Old Jun 16, 2013, 08:05 AM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by bob4432 View Post
i would design for the bmp180 baro as the bmp085 is eol and digikey is showing 0 in stock atm of this writing. it is comparable to the bmp085 and should work w/ the same software as i have connected a bmp180 bob to mw and uncommented bmp085 in the firmware and it works, same w/ tc's baseflight (but i haven't looked into his code to see if he put in the bmp180). you could always go the ms5611 too...
Year BMP085 is pretty much "last call". I have a few laying around anyway and figured I would start with them to avoid too many changes.
I will probably use MS5611 later.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Jun 21, 2013, 02:54 PM
David Parry is offline
Find More Posts by David Parry
It only cost 50 honest!
David Parry's Avatar
United Kingdom, Bracknell
Joined Oct 2007
Hi, Just finished reading through this thread, and think I'm ready to start building. Before I order some boards has anyone got a couple extra they want to sell? Bstott have you any left?
Also is the link on page 1 upto date with mouser items?
Am in UK.
David Parry is offline Find More Posts by David Parry
Old Jun 22, 2013, 10:35 PM
tang0_au is offline
Find More Posts by tang0_au
Sutherland, Sydney
Joined Apr 2006
have a couple of queries I hope someone could help with ...
I installed a 100amp current sensor from flytron and calibrated the current display using a volt / amp meter between the main battery and the current sensor - the OSD reads the same as the volt/amp meter when sitting at idle - 0.6amps. however, when I fly I see amps that are higher than I would expect - upto 68 amps with 3s lipo, 1020kv motors & 10x5 carbon props on a tbs disco frame. the MAH used is also incorrect - the OSD recorded about 3300mah (4500 lipo) but when charged the charger only pushed 2780mah into the pack ...
also, the character uploader once run still displays some chinese characters - it mainly affects the small text such as the GPS co-ords & # of satellites -
any ideas as to whats going on ????
thanks
tang0_au is offline Find More Posts by tang0_au
Old Jun 23, 2013, 12:18 PM
Just another user
Joined Feb 2011
thanks
For the 100A current-sensor, the calibration-value should be close to 0.98
// 25 A sensor = 0.24
// 50 A sensor = 0.49
// 100A sensor = 0.98
You can't really calibrate at ~600 mA, as the resolution is pretty bad on the 100A version. I would suggest to use the calibration value 0.98, or do a real measurement with WOT and compare current-sensor and current-reading from a multimeter or similar.
In regard to the character-uploader. All the small numbers are generated automatic in the character_uploader program. That means they are not visible in the normal character-editor.
Old Jun 23, 2013, 04:45 PM
tang0_au is offline
Sutherland, Sydney
Joined Apr 2006
ok - makes sense for the current - thanks ...
but for the small characters on screen - how do I get rid of the chinese characters and get to display with normal 'small' numbers ???
thankyou
Old Jun 23, 2013, 05:02 PM
Just another user
Joined Feb 2011
thankyou
Have you looked at this, its not well updated, but that part should be covered
https://dl.dropboxusercontent.com/u/...OSD_manual.pdf
Old Jun 24, 2013, 04:46 AM
tang0_au is offline
Sutherland, Sydney
Joined Apr 2006
thanks - tried that too - but the screen that shows the entire char set after 'loading default char' still has lots of chinese characters in it ... :/ ??
Old Jun 24, 2013, 05:37 PM
Just another user
Joined Feb 2011
Hmm that's weird. Are you sure that you have uploaded the sketch called Character_Uploader.ino? It can be found in:
MAX7456_OSD_v0_19\MAX7456_OSD_v0_19\Character_Uplo ader
The normal file called MAX7456_OSD.ino will also show all the characters in first/second boot, but that's mainly used as info, to show the characters and indicate that new settings are saved etc (but new characters have to be uploaded with the other sketch)
Old Jun 25, 2013, 04:28 AM
tang0_au is offline
Sutherland, Sydney
Joined Apr 2006
yep - 100% sure am using the character uploader - v 19 - I also tried downloading it again to ensure I hadn't corrupted it somehow - also tried older version - back to v5 .. ! ??
Old Jun 26, 2013, 01:48 AM
SupraGo is offline
Find More Posts by SupraGo
SupraGo's Avatar
Canada, AB, Vegreville
Joined Jun 2009
Did you have the OSD powered when you uploaded the char set?
Bill
SupraGo is offline Find More Posts by SupraGo
Old Jun 26, 2013, 04:53 AM
tang0_au is offline
Sutherland, Sydney
Joined Apr 2006
tried it being powered from the usb or with plugging in main battery ..
Old Jun 28, 2013, 02:36 PM
Just another user
Joined Feb 2011
Sorry guys, work have been crazy lately and I haven't had any time for DIY-projects.
I'll be going on vacation for 3 weeks in a day or so, but won't have access to a computer.
I have a lot of beers to drink and some mountains to climb
See you around
Old Jun 28, 2013, 06:02 PM
BloomingtonFPV is offline
Find More Posts by BloomingtonFPV
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
That must be the mountainous regions of Denmark...
Have a great trip.
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Jun 28, 2013, 06:17 PM
absolute-zero is offline
Find More Posts by absolute-zero
absolute-zero's Avatar
Joined Sep 2004
Have a nice trip Dennis.
I hiked in Norway for a week ago. Always remember to bring some fpv-gear :-)
Picture is taken at Gaustatoppen.
Michael
absolute-zero is offline Find More Posts by absolute-zero
Old Jun 29, 2013, 01:47 AM
Just another user
Joined Feb 2011
Have a great trip.
Sure, the huge mountains in Denmark
Michael
That must have been a wonderfull place to fly. I would really love to bring FPV-equipment, but with 4 people in the car and full mountain-equipment that's not gonna be easy...
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
