Old Aug 11, 2013, 11:57 AM
absolute-zero is offline
Find More Posts by absolute-zero
absolute-zero's Avatar
Joined Sep 2004
Originally Posted by Dennis Frie View Post
My dropbox is not full
By the way, the smaller OSD PCB with integrated power-supply, GPS and pressure-sensor arrived at the post-office yesterday
It sounds promising. You have to tell if you need someone to carry out a field test.
Michael
absolute-zero is offline Find More Posts by absolute-zero
Old Aug 11, 2013, 12:05 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Michael
If you use 5-volt FPV equipment (Video-tx and camera) I wouldn't mind to get it tested roughly sooner or later
It should be able to deliver a very clean 5-volt supply. It could be interesting to add a 12-volt supply too, but I don't really use 12-volt myself.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Aug 12, 2013, 04:27 AM
Joined Sep 2004
I can create most used setups with following equipment in stock.
Camera: 3x 5V, 5x 7-12V, 2x 12V
AV Transmitter: 3x 3.3V, 2x 5V, 7x 12V
All my FPV systems share power source with the propulsion system, so good filtration is a must.
A 3.3V could be interesting too, for the cheap 5.8Ghz systems.
Regards
Michael
Old Aug 12, 2013, 04:36 AM
Joined Sep 2004
How well is the power supply engineered regarding to electromagnetic radiation?
Old Aug 12, 2013, 02:06 PM
Just another user
Joined Feb 2011
Hopefully pretty well ;-)
With a high switching frequency and good amount of capacitance, the ripple on both input and output, should be kept at a minimum.
The loop on the converter is quite small and should not emit much RF-noise.
I considered a RF-shield to eliminate/attenuate the remaining noise, but with the results from the test-board, it didn't seem to be necessary at all. Even at very close distance, I wasn't able to measure much, if any, noise.
http://www.rcgroups.com/forums/showp...&postcount=140
http://www.rcgroups.com/forums/showp...&postcount=145
- but I'm well aware of the noise-requirements and it have certainly been considered.
Old Aug 12, 2013, 02:23 PM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
What about a SAW filter for the GPS?
Specially if the GPS antenna is small things like the FrSky RX's with telemetry will kill the GPS signal.
Had to bought a GPS with bigger antenna to my copters as I could barely get a 3d FIX when using with FrSky gear.
IceWind is offline Find More Posts by IceWind
Old Aug 12, 2013, 02:30 PM
Just another user
Joined Feb 2011
As I'm using an integrated GPS-unit, adding a SAW-filter is not really possible. I really want to keep it as small and light as possible - if I need large GPS-antenna etc. I will be using a seperate GPS-unit.
Old Aug 13, 2013, 03:01 AM
Joined Sep 2004
Superb..
Old Aug 13, 2013, 03:41 PM
Just another user
Joined Feb 2011
Old Aug 13, 2013, 09:06 PM
Flying Munkee is offline
Find More Posts by Flying Munkee
Joined Jan 2010
Step away for a few months and you come up with that beautiful little thing. Nice work Dennis!
Middle of the video is some footage with v019
Performed flawlessly! Thanks again Dennis.
MonkeyFest 2013 (4 min 36 sec)
Flying Munkee is offline Find More Posts by Flying Munkee
Old Aug 14, 2013, 03:20 AM
mike_o is offline
Find More Posts by mike_o
mike_o's Avatar
Denmark, Nærum
Joined Jan 2012
wow - looking good. Nice work, Dennis!
I have a new test platform standing by
Just mounted the ezUHF Tx/Rx
BTW, I also enjoyed the previous version very much. This is my latest flight:
FPV Falcon Flying Wing, Seaside (4 min 26 sec)
mike_o is offline Find More Posts by mike_o
Old Aug 14, 2013, 02:37 PM
Just another user
Joined Feb 2011
http://youtu.be/lvIu7T2ezjU
I've been quite busy with a lot of other stuff lately, but I'm still around whenever I get time
Looks good from the video, always great to see it in action.
Old Aug 14, 2013, 02:39 PM
Just another user
Joined Feb 2011
http://youtu.be/77uOda9ZHy4
Looks very nice
You should really get the EzUHF and OSD connected, to get RSSI and package information. It's really nice when flying in noisy environments and/or pushing the range.
Old Aug 15, 2013, 04:15 AM
infall is offline
Find More Posts by infall
David(bg2vcj)
Joined Nov 2008
thanks
How to get it to work? Please help
It's working fine here... can you try again?
I'll try and put it in dropbox but my account there is full.
infall is offline Find More Posts by infall
Old Aug 15, 2013, 04:50 AM
infall is offline
David(bg2vcj)
Joined Nov 2008
I am interested in the OSD, want to test it. I only have minimOSD. Can you tell me, how to upload the firmware and how to use it?
Please note that this is just a direct copy of the file uploaded by IceWind, I haven't even unpacked the file
https://dl.dropboxusercontent.com/u/...9_MinimOSD.zip
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
