Old Apr 06, 2013, 05:26 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
MAX7456 will run without Atmega328, but it will not show any characters. That means you will get sync-pulses, but a completely black screen.
As suggested by Badlands, I high-res image might help us find the problem
Dennis Frie is offline Find More Posts by Dennis Frie
Old Apr 07, 2013, 01:56 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Something might be up with my MAX7456 chips I bought from ebay as I get no black screen and the supply voltage is correct at the chip.
Everything else was from RS components.
Hi res pic - see anything obvious?
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Apr 07, 2013, 02:38 PM
Just another user
Joined Feb 2011
That looks pretty good, well done.
Just to be sure, you have supplied 5 volt right?
I don't really have any good suggestions. You can check the connections on MAX7456 with a multimeter to be sure you don't have a short somewhere, but it looks pretty good.
I can see that you live in England, so in case you canīt find the problem, I don't mind to have a look at it. Shipping from England to Denmark shouldn't be too bad.
Old Apr 07, 2013, 04:15 PM
BillyJo is offline
Find More Posts by BillyJo
FpvQc
BillyJo's Avatar
Canada, QC, Quebec
i received my parts today, i begin to solder parts on board here a pics =)
BillyJo is offline Find More Posts by BillyJo
Old Apr 07, 2013, 04:21 PM
Just another user
Joined Feb 2011
Looks good so far
Really cool to see people build it, even though it's all SMD-components and far from a complete kit!
Old Apr 07, 2013, 04:31 PM
Devonboy is offline
SW England
Joined Aug 2009
OK, got mine working.
Stupid schoolboy error and ordered the incorrect 27MHz crystal.
The one I got has 4 solder pads, 2 for the crystal output and 2 for ground.
I never checked, I remember I was more interested in the size.
Anyways, scewed the xtal on the PCB and it runs!
Nigel.
Old Apr 07, 2013, 04:34 PM
Just another user
Joined Feb 2011
Nigel.
Haha, you didn't notice the extra pads when soldering the crystal?
Anyways, nice you found the problem. Hope the rest will be piece of cake
Old Apr 07, 2013, 05:01 PM
Devonboy is offline
SW England
Joined Aug 2009
Nope, no need for orientation on the crystal (normally !!)
I soldered it with one of these and some solder paste.
Aoyue 852A+ SMD Rework Station Demo 1 (1 min 33 sec)
Nigel.
Old Apr 08, 2013, 02:30 PM
findus4fun is offline
Find More Posts by findus4fun
Joined Mar 2013
OSD and PA6 Gerber Files
Originally Posted by jeffkash View Post
I'm interested. Please post.
Hi, here are the gerber files from the merged pa6 and osd which fit on 50x50mm. I did not manufacture them so far but I think everything should be ok.
Please give me a short message if the files worked for you.
Jan
findus4fun is offline Find More Posts by findus4fun
Old Apr 08, 2013, 05:55 PM
BillyJo is offline
FpvQc
BillyJo's Avatar
Canada, QC, Quebec
here is the final result ! two working OSD =)
did not play yet with the Config, thanks again !
Old Apr 09, 2013, 12:43 PM
Just another user
Joined Feb 2011
Thanks for sharing
Looking forward to hear your impression, when you get time to test it in-air
Old Apr 13, 2013, 03:41 PM
Devonboy is offline
SW England
Joined Aug 2009
Finally got an MTK3329 GPS.
Configured at 9600 baud and 1Hz update.
Set the same in config.h and when the GPS is connected, it either won't fully boot or boots up and then reboots over and over.
I have another GPS that runs at 38400 baud and 1Hz update rate.
Same thing with this one (after changing config files and uploading).
It runs fine with nothing at all attached (although the battery counter counts up quite rapidly?).
Any clues as to what is going wrong here...
Nigel.
Old Apr 13, 2013, 03:46 PM
Just another user
Joined Feb 2011
Nigel.
That sounds weird. I've never experienced that it have rebooted.
What hardware did you use for testing? An Arduino or the dedicated OSD-hardware? Arduino have some auto reset function associated with serial-communication
Old Apr 13, 2013, 03:53 PM
Devonboy is offline
SW England
Joined Aug 2009
Dedicated OSD hardware -- this one http://www.rcgroups.com/forums/showp...&postcount=921
Nigel
Old Apr 14, 2013, 05:16 AM
penpen is online now
Find More Posts by penpen
France, IdF, Paris
Joined May 2010
Is it possible to reuse arrow pics and placing in 7456 matrix's display to make a radar view of position of plane ? like suppo easy osd and rvosd ?
penpen is online now Find More Posts by penpen
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
