Old Aug 18, 2013, 12:33 PM
David Parry is online now
Find More Posts by David Parry
It only cost Ģ50 honest!
David Parry's Avatar
United Kingdom, Bracknell
Joined Oct 2007
For those using a Neo 6M gps did you have to change the GPS's config at all?
Need to order one and not sure if it uses a mixture of NMEA and binary or just NMEA.
If not What one should I get? Flytron out of stock.
David Parry is online now Find More Posts by David Parry
Old Aug 23, 2013, 01:51 PM
absolute-zero is offline
Find More Posts by absolute-zero
absolute-zero's Avatar
Joined Sep 2004
Originally Posted by infall View Post
I am interested in the OSD, want to test it. I only have minimOSD. Can you tell me, how to upload the firmware and how to use it?
I have just installed DFOSD on a minimOSD, and it works perfect.
Use Arduino 1.0.5 and ISP-Programmer
1. Open Arduino
2. Burn bootloader using programmer
3. Open and upload: Character_Uploader_MinimOSD.ino
4. Reboot OSD
5. Open and upload: MAX7456_OSD_MinimOSD.ino (reconfig config.h if needed)
6. Reboot OSD
= Working DFOSD on minimOSD
absolute-zero is offline Find More Posts by absolute-zero
Old Aug 28, 2013, 02:38 AM
msev is online now
Find More Posts by msev
Joined Sep 2010
Has anyone tried Minimosd code on this hardware?
msev is online now Find More Posts by msev
Old Aug 28, 2013, 02:12 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Deleted - misunderstood the question
Nope, don't think anyone have tried the MinimOSD software on this hardware. You can be the first
Dennis Frie is offline Find More Posts by Dennis Frie
Old Aug 28, 2013, 03:49 PM
mateuszganko is offline
Find More Posts by mateuszganko
Joined Sep 2012
I try you have to change analog input pins and void MAX7456Configure() and working very well
void MAX7456Configure() {
// todo - automatically recognising card.
if(Settings[S_BOARDTYPE] == 0) { // Rush
MAX7456SELECT = 10; // ss
MAX7456RESET = 6; // RESET
if(Settings[S_BOARDTYPE] == 1) { // MinimOSD
mateuszganko is offline Find More Posts by mateuszganko
Old Aug 29, 2013, 06:45 AM
msev is online now
Joined Sep 2010
Does auto-baud detection also work for Neo-6m ublox gps?
Mateuszganko do you use this code on Mavlink version (for Arducopter) or MSP version ( for Multiwii)....Do you maybe use "Minim-osd extra" code project?
Old Aug 29, 2013, 04:09 PM
Just another user
Joined Feb 2011
It should auto detect baud-rate on all GPS-modules with a UART-output, as long as the signal-strength is within the normal range. A normal 3.3 V device is acceptable as a 3.3V signal will trigger the logic "high" on Atmega328, but if the signal is a lot lower than that, chances are logic levels will not be detected.
Old Aug 30, 2013, 05:35 PM
Joined Sep 2012
Software I use R345 KV TEAM
you need to change analog voltage pin to 0 and change the voltage divider, for example, replace the 10k resistor to 47k because MWS has analog 1V internal reference. Change ISP to FTDI by the way much faster you upload the software
Old Sep 02, 2013, 04:42 AM
infall is offline
Find More Posts by infall
David(bg2vcj)
Joined Nov 2008
1. Open Arduino
4. Reboot OSD
6. Reboot OSD
Please Tell me:
1.Arduino 1.0.5 ----tools---Borad---Type
2. MAX7456_OSD_MinimOSD.ino (reconfig config.h if needed)
Modify those items , there are examples of it ?
Thanks.
infall is offline Find More Posts by infall
Old Sep 02, 2013, 07:43 PM
Joined Sep 2004
Please Tell me:
Thanks.
1. I use AVRISP mkII
2. Reconfig = Select the data you want the OSD to show, and where you want them to be shown. Standard setting is fine.
Old Sep 04, 2013, 01:31 AM
mbanzi is offline
Find More Posts by mbanzi
United States, CA, San Diego
Joined Jul 2011
Fried my OSD :(
In my rush to complete a 2nd OSD, I hooked up a 3S LiPo directly to Vcc on the board, instead of using the 5V wire (which is the same color).
The MEGA328 is definitely fried. What other components will likely have gotten damaged?
mbanzi is offline Find More Posts by mbanzi
Old Sep 04, 2013, 02:23 AM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
The 7456 may or may not be ok. IIRC some were spec'd for above 12v operating voltage, and some were spec'd for the normal 5.5v. If a GPS was connected it's probably toast too.
Other than that, everything else is passive and should have avoided damage.
Legot is offline Find More Posts by Legot
Old Sep 06, 2013, 02:00 AM
mbanzi is offline
Joined Jul 2011
Thanks! Turned out only the Atmega328 was fried. GPS thankfully survived too. OSD is up & running again.
Old Sep 06, 2013, 03:11 AM
martinic is offline
Find More Posts by martinic
FPV Enthusiast
martinic's Avatar
New Brunswick, Canada
Joined Nov 2004
I'm using the firmware with a minimosd and the characters seem translucent. They're still readable, but they can be difficult to see at times.
Is there a setting to make the fonts more opaque? I've looked through the code, but nothing stands out.
martinic is offline Find More Posts by martinic
Old Sep 06, 2013, 10:38 AM
Just another user
Joined Feb 2011
The white-level of the characters can be configured on MAX7456. As the default value should work well, it haven't been added as an option in config.h though.
I canīt remember if the levels are being configured in the initialization, you probably have to look a bit on the code, if you want to change it.
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
