 2012 11:35 AM
