Nov 24, 2012, 04:10 PM
New in Box G10 OUTRAGE G5 Flybar Head Kit w/ Fiberglass Blades KRG5000
New in Box G10 OUTRAGE G5 Flybar Head Kit w/ Fiberglass Blades KRG5000.
New in Box kit all packages still sealed, small crease back tip of one side of the canopy. $250 including shipping and paypal fees.
Designed by the well-respected helicopter designer Charley Stephens, this new heli defines a new concept of low head speed, high voltage micro helicopters. With super low amp draw (average 9amp compared to 25A of other 450 size helicopters) this chopper can perform incredibly double 3D flight time compared to its rivals on a single pack of battery at unbelievable 2400rmp head speed. With programmable head and tail, this heli is so versatile it can be suitable for beginners to highest demand 3D pilots.
Outrage Specifications:
Length: 620mm
Height : 210mm (including head button 203mm without)
Main Rotor Diameter: 775mm
Tail Rotor Diameter: 157mm
Blade Length:350mm
Main Gear 150T .5 mod gear
Auto Rotation 106T
Drive Gear 25T
Flying Weight 780-850 Grams depending on equipment used
Black plastic tail blade
Black fiberglass 350mm main blade
Painted fiberglass canopy
Black G10 fiberglass frame and landing gear and fin set
Manual included
Kit Only. No Electronics Provided.
Beautifully crafted CNC anodized parts
True 120 Degree CCPM Servo layout for precision control and geometry
Compact frame height for enhanced 3D fight characteristics
Large adjustable battery tray positions for various battery shapes and sizes
Fiberglass 350mm extremely stable blades
15 Degrees +/- achievable pitch ranges
Programmable head - From Mild to Wild
Thrust bearings on main blade grips
One piece 3D dampers
Ceramic main and tail rotor shaft support bearings
High quality screw hardware
Programmable tail rotor ratios 11t included for 4.664:1, (10t Optional for 4.24:1), (12t Optional for 5.088 :1)
Ball raced double pivot tail control system
High quality tail rotor drive belt
Fiberglass painted canopy
Parts compatibility with other brand helicopters for most crashes.
