The Gerber-files etc. will be available when the PCB have been tested. PCB's from Seeedstudio is around 14$ for 10 pieces with shipping, that's hard to get any cheaper. The PPM-in is not done yet, but have a few ideas ![]() I will use it for signal-information with EzUHF as well. |
Brian |
I use a bootloader on the microcontroller, which means it only have to be programmed once with programmer. All vias was original made just big enough to fit the normal wires used with arduino etc. and not tented for debugging, programming etc. But I have to admit, that it have been changed in the latest version (as I hope it will be the last version, unless someone have some good ideas). Some vias have been made a bit smaller, they are all tented and some traces have been re-routed to avoid vias. I use this one to program, as it's a lot easier and I have quite a few things with Atmega controllers: http://www.hobbyking.com/hobbyking/s...hing_Tool.html I gotta admit that makes it a bit more difficult if you use a normal programmer, but it should be doable (Vcc gnd and reset are easy available). By the way, max los have just been increased to 460 kilometers or something crazy like that. By request from a user who plan to take it for a little ride ![]() Will be included in next release |
I've updated the firmware. Not much have been changed, the major difference is the huge increase in max LOS by request
![]() http://code.google.com/p/diy-osd-max7456/ |
.I hate to ask, but IMHO for widespread acceptability, the ease of programming is going to be directly proportional to how far it gets accepted by the community. with no 'easy' programming method, I feel it will stay at the 'hacker' level and not move more mainstream and a bit of board space may be worth this for a larger audience. this could be accomplished through a isp connector to burn the arduino boot loader and then 6 pins in a row so people can use a ftdi adapter for programming from the arduino environment. what are you designing this in, maybe I can help? i am pretty familiar w/ eagle and decent w/ diptrace. bob4432/Brian |
No, battery power here, well video, Rc & ing. use batteries. Forward motion is gas 4 stroke. I'll need a couple of months to get it worked out. Just found a new flying site that should me 100 miles (160km) without to much trouble. I'm really looking forward to using Dennis's OSD here.
Marc |
![]() Unfortunately you are right about the ICSP header, but as I didn't expected many to actually use the design I haven't considered it much. But I'll have a look at it, it should be possible to add space for a ICSP header somehow. It's designed in Altium... Quote:
| Thread Tools | |
| Help! OSD version UNKNOWN and fail to update (error) | dROb | Eagle Tree Systems | 9 | May 16, 2012 05:12 PM |
| Sold EASY OSD (Version 1.2) Brand New . $75 shipped. | LHTPlane | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 20, 2012 10:45 PM |
| For Sale MAX7456 OSD Break out board. | ziomatrixacs | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Jun 18, 2011 03:50 PM |
