Old Nov 24, 2012, 05:13 PM
Stretch1 is offline
Find More Posts by Stretch1
Happiness is a warm ESC.
Stretch1's Avatar
Ballarat Vic. Australia
Joined Jun 2008
OSE Mini Outboard Seizure
G'day Guys,
Last week I bolted one of these legs ( http://www.offshoreelectrics.com/pro...prod=OSE-80980 ) to one of my F1 hornets.
My leg is a bit different from the one pictured on the OSE website. ( Different motor mount and an extra brass fitting.)
After some mucking about setting up an acceptable pushrod setup (600 heli ball joints/pushrods and some modified nylon control horns) I dropped her in the dam last night.
Power was great, motor stayed cool and battery/esc temperature was ok. Things were going great for a few minutes, and then I lost drive when the flex snapped.
I launched my inflatable and recovered the Hornet to find that the propshaft was seized solid. ( I'd lubed the flex before putting the boat in the water.)
I needed vise grips to liberate the prop shaft frop the screw in bush at the end of the leg. This bush isn't brass, and appeared to be "welded" to the steel propshaft. ( I've attached a pic, the bush looks like copper.)
With the inspection plate removed there appears to be a 'total loss' lubricant reservoir above the flex shaft, fed at the top with a barbed brass fitting and draining at the bottom with a small opening presumably to lubricate the prop shaft bush.
I've deburred/polished the inside of the prop shaft bush with some abrasive paste and my spare prop/flex shaft shows no sign of any binding.
I'm about to reassemble the leg to try things out again and was wondering if anyone else had played with these legs and had any issues.
I'm going to try some synthetic engine oil in the reservoir, is this the right method of attack? I've got a fair idea about things that fly ( helis, sailplanes, airplanes and multi rotors ) but I'm a newbie when it comes to boats so any advice is welcome.
Stretch1 is offline Find More Posts by Stretch1
Old Nov 25, 2012, 06:20 AM
wparsons is online now
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I know a couple other people on here have bought them, but I haven't seen anyone else post about failures. Generally you want thick grease for boats, oil just washes away too quickly.
wparsons is online now Find More Posts by wparsons
Old Nov 25, 2012, 12:31 PM
tsenecal is online now
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
i am curious how many cells you are running through this... i am using a 3 cell setup, and the motor info on offshoreelectrics specifically states 2 or 3 cell only.
this is a video of my MRP running on 3 cells, running around 30mph, which is perfectly fine for this particular hull.
white tunnel ose (1 min 58 sec)
the video is the third or fourth run for that hull, i have a second hull, with an identical setup for motor, battery and esc, and it has been run twice, with zero issues like you describe. I have checked them once for grease, and found no need to regrease. once I have run them for a season, i will know more about their "needs", but i have not seen any abnormal wear anywhere in the drive train.
i am running a larger grimracer prop than stock.
if you are trying to get the most speed possible from this little unit, you might be trying to get too much out of it.
I'm sure you've seen this thread, but the original thread where all my tuning and testing was described is here:
http://www.rcgroups.com/forums/showthread.php?t=1702142
tsenecal is online now Find More Posts by tsenecal
Old Nov 25, 2012, 04:15 PM
Stretch1 is offline
Stretch1's Avatar
Joined Jun 2008
G'day guys,
Thanks for the replies.
I'm running on 3S and the unit is well lubricated.
I won't use oil in the reservoir again, as it does just drain away too quickly.
I hit a submerged rock not long before the initial seizure , so now I'm thinking I may have deformed the housing/bush by a few thou', which would be just enough to make it grab when it warmed up. ( It was a pretty big hit.) It started to get tight when I ran it yesterday with the polished bush and new shaft, I left everything to cool down, and it freed up. ( Not that anything was really hot.)
I'm going to try honing the bush before my next test.
Stretch1
Old Nov 28, 2012, 12:54 PM
Chinewalker is online now
Find More Posts by Chinewalker
Chinewalker's Avatar
1000 Islands, NY
Joined Dec 2009
Good info to know! I am planning on clamping one of these on the back of my outboard utility...
http://www.rcgroups.com/forums/showthread.php?t=1591892
Chinewalker is online now Find More Posts by Chinewalker
Old Nov 28, 2012, 03:57 PM
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
the hobbyking hornet is also considerably larger and heavier than my MRP tunnel hulls, it weighs almost twice as much, and is 7" longer. you might be better off going with one of the larger "500" size outboards like the proboat motor available on offshoreelectrics.com http://www.offshoreelectrics.com/pro...rod=dh-PRB4020 I know it is considerably more expensive (twice the price if you include the cost of the actual motor), but it would be able to handle considerably more abuse than the little one.
Old Nov 28, 2012, 06:28 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I don't think the Hornet is that much bigger.... it's 29.5" with the motor.
Sold OSE Built Rigged Insanity NEW Diegoboy Boats (FS/W) 6 Nov 03, 2012 06:19 AM
Build Log 1980 Outrigger with an Electric Outboard - Changed to Predator Outrigger w/outboard Dave8888 Racing Boats - Electric 22 Oct 08, 2012 07:15 PM
Sold Vintage Outboard Cabin Cruiser Fiberglass Hull and Deck for K&B Outboard? Tollytime Boats (FS/W) 2 Jul 25, 2012 03:58 PM
Alert ****MMEU Hosts the 2012 P-Shoot Out Sponsored by OSE**** longballlumber Racing Boats - Electric 2 Mar 28, 2012 02:12 PM
Alert New 5692 Mounts in at OSE!! scorpion1 Racing Boats - Electric 26 Mar 04, 2012 03:38 PM
