Old Apr 03, 2013, 01:45 PM
Dennis Frie is offline
Find More Posts by Dennis Frie
Just another user
Dennis Frie's Avatar
Denmark, Capital Region of Denmark, Naerum
Joined Feb 2011
Originally Posted by Spejlo View Post
hi Denis
I found one nasty bug.. some GPS receivers (ublox NEO 6) sends GGA and RMC together (no delay between)
everything is OK before homepos is set.. but after that.. all the calculations are little time consuming and GGA sentence is missing 2 chars (on baud 38400) (hope you understand my english
I fix it for myself (but it's not universal)
if (homepos==1) ggapos=3; else ggapos=5;
if (GPSbuffer[ggapos+1]=='A' && GPSbuffer[ggapos] =='G') {
Great to know, thanks a lot
It have never been a problem with the GPS-units I've tested, but I might consider to add a more flexible GPS-routine, that will not have this limitation.
Dennis Frie is offline Find More Posts by Dennis Frie
Old Apr 03, 2013, 04:34 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
hi Denis
Which Neo-6 module are you using exactly? Is it Neo-6m (like rctimer,goodluckbuy,hk gps?)?
msev is offline Find More Posts by msev
Old Apr 04, 2013, 12:10 AM
Spejlo is offline
Find More Posts by Spejlo
Joined Sep 2011
yes Neo-6M from HK.. I have 4 GPS units and only this one cause little problems
Spejlo is offline Find More Posts by Spejlo
Old Apr 04, 2013, 07:02 AM
Spejlo is offline
Joined Sep 2011
if I may suggest. move all calculations outside interrupt and everything should be OK
Old Apr 04, 2013, 11:18 AM
msev is offline
Joined Sep 2010
Just for information purpose which other gps's do you also have?
Old Apr 04, 2013, 11:44 AM
Just another user
Joined Feb 2011
Unfortunately, that will give some other complications. If the GPS-calculations are moved from the interrupt, the next serial-string will overwrite the previous string. I can make an extra receive-buffer, but it will require a bit of extra SRAM (and the GPS-calculations have to wait for the 10 and 5 Hz loop to finish, but that's most likely not a problem).
Nevertheless, this is probably the best solution. I just have to check the timing and re-arrange a bit
Old Apr 04, 2013, 01:57 PM
Spejlo is offline
Joined Sep 2011
I think its only universal (bulletproof) way to move calculations outside of interrupt.
if I change baud rate to 115200 much more chars is missing
but if no one have this problem just take it easy.. no hurry.. I fix this for myself and maybe it's possible to add delay between RMC and GGA in ublox config
Old Apr 04, 2013, 02:03 PM
Spejlo is offline
Joined Sep 2011
EagleTree V4 10hz
HobbyKing G-OSD 1hz
and one unknown 1hz
all these have no problem
Old Apr 04, 2013, 03:45 PM
mbanzi is offline
Find More Posts by mbanzi
United States, CA, San Diego
Joined Jul 2011
Is there a list of GPS modules that work well with the OSD (especially the 5-10Hz ones)? I am looking to upgrade my G-OSD 1Hz GPS to something better, not sure what to buy.
I've scanned through both the threads for the OSD and have seen several GPS models mentioned, but nothing specific mentioned.
mbanzi is offline Find More Posts by mbanzi
Old Apr 04, 2013, 04:56 PM
Just another user
Joined Feb 2011
All GPS-modules with normal NMEA-strings should work. I use a MTK GPS, but it shouldn't be necessary to use that exact brand.
It's the first time I've heart of the problem mentioned by Spejlo, but I'll try to get that solved for next update.
Old Apr 04, 2013, 11:59 PM
Spejlo is offline
Joined Sep 2011
I suggest NEO 6M.. it's clearly best I've seen.. it's fast (about 30sec to fix) and super sensitive (in two story building 6-7 sats)
don't be scared if this one doesn't work properly for now.. you can easily fix that (hard-coded but works like a charm)
Old Apr 05, 2013, 05:56 AM
msev is offline
Joined Sep 2010
Can you still configure the GPS regarding baudrate and frequency...For example in that case one could use both gps for flight controller and osd.. (that they would both use same value for baud rate and frequency)...What about UBX protocol?
Old Apr 05, 2013, 06:41 AM
Spejlo is offline
Joined Sep 2011
I don't see any problem using one GPS for OSD and flight controller (I use it like this with ArduPlane 38400/10hz RMC and GGA)
UBX protocol was the first thing I've turned off. things that I have only one support UBX protocol.. NMEA is much more supported
Old Apr 05, 2013, 04:57 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
Just got my first board built using Dennis' PCB v1.1 (and put the 47uF caps the correct way round).
Burnt bootloader, uploaded the graphics and default software.
Nothing out of the video, nada, zip.
It's late and I'm tired, probably doing something wrong...but, am I right in thinking the MAX7456 should output something to a monitor/screen regardless of any input (even without a camera connected or the Atmega running)?
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Apr 06, 2013, 05:23 PM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Nigel.
Nigel - yes you shoud get an output without a camera connected, sounds like your Atmega is running thou if you can firmware it?
Upload a clear picture of the PCB for the forum users to look at?
badlands is offline Find More Posts by badlands
Help! OSD version UNKNOWN and fail to update (error) dROb Eagle Tree Systems 9 May 16, 2012 05:12 PM
Sold EASY OSD (Version 1.2) Brand New . $75 shipped. LHTPlane FPV Equipment (FS/W) 7 Mar 20, 2012 10:45 PM
For Sale MAX7456 OSD Break out board. ziomatrixacs FPV Equipment (FS/W) 4 Jun 18, 2011 03:50 PM
