![]() But with that being said, HF is not very good as a DIY-projects, unless you are quite experienced. The traces, components etc. is really important. And then again, have you checked my previous projects? I have already written the software, so you can just get a RFM22B/OpenLRS receiver (will most likely be available from HK dead cheap soon) if you wan't to check for noise in the 433mhz area. It can scan the same band as RF-explorer WSUB1G if you change the input-filters. http://www.rcgroups.com/forums/showthread.php?t=1617297 It have been used by a few to find noise-sources etc. and was also used to find a bug in the UK UHF firmware (they used another frequency than expected) |
United States, AZ, Prescott Valley
Joined Feb 2012
Thanks Dennis Rick |
Just updated PCB with 3.3V LDO regulator for I2C, 2 pads for RAW if needed for other equipment, PPM-input is now connected directly to GND and Vcc (which means that the OSD can be powered directly from the receiver if needed), and minor changes in the layout.
It's an untested design, but I don't mind to make it available if anyone is interested The gerber-files etc. will be available when I have a "final design" that have been tested ![]() https://www.batchpcb.com/ https://www.batchpcb.com/pcbs/100746
Take a look at your MAX7456 breakout-board. If you are able to solder all those components - you should be good to go. If you have never soldered SMD before, this is not the best place to start. It's not exactly a DIY-friendly board, as MAX7456 is not available in larger packages. I just use a descent soldering-iron and some solder-wick. It works pretty well.
I think this should be the basic BOM...
Necessary components 1 x Atmega328p (farnell 1715486) 1 x MAX7456 1 x 16MHz crystal (farnell 1841946) 1 x 27MHz crystal (farnell 1841955) 0603-size: 2 x 18pF (load caps for 16MHz crystal, should be NP0/C0G) 0805-size: 1 x 100nF (used to AC-couple video-signal input) 2 x 75ohm (input and output impedance of video line) 1206-size 2 x 47uF cap (to AC-couple video-output. Tantalum is fine) Recommended components 0603-size: 5 x 100nF (decoupling on Atmega328p and MAX7456) 0805-size (0603 is also fine): 3 x 1k (used to pull-up sync-signals to 5-volt) 1 x 10k (used as pull-up on atmega reset-pin) Voltage-divider 1 x 3k3 1 x 10k Analog input: 2 x series resistors Optional components: For I2C: SOT-23 3.3V LDO regulator 1 x 1uF capacitor (0603) For extra decoupling you can use: 2 x 1206 capacitors 4 x 0805 capacitors |
i personally use 1% resistors, 10% caps on my stuff (unless ds states otherwise) and other than the 18pf npo i am assuming x7r for other 0603/0805 caps and the 1206 47uF in tantalum? also might want to list min V requirements for the caps - i haven't looked at the ds for the max chip so I don't know if anything needs a relatively high V tolerance (like the invensense itg3200/mpu3050/mpu6000 and many other in that line, the ds states the charge pump cap 2.2nF needs to be rated @ 50V) i would also recommend people buying quite a few of the components, especially the 0603 stuff - they are cheap and can easily be blown off the pcb or just plain lost. 0805 and 1206 not so much, but again, the prices are not too bad, w/ the exception of the 47uF tantalum caps @ ~.50 or so each, the other caps/resistors will be much cheaper. last time i bought 1000 1K resistors, 1% i think i paid $3, and that is through mouser just a couple things you may assume but people new may not know bob4432/brian |
Thanks for your comments, always nice with some feedback. I see some information slipped, I will edit the post ![]() You only need 2 x 18pF capacitors, as MAX7456 have internal load-capacitors. I had the footprints on the first PCB-design and checked that it worked without mounting extra capacitors ![]() The 3,3V ldo regulator is a SOT23-3. I could have picked a SOT23-5, but it shouldn't make any major difference. I will probably use a 1 uF cap on the output, I believe 100 nF is acceptable as well, but you are right, 1 uF is the recommended value. The resistor and capacitor ratings are not very important for this purpose, pretty much all components can be low rating (sure, C0G/NP0 at 18pF caps is a good idea) , but the rest of the components doesn't really matter. It's all running at 5-volt which shouldn't be any problem at all. |
| Thread Tools | |
| Help! OSD version UNKNOWN and fail to update (error) | dROb | Eagle Tree Systems | 9 | May 16, 2012 05:12 PM |
| Sold EASY OSD (Version 1.2) Brand New . $75 shipped. | LHTPlane | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 20, 2012 10:45 PM |
| For Sale MAX7456 OSD Break out board. | ziomatrixacs | FPV/RPV - Equipment and Vehicles (FS/W) | 4 | Jun 18, 2011 03:50 PM |
