Old Apr 17, 2013, 06:12 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by msev View Post
I've sent him one, but apparently he hasn't received it yet...hope he does soon..
sounds good
Have you had the time to assemble an OSD yourself?
Dennis Frie is offline Find More Posts by Dennis Frie
Old Apr 17, 2013, 06:17 PM
msev is online now
Find More Posts by msev
Joined Sep 2010
Originally Posted by Dennis Frie View Post
sounds good
I'm waiting for some Pro guy with pro tools to come home from vacation, he'll solder me one up for a song (and a beer), next I hope I can talk buisness with him to solder a few up for guys here on rcg
msev is online now Find More Posts by msev
Old Apr 17, 2013, 06:54 PM
bob4432 is offline
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
know it is off topic, but would like to hear about the weather balloon project - will be interesting to see how the temps affect the sensors. what baro you using? that error may actually become an issue now (i think there was a baro issue if memory serves me, but my memory is not good at all, so that may be something else i read)
brian
I'll be adding a few extra features I need for a weather-balloon project. If anyone else have some small things they would like to see implemented, let me know and I'll see if we can get it included in the the next update.
bob4432 is offline Find More Posts by bob4432
Old Apr 17, 2013, 07:05 PM
Just another user
Joined Feb 2011
brian
We will most likely be using BMP085 with a very small hole in the foam. It's rated to minimum 0 degrees for normal performance and working down until -40 degrees (if I remember correctly).
So far I've coded a simple temperature-control. We plan to use a small heating-element/resistor to keep a, more or less, constant temperature in the fuse. That should help a lot with the temperature-problem and don't require much energy with well isolated foam-plane.
I've started to code a part of the release-code, to make sure the plane will be released, if fail-safe is active more than x seconds. The OSD should be able to handle everything, so no need to use extra hardware.
Old Apr 17, 2013, 10:29 PM
bob4432 is offline
bob4432's Avatar
Joined May 2010
sounds like fun so far
Old Apr 18, 2013, 06:12 AM
IceWind is offline
Find More Posts by IceWind
throw new IOPilotException();
IceWind's Avatar
Ireland, County Dublin, Dublin
Joined Feb 2005
Hey,
Anyone in EU that may want to sell any extra PCB?
(probably some parts as well)
Thanks.
IceWind is offline Find More Posts by IceWind
Old Apr 18, 2013, 07:48 AM
jalves is offline
Find More Posts by jalves
jalves's Avatar
Portugal
Joined Mar 2004
If you want to use a daughter board with it for input/output, minimOSD pcb boards work very well for DFmaxOSD code.
jalves is offline Find More Posts by jalves
Old Apr 19, 2013, 07:28 PM
bstott2 is offline
Find More Posts by bstott2
bstott2's Avatar
United States, MO, Springfield
Joined Feb 2013
@ Dennis --- I used your file and tried to submit the mfg order to Seeed through their website. I got an error message telling me to rename the file. I used your *.rar just from your posted link. I even checked it and reviewed the contents. All looked good. Anyway - I zipped the file and resubmitted to Seeed and the application accepted and processed my payment.... I'll check with them next week about the order.
@ msev --- Yeah - mystery. I am still waiting. I think I jinxed our plan by joking about it getting lost. It's all good though. We'll see what else shows up.
bstott2 is offline Find More Posts by bstott2
Old Apr 19, 2013, 09:03 PM
Just another user
Joined Feb 2011
Arh, SeedStudio don't accept 2 PCB-orders, with the same filename. As I have already uploaded the rar-file, you get an error. I've just renamed the rar-file to something else. OSD_PCB_V1_1_bstott.rar for example in your case
A ZIP-file should be fine too, but simply changing the name in the original file is all that's needed
Old Apr 20, 2013, 06:43 AM
Just another user
Joined Feb 2011
Just made a quick sketch for auto baudrate detection, seems to work pretty well and will probably be included in next update
Old Apr 20, 2013, 06:47 AM
HOL is offline
HOL
Find More Posts by HOL
HOL
Danmark, Midtjylland, Galten
Joined Oct 2011
HOL is offline Find More Posts by HOL
Old Apr 20, 2013, 06:55 AM
msev is online now
Joined Sep 2010
I still have hope for it to arrive to your place...My first shipment to the US can't be lost man , that would be really unlucky.
Old Apr 20, 2013, 09:39 AM
Just another user
Joined Feb 2011
Originally Posted by Spejlo View Post
hi Denis
I found one nasty bug.. some GPS receivers (ublox NEO 6) sends GGA and RMC together (no delay between)
everything is OK before homepos is set.. but after that.. all the calculations are little time consuming and GGA sentence is missing 2 chars (on baud 38400) (hope you understand my english
I fix it for myself (but it's not universal)
if (homepos==1) ggapos=3; else ggapos=5;
if (GPSbuffer[ggapos+1]=='A' && GPSbuffer[ggapos] =='G') {
I've just written a fix, that should ensure this is no longer a problem
Would you mind to test, if I upload a test-version?
Old Apr 20, 2013, 11:34 AM
Legot is offline
Find More Posts by Legot
Build to Fly? FLY to BUILD!
Legot's Avatar
United States, AZ, Gilbert
Joined Nov 2009
Does anyone have a spare board that they're willing to give up?
Legot is offline Find More Posts by Legot
Old Apr 20, 2013, 12:59 PM
Just another user
Joined Feb 2011
So far...
  • Fixed problem with Ublox GPS module
  • Auto baudrate detection added
And for a weather-balloon project the following have been added, which can be used as well
  • Failsafe indication
  • Output for heater-element based on temperature from BMP085 (to keep electronic warm)
  • Servo-output to release payload from balloon. Automatic released if failsafe is present more than x seconds (low resolution servo-output)
Anything else I promised to add?
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 06:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 11:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 04:50 PM
